Install CircleCI machine runner on AWS Graviton
This section provides step-by-step instructions to install and configure the CircleCI Machine Runner. With this setup, your self-hosted Arm64 environment can efficiently execute CircleCI jobs directly on the Graviton architecture, enabling faster builds and improved performance for ARM-based workloads.
Add the CircleCI package repository
For Debian/Ubuntu-based systems running on AWS Graviton (Arm64), first add the official CircleCI repository. This ensures you can install the CircleCI Runner package directly using apt.
curl -s https://packagecloud.io/install/repositories/circleci/runner/script.deb.sh?any=true | sudo bash
After successful execution, the CircleCI repository will be added under /etc/apt/sources.list.d/. Run the command to verify:
ls /etc/apt/sources.list.d/
Install the CircleCI runner
To install the CircleCI runner, use the following command:
sudo apt-get install -y circleci-runner
This command installs the latest CircleCI Machine Runner for your Arm64 system. The runner program is placed in /usr/bin/, and its configuration files are stored in /etc/circleci-runner/.
Configure the runner authentication token
Update the CircleCI runner configuration with your authentication token. This token is generated from the resource class you created in the CircleCI Dashboard.
export RUNNER_AUTH_TOKEN="YOUR_AUTH_TOKEN"
sudo sed -i "s/<< AUTH_TOKEN >>/$RUNNER_AUTH_TOKEN/g" /etc/circleci-runner/circleci-runner-config.yaml
Enable and start the CircleCI runner
Set the CircleCI runner service to start automatically and verify it is running:
sudo systemctl enable circleci-runner
sudo systemctl start circleci-runner
sudo systemctl status circleci-runner
If the status shows active (running), your runner is successfully installed and connected to CircleCI.
        ● circleci-runner.service - Run the CircleCI self-hosted runner agent
     Loaded: loaded (/usr/lib/systemd/system/circleci-runner.service; enabled; preset: enabled)
     Active: active (running) since Fri 2025-10-17 05:33:20 UTC; 51min ago
   Main PID: 2226 (circleci-runner)
      Tasks: 9 (limit: 18717)
     Memory: 53.0M (peak: 66.9M)
        CPU: 1.249s
     CGroup: /system.slice/circleci-runner.service
             └─2226 /usr/bin/circleci-runner machine -c /etc/circleci-runner/circleci-runner-config.yaml
Oct 17 05:41:28 ip-172-31-34-224 circleci-runner[2226]: 05:41:28 7b67e 24.210ms worker loop: claim:  app.backoff_ms=5000 app.>
Oct 17 06:00:08 ip-172-31-34-224 circleci-runner[2226]: 06:00:08 a8093 22.942ms POST /api/v3/runner/claim app.loop_name=claim>
Oct 17 06:00:08 ip-172-31-34-224 circleci-runner[2226]: 06:00:08 a8093 23.028ms claim app.loop_name=claim:  mode=agent result>
Oct 17 06:00:08 ip-172-31-34-224 circleci-runner[2226]: 06:00:08 a8093 23.064ms worker loop: claim:  app.backoff_ms=5000 app.>
Oct 17 06:04:49 ip-172-31-34-224 circleci-runner[2226]: 06:04:49 73039 19.847ms POST /api/v3/runner/claim app.loop_name=claim>
Oct 17 06:04:49 ip-172-31-34-224 circleci-runner[2226]: 06:04:49 73039 19.936ms claim app.loop_name=claim:  mode=agent result>
Oct 17 06:04:49 ip-172-31-34-224 circleci-runner[2226]: 06:04:49 73039 19.971ms worker loop: claim:  app.backoff_ms=5000 app.>
Oct 17 06:19:13 ip-172-31-34-224 circleci-runner[2226]: 06:19:13 c34c1 22.392ms POST /api/v3/runner/claim app.loop_name=claim>
Oct 17 06:19:13 ip-172-31-34-224 circleci-runner[2226]: 06:19:13 c34c1 22.479ms claim app.loop_name=claim:  mode=agent result>
Oct 17 06:19:13 ip-172-31-34-224 circleci-runner[2226]: 06:19:13 c34c1 22.514ms worker loop: claim:  app.backoff_ms=5000 app.>
This confirms that the CircleCI Runner is actively connected to your CircleCI account and ready to accept jobs.
You can also verify it from the dashboard:
Image Alt Text:Diagram showing the CircleCI self-hosted runner architecture. The main subject is an AWS Graviton server labeled as a self-hosted runner, connected to the CircleCI cloud platform. Arrows indicate job requests flowing from CircleCI to the runner and job results returning to CircleCI. The environment includes icons for cloud infrastructure and developer workstations. The tone is technical and informative. Any visible text in the image is transcribed as: Self-Hosted Runners. alt-textSelf-Hosted Runners
