Replicate data across three nodes
You’ll add the prepared ceph2 and ceph3 virtual machines (VMs) to the existing cluster. Then, you’ll increase the RADOS Block Device (RBD) pool from one copy of its data to three. Start on the AGI host to authorize SSH access, then administer the cluster from ceph1. Keep the RBD volume mounted so that you can check the same file after replication completes.
Authorize cephadm on the new nodes
cephadm uses SSH to deploy and manage services on the additional nodes.
Start in a terminal on the AGI host with the SSH key at ~/.ssh/agi_ceph.
Retrieve the public SSH key of the cluster from ceph1:
ssh -o ConnectTimeout=10 -i "${HOME}/.ssh/agi_ceph" \
  ubuntu@192.168.100.11 'sudo -n cat /etc/ceph/ceph.pub' \
  > /tmp/agi-ceph-cluster.pub
ssh-keygen -lf /tmp/agi-ceph-cluster.pub
Install that public key using the existing ubuntu access on each new node:
for VM_NUMBER in 2 3; do
  VM_IP="192.168.100.$((10 + VM_NUMBER))"
  ssh -o ConnectTimeout=10 -o BatchMode=yes \
    -i "${HOME}/.ssh/agi_ceph" "ubuntu@${VM_IP}" \
    'sudo -n install -d -m 700 /root/.ssh &&
     sudo -n touch /root/.ssh/authorized_keys &&
     sudo -n chmod 600 /root/.ssh/authorized_keys &&
     sudo -n tee -a /root/.ssh/authorized_keys >/dev/null' \
    < /tmp/agi-ceph-cluster.pub
done
This authorizes the cephadm root SSH key without enabling password login or copying the private key of the AGI host.
Return to the SSH session on ceph1 for all remaining commands.
Add both hosts with their stable addresses:
sudo /usr/local/sbin/cephadm shell -- ceph orch host add ceph2 192.168.100.12
sudo /usr/local/sbin/cephadm shell -- ceph orch host add ceph3 192.168.100.13
sudo /usr/local/sbin/cephadm shell -- ceph orch host ls
The hostnames passed to ceph orch host add match the output of hostname on each VM.
Add the other OSDs
Each additional object storage daemon (OSD) provides a storage location for another copy of the pool’s data. Confirm that each new data disk is available:
sudo /usr/local/sbin/cephadm shell -- ceph orch device ls --hostname ceph2 --wide --refresh
sudo /usr/local/sbin/cephadm shell -- ceph orch device ls --hostname ceph3 --wide --refresh
After you confirm /dev/vdb is the intended empty disk on both nodes, create the OSDs:
sudo /usr/local/sbin/cephadm shell -- ceph orch daemon add osd ceph2:/dev/vdb
sudo /usr/local/sbin/cephadm shell -- ceph orch daemon add osd ceph3:/dev/vdb
Wait until all three OSDs are up and in:
sudo /usr/local/sbin/cephadm shell -- ceph osd tree
The tree should show one OSD beneath each of ceph1, ceph2, and ceph3. A container reporting running doesn’t prove the OSD is up. Wait for the OSD tree and cluster status to agree before increasing replication.
Place monitors on all three nodes
Monitors maintain the cluster maps and use a majority to agree on cluster state. Deploy a monitor on each node:
sudo /usr/local/sbin/cephadm shell -- ceph orch apply mon --placement="ceph1,ceph2,ceph3"
sudo /usr/local/sbin/cephadm shell -- ceph orch ps --daemon-type mon
Run sudo /usr/local/sbin/cephadm shell -- ceph -s and wait until quorum includes all three hosts. An odd number of monitors allows a majority to form if one monitor becomes unavailable.
Increase the pool replication
Confirm that the pool uses a replicated CRUSH rule with host as its failure domain:
sudo /usr/local/sbin/cephadm shell -- ceph osd pool get agi-rbd crush_rule
sudo /usr/local/sbin/cephadm shell -- ceph osd crush rule dump replicated_rule
In the rule output, find the step containing chooseleaf and confirm that its type is host. If your pool uses a differently named rule, substitute that rule name in the second command.
Set size to 3 to keep a copy on each virtual host, and min_size to 2:
sudo /usr/local/sbin/cephadm shell -- ceph osd pool set agi-rbd size 3
sudo /usr/local/sbin/cephadm shell -- ceph osd pool set agi-rbd min_size 2
watch sudo /usr/local/sbin/cephadm shell -- ceph -s
These values ensure that I/O can continue during a single-OSD outage.
Ceph copies existing pool data to the new OSDs through backfill.
Stop watch with Ctrl+C after all placement groups return to active+clean. The new replica count is then satisfied.
Confirm that the file remains available:
sudo cat /mnt/ceph-rbd/hello.txt
The expected output is:
        Ceph RBD on aarch64
You’ve expanded the cluster to three virtual hosts and changed the RBD pool to three host-level replicas.
Next, you’ll stop one OSD and observe degraded operation and recovery.
