Get started with ClickHouse on Google Cloud C4A Arm virtual machines
Create a Firewall Rule on GCP
Create a Google Axion C4A Arm virtual machine on GCP
Set up GCP Pub/Sub and IAM for ClickHouse real-time analytics on Axion
Install ClickHouse
Establish a ClickHouse baseline on Arm
Build a Dataflow streaming ETL pipeline to ClickHouse
Benchmark ClickHouse on Google Axion processors
In this section you’ll benchmark query latency on ClickHouse running on Google Axion (Arm64). The goal is to measure repeatable query latency with a focus on p95 latency, using data ingested with the real-time Dataflow pipeline.
ClickHouse may serve repeated queries from its query cache, which can artificially reduce latency numbers. To ensure that every query is fully executed, the query cache is disabled.
Run this inside the ClickHouse client:
SET use_query_cache = 0;
This ensures every query is executed fully and not served from cache.
Ensure enough data is present to produce meaningful latency results by checking the current row count.
SELECT count(*) FROM realtime.logs;
The output is similar to:
┌─count()─┐
1. │ 5000013 │ -- 5.00 million
If data volume is low, generate additional rows (optional):
INSERT INTO realtime.logs
SELECT
now() - number,
concat('service-', toString(number % 10)),
'INFO',
'benchmark message'
FROM numbers(1000000);
Query id: 8fcbefab-fa40-4124-8f23-516fca2b8fdd
Ok.
1000000 rows in set. Elapsed: 0.058 sec. Processed 1.00 million rows, 8.00 MB (17.15 million rows/s., 137.20 MB/s.)
Peak memory usage: 106.54 MiB.
These queries represent common real-time analytics patterns:
Each query scans and processes millions of rows to stress the execution engine.
Query 1 – Filtered Count (Service-level analytics)
SELECT count(*)
FROM realtime.logs
WHERE service = 'service-5';
Query id: cfbab386-7168-42ce-a752-2d5146f68b48
┌─count()─┐
1. │ 350000 │
1 row in set. Elapsed: 0.013 sec. Processed 6.00 million rows, 74.50 MB (466.81 million rows/s., 5.80 GB/s.)
Peak memory usage: 3.25 MiB.
Query 2 – Time-windowed Count (Recent activity)
SELECT count(*)
FROM realtime.logs
WHERE event_time >= now() - INTERVAL 10 MINUTE;
Query id: 7654746b-3068-4663-a5c6-6944d9c2d2b9
┌─count()─┐
1. │ 572 │
1 row in set. Elapsed: 0.003 sec.
Query 3 – Aggregation by Service
SELECT
service,
count(*) AS total
FROM realtime.logs
GROUP BY service
ORDER BY total DESC;
Query id: c48c0d30-0ef6-4fb9-bbb9-815a509a5f91
┌─service────┬──total─┐
1. │ service-6 │ 350000 │
2. │ service-1 │ 350000 │
3. │ service-0 │ 350000 │
4. │ service-7 │ 350000 │
5. │ service-3 │ 350000 │
6. │ service-4 │ 350000 │
7. │ service-5 │ 350000 │
8. │ service-2 │ 350000 │
9. │ service-9 │ 350000 │
10. │ service-8 │ 350000 │
11. │ service-10 │ 250000 │
12. │ service-15 │ 250000 │
13. │ service-16 │ 250000 │
14. │ service-13 │ 250000 │
15. │ service-18 │ 250000 │
16. │ service-17 │ 250000 │
17. │ service-19 │ 250000 │
18. │ service-12 │ 250000 │
19. │ service-11 │ 250000 │
20. │ service-14 │ 250000 │
21. │ api │ 12 │
22. │ local │ 1 │
22 rows in set. Elapsed: 0.011 sec. Processed 6.00 million rows, 74.50 MB (527.10 million rows/s., 6.54 GB/s.)
Peak memory usage: 7.18 MiB.
To calculate reliable latency metrics, execute the same query multiple times (10 iterations) using clickhouse-client --time.
clickhouse-client --time --query "
SELECT count(*)
FROM realtime.logs
You should see an output similar to:
350000
0.009
350000
0.009
350000
0.009
350000
0.011
350000
0.010
350000
0.0011
350000
0.009
350000
0.009
350000
0.009
350000
0.011
Each run prints:
Edit your file:
vi latency-results.txt
Only the latency values are required for statistical analysis. Row counts are removed.
0.009
0.009
0.009
0.011
0.010
0.011
0.009
0.009
0.009
0.011
Sort the latency values: Latency values are sorted in ascending order to compute percentiles.
sort -n latency-results.txt
0.009
0.009
0.009
0.009
0.009
0.009
0.010
0.011
0.011
0.011
Calculate p95 latency (manual):
The p95 latency represents the value under which 95% of query executions complete.
Formula:
p95 index = ceil(0.95 × N)
For 10 samples:
ceil(0.95 × 10) = ceil(9.5) = 10
The 10th value in the sorted list is your p95 latency.
p95 result
p95 latency = 0.011 seconds ≈ 11 ms
After executing the ClickHouse query 10 times on the GCP Axion (Arm) VM, the observed p95 query latency was ~11 ms, demonstrating consistently low-latency analytical performance on Arm-based infrastructure.
You’ve successfully completed a comprehensive ClickHouse benchmarking exercise on Google Axion (Arm64) processors. Key results from the c4a-standard-4 (4 vCPU, 16 GB memory) Arm64 VM running SUSE:
Throughout this Learning Path, you provisioned an Arm-based VM on Google Cloud, deployed ClickHouse, configured a real-time streaming pipeline with Pub/Sub and Dataflow, and validated end-to-end analytical performance. You can now deploy, optimize, and benchmark ClickHouse workloads on Google Cloud Arm infrastructure.
