Deploy Ceph RADOS Block Device storage on an Arm AGI CPU host
Understand the staged Ceph topology
Create three virtual machines
Prepare and validate the virtual machines
Bootstrap Ceph on one node
Create and use an RBD volume
Expand Ceph to three nodes
Test Ceph RBD during an OSD outage and recovery
Use
cephadm 19.2.6 to match the Ceph Squid 19.2.6 cluster release. Ubuntu 26.04 repositories provide Ceph 20.2.0, so download cephadm 19.2.6 directly to keep the deployment tools and cluster on the same version.Run VM creation commands on the Arm AGI CPU host. Run preparation commands inside each VM. During expansion, authorize the cluster SSH key on the new nodes from the AGI host. Run cluster bootstrap, RBD usage, and the remaining expansion commands inside
ceph1.Confirm each VM has 4 vCPUs, 4 GB memory, a 20 GB OS disk, and a separate unused data disk of at least 10 GB. Also ensure that each VM has stable IP addressing, SSH access, hostname resolution, and synchronized clocks. Identify the empty data disk that Ceph will use on each node.
You should see a block device such as
/dev/rbd0. Format and mount it, write a test file, then unmap and remap the image. Compare checksums to verify that the file persists in Ceph.You add two more Ceph nodes so that the cluster runs one OSD per node. A controlled OSD failure tests whether you can keep reading and writing the RBD volume. After the OSD returns, you verify that Ceph repairs changed objects and both the original and outage files retain their checksums.
