Use Ceph storage from Linux
You’ll create a RADOS Block Device (RBD) image, map it as a block device, and mount a filesystem on it to store a test file. Run all commands inside ceph1, which acts as both a storage node and an RBD client. A checksum check after remapping will verify that the file persists in Ceph.
Create the storage pool
A pool groups the objects that store your RBD image and controls how many copies Ceph keeps. Start with one copy because only one object storage daemon (OSD) is available. Cluster administration uses cephadm shell. RBD mapping uses the pinned container tools to configure a kernel block device for the VM.
Create the pool:
sudo /usr/local/sbin/cephadm shell -- ceph osd pool create agi-rbd 8
sudo /usr/local/sbin/cephadm shell -- ceph config get mon mon_allow_pool_size_one
By default, Ceph prevents setting a pool size to 1 to protect against data loss. Temporarily enable single-replica pools, set the size to 1, and immediately restore the safety check:
sudo /usr/local/sbin/cephadm shell -- ceph config set mon mon_allow_pool_size_one true
sudo /usr/local/sbin/cephadm shell -- ceph osd pool set agi-rbd size 1 --yes-i-really-mean-it
sudo /usr/local/sbin/cephadm shell -- ceph config set mon mon_allow_pool_size_one false
The size of the pool is the desired number of copies, and min_size is the minimum required to serve I/O. Set that minimum to 1 for this single-OSD stage, then initialize the pool for RBD:
sudo /usr/local/sbin/cephadm shell -- ceph osd pool set agi-rbd min_size 1
sudo /usr/local/sbin/cephadm shell -- rbd pool init agi-rbd
sudo /usr/local/sbin/cephadm shell -- ceph osd pool get agi-rbd size
sudo /usr/local/sbin/cephadm shell -- ceph osd pool get agi-rbd min_size
sudo /usr/local/sbin/cephadm shell -- ceph pg ls-by-pool agi-rbd
Confirm that size and min_size are 1 and all placement groups for agi-rbd show active+clean. This means they can serve I/O and have the copies required by the pool settings.
Warning
A single-replica pool can lose all of its data if its OSD or backing disk fails. Use it only for this learning stage. You’ll change the pool to three replicas after adding the other nodes.
Create a new 1 GiB image:
sudo /usr/local/sbin/cephadm shell -- rbd create --size 1024 agi-rbd/demo-volume
sudo /usr/local/sbin/cephadm shell -- rbd info agi-rbd/demo-volume
Create a pool-restricted client
Generate a minimal configuration and an aes256k credential for client.agirbd. The credential grants access to the agi-rbd pool. Run each block individually in the same SSH session on ceph1, checking its result before continuing.
Prepare a private directory for the generated files:
umask 077
CLIENT_DIRECTORY="$HOME/agi-rbd-client"
mkdir -p "$CLIENT_DIRECTORY"
Generate the configuration with a bounded wait:
sudo timeout --kill-after=5s 30s \
  /usr/local/sbin/cephadm shell -- ceph config generate-minimal-conf \
  </dev/null > "$CLIENT_DIRECTORY/ceph.conf.new"
echo "Configuration exit status: $?"
Continue only if the exit status is 0. Then, create or retrieve the pool-restricted credential:
  /usr/local/sbin/cephadm shell -- ceph auth get-or-create \
  --key-type=aes256k client.agirbd \
  mon 'profile rbd' \
  osd 'profile rbd pool=agi-rbd' \
  mgr 'profile rbd pool=agi-rbd' \
  </dev/null > "$CLIENT_DIRECTORY/ceph.client.agirbd.keyring.new"
echo "Credential exit status: $?"
After generating the configuration and credential files, verify that both commands completed successfully and install them to the system directory:
test -s "$CLIENT_DIRECTORY/ceph.conf.new" &&
test -s "$CLIENT_DIRECTORY/ceph.client.agirbd.keyring.new" &&
sudo install -d -m 700 /etc/ceph/rbd-client &&
sudo install -m 644 "$CLIENT_DIRECTORY/ceph.conf.new" \
  /etc/ceph/rbd-client/ceph.conf &&
sudo install -m 600 "$CLIENT_DIRECTORY/ceph.client.agirbd.keyring.new" \
  /etc/ceph/rbd-client/ceph.client.agirbd.keyring &&
echo "Client files installed successfully"
Continue when the success message appears. The .new files keep command output separate from the installed files until generation succeeds.
