Get started with ClickHouse on Google Cloud C4A Arm virtual machines
Create a Firewall Rule on GCP
Create a Google Axion C4A Arm virtual machine on GCP
Set up GCP Pub/Sub and IAM for ClickHouse real-time analytics on Axion
Install ClickHouse
Establish a ClickHouse baseline on Arm
Build a Dataflow streaming ETL pipeline to ClickHouse
Benchmark ClickHouse on Google Axion processors
This section shows you how to validate that ClickHouse is functioning correctly and establish a basic performance baseline on your SUSE Linux Arm64 virtual machine.
Verify that the ClickHouse server is running:
sudo systemctl status clickhouse-server
The output is similar to:
● clickhouse-server.service - ClickHouse Server
Loaded: loaded (/etc/systemd/system/clickhouse-server.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2025-11-27 05:07:42 UTC; 18s ago
Main PID: 4229 (ClickHouseWatch)
Tasks: 814
CPU: 2.629s
CGroup: /system.slice/clickhouse-server.service
├─ 4229 clickhouse-watchdog server --config=/etc/clickhouse-server/config.xml
└─ 4237 /usr/bin/clickhouse server --config=/etc/clickhouse-server/config.xml
Connect to the ClickHouse server using the client:
clickhouse client
Create a test database and table to establish a controlled environment for baseline evaluation:
CREATE DATABASE baseline_test;
USE baseline_test;
Query id: bc615167-ecd5-4470-adb0-918d8ce07caf
Ok.
0 rows in set. Elapsed: 0.012 sec.
USE baseline_test
Query id: cd49553a-c0ff-4656-a3e5-f0e9fccd9eba
Ok.
0 rows in set. Elapsed: 0.001 sec.
Create a table optimized for analytics:
CREATE TABLE events
event_time DateTime,
user_id UInt64,
event_type String
ENGINE = MergeTree
ORDER BY (event_time, user_id);
Query id: 62ce9b9c-9a7b-45c8-9a58-fa6302b13a88
Ok.
0 rows in set. Elapsed: 0.011 sec.
Data insertion loads a small, controlled dataset to simulate real event data and validate write functionality. Insert sample data (10,000 rows):
INSERT INTO events
SELECT
now() - number,
number,
'click'
FROM numbers(10000);
Query id: af860501-d903-4226-9e10-0e34467f7675
Ok.
10000 rows in set. Elapsed: 0.003 sec. Processed 10.00 thousand rows, 80.00 KB (3.36 million rows/s., 26.86 MB/s.)
Peak memory usage: 3.96 MiB.
Verify the row count:
SELECT count(*) FROM events;
Query id: 644f6556-e69b-4f98-98ec-483ee6869d6e
┌─count()─┐
1. │ 10000 │
1 row in set. Elapsed: 0.002 sec.
The results below are intended to establish a baseline for this environment and configuration, not to serve as a comprehensive benchmark or comparison.
Run a simple filtered count query:
SELECT count(*) FROM events WHERE event_type = 'click';
Query id: bd609de4-c08e-4f9f-804a-ee0528c94e4d
┌─count()─┐
1. │ 10000 │
1 row in set. Elapsed: 0.003 sec. Processed 10.00 thousand rows, 130.00 KB (2.98 million rows/s., 38.71 MB/s.)
Peak memory usage: 392.54 KiB.
Run a query that groups events by date and counts occurrences:
SELECT
toDate(event_time) AS date,
count(*) AS total_events
FROM events
GROUP BY date
ORDER BY date;
Query id: b3db69f8-c885-419f-9900-53d258f0b996
┌───────date─┬─total_events─┐
1. │ 2025-11-27 │ 10000 │
1 row in set. Elapsed: 0.002 sec. Processed 10.00 thousand rows, 40.00 KB (4.08 million rows/s., 16.33 MB/s.)
Peak memory usage: 785.05 KiB.
Exit the client:
exit
You’ve validated that ClickHouse is stable and functional on the Arm64 virtual machine and established a basic performance baseline you can build on.
