# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/circleci-on-aws/)
- [Get Started with CircleCI on AWS Graviton](https://learn.arm.com/learning-paths/servers-and-cloud-computing/circleci-on-aws/background/)
- [Create an AWS EC2 Arm64 Graviton Instance](https://learn.arm.com/learning-paths/servers-and-cloud-computing/circleci-on-aws/instance/)
- [Install CircleCI CLI](https://learn.arm.com/learning-paths/servers-and-cloud-computing/circleci-on-aws/circlecli-installation/)
- [Create a resource class in CircleCI](https://learn.arm.com/learning-paths/servers-and-cloud-computing/circleci-on-aws/resource-class/)
- [Install CircleCI machine runner on AWS Graviton](https://learn.arm.com/learning-paths/servers-and-cloud-computing/circleci-on-aws/circleci-runner-installation/)
- [Verify CircleCI Arm64 Self-Hosted runner](https://learn.arm.com/learning-paths/servers-and-cloud-computing/circleci-on-aws/validation/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/circleci-on-aws/_next-steps/)
## Explore related resources
- [AWS EC2 Graviton Documentation](https://aws.amazon.com/ec2/graviton/)
- [CircleCI Self-Hosted Runner Documentation](https://circleci.com/docs/guides/execution-runner/install-machine-runner-3-on-linux/)
- [CircleCI CLI Documentation](https://circleci.com/docs/guides/toolkit/local-cli/)
## Review frequently asked questions
### Which EC2 instance and AMI should I select to follow the steps?
Use an Amazon EC2 instance powered by AWS Graviton, such as `m6g.large`, and choose a Linux AMI such as Ubuntu in the AWS Management Console. You’ll follow a console-based instance launch workflow.
### What should I install before setting up the CircleCI CLI?
Install curl, tar, gzip, coreutils, gpg, and git using your package manager. These tools enable downloading, verifying, and extracting the CLI.
### What do I need before creating a resource class for the self-hosted runner?
Access the CircleCI dashboard and ensure an organization/namespace is available. The resource class links your runner to that namespace so jobs can target it.
### How do I confirm the machine runner is installed and connected?
After adding the CircleCI package repository and installing the runner, the agent registers to your resource class. Running the sample workflow should start on the EC2 instance and complete the test computation.
### What should I check if a job does not run on the self-hosted runner?
Verify the job targets the resource class you created, the EC2 instance is running, and the runner process is installed on that instance. Then re-run the workflow from the CircleCI dashboard.