Define the RBD mapping command
Mapping exposes the RBD image as a device such as /dev/rbd0 inside ceph1.
Save a script that runs the matching Ceph tools in a container, so that you can reload it after reconnecting by SSH:
cat > "$HOME/agi-rbd-tools.sh" <<'TOOLS'
CEPH_IMAGE='quay.io/ceph/ceph@sha256:ff836bb28e7d0be0ec4dd22e79407174452a96e11ee62e9cdd1fa47f4bcc3bdc'
rbd_kernel() {
  sudo podman run --rm --privileged --network host \
    --volume /etc/ceph/rbd-client:/etc/ceph:ro \
    --volume /dev:/dev \
    --volume /sys:/sys \
    --volume /lib/modules:/lib/modules:ro \
    --entrypoint /usr/bin/rbd \
    "$CEPH_IMAGE" --id agirbd "$@"
TOOLS
source "$HOME/agi-rbd-tools.sh"
sudo modprobe rbd
rbd_kernel info agi-rbd/demo-volume
rbd_kernel device list
The privileged container needs access to the devices and sysfs of the VM to configure kernel mappings. The Ceph credential restricts cluster access to the pool but doesn’t restrict the privileges of the container within the VM.
Map the RBD image to a kernel block device:
rbd_kernel device map agi-rbd/demo-volume
Set RBD_DEVICE to the returned path:
RBD_DEVICE=/dev/rbd0
sudo lsblk -o NAME,SIZE,TYPE,FSTYPE,MOUNTPOINTS "$RBD_DEVICE"
sudo blockdev --getsize64 "$RBD_DEVICE"
Confirm that the device list associates this path with agi-rbd/demo-volume. Ensure that the block size is 1 GiB (1073741824 bytes), and that it has no filesystem or mount point.
Allow RBD inspection if AppArmor blocks lsblk
If lsblk returns Permission denied, verify whether AppArmor blocked access to the RBD sysfs path:
sudo dmesg --color=never | grep -Ei 'apparmor|denied|rbd|ceph' | tail -n 30
sudo grep -n 'local/' /etc/apparmor.d/lsblk
If AppArmor denied lsblk access to /sys/devices/rbd/, add a read rule to the local profile override and reload AppArmor:
sudo mkdir -p /etc/apparmor.d/local
sudo tee -a /etc/apparmor.d/local/lsblk >/dev/null <<'EOF_APPARMOR'
# Allow lsblk to inspect kernel-mapped Ceph RBD devices.
/sys/devices/rbd/ r,
/sys/devices/rbd/** r,
EOF_APPARMOR
sudo apparmor_parser -r -T /etc/apparmor.d/lsblk
When lsblk displays the device details without permission errors, you’re ready to format the volume.
Format and verify persistent data
Create a filesystem on the new image so that Linux can store files on it. After confirming the image identity, size, and absence of a filesystem, format it once. Then, mount the filesystem and record the checksum of a test file for later comparisons:
sudo mkfs.ext4 "$RBD_DEVICE"
sudo mkdir -p /mnt/ceph-rbd
sudo mount "$RBD_DEVICE" /mnt/ceph-rbd
echo "Ceph RBD on $(uname -m)" | sudo tee /mnt/ceph-rbd/hello.txt
sudo sync -f /mnt/ceph-rbd/hello.txt
sudo sha256sum /mnt/ceph-rbd/hello.txt | tee "$HOME/agi-rbd-baseline.sha256"
Run checksum reads with sudo so that they can access files on the mounted volume. The unprivileged tee saves the baseline in your home directory.
Unmount and unmap the image, then map it again:
cd "$HOME"
sudo umount /mnt/ceph-rbd
rbd_kernel device unmap "$RBD_DEVICE"
Update RBD_DEVICE if the new mapping returned a different path. Mount the existing filesystem without formatting it again:
sudo sha256sum -c "$HOME/agi-rbd-baseline.sha256"
The expected output is:
        /mnt/ceph-rbd/hello.txt: OK
Keep the volume mounted.
If you disconnect or start a new SSH session on ceph1, reload the helper functions and check the device path:
You’ve created an RBD image, mapped it through the Ubuntu 26.04 guest kernel, and verified persistent data.
Next, you’ll add two Ceph hosts and change the pool from one replica to three.
