Build the VM environment
You’ll create three Ubuntu 26.04 virtual machines (VMs) with stable IP addresses, SSH access, and a separate data disk for Ceph. Run the commands on the physical AGI host. By the end, you’ll be able to connect to each VM and confirm that its initial setup has completed.
Check the AGI host
The example uses kernel-based VM (KVM) and libvirt to create the VMs. Ensure that the AGI CPU host runs Ubuntu 24.04 and has the following attributes:
  • At least 12 available CPU cores
  • At least 12 GB of memory available to the VMs, with 16 GB or more of total host memory recommended
  • At least 90 GB of available storage
  • Hardware virtualization support through KVM
  • Root or sudo access
The virtual disks use the QCOW2 format and grow as data is written. However, the host needs to have enough capacity for the disks to reach their configured sizes.
Confirm that the host uses the Arm architecture:
uname -m
On an Arm-based host, the command prints aarch64.
Install the virtualization tools
Install KVM, virtualization packages, the Arm64 UEFI firmware, and the cloud-image tools:
sudo apt update
sudo apt install -y \
  qemu-kvm \
  qemu-efi-aarch64 \
  libvirt-daemon-system \
  libvirt-clients \
  libvirt-daemon-config-network \
  virtinst \
  cloud-image-utils \
  curl
Start the libvirt daemon and configure it to start when the host boots:
sudo systemctl enable --now libvirtd
Check whether QEMU can use KVM on the host:
sudo virt-host-validate qemu
The expected output is:
          QEMU: Checking if device /dev/kvm exists                                   : PASS
  QEMU: Checking if device /dev/kvm is accessible                            : PASS
  QEMU: Checking if device /dev/vhost-net exists                             : PASS
  QEMU: Checking if device /dev/net/tun exists                               : PASS
  QEMU: Checking for cgroup 'cpu' controller support                         : PASS
  QEMU: Checking for cgroup 'cpuacct' controller support                     : PASS
  QEMU: Checking for cgroup 'cpuset' controller support                      : PASS
  QEMU: Checking for cgroup 'memory' controller support                      : PASS
  QEMU: Checking for cgroup 'devices' controller support                     : PASS
  QEMU: Checking for cgroup 'blkio' controller support                       : PASS
  QEMU: Checking for device assignment IOMMU support                         : PASS
  QEMU: Checking if IOMMU is enabled by kernel                               : PASS
  QEMU: Checking for secure guest support                                    : WARN (Unknown if this platform has Secure Guest support)
Ignore warnings for features that you won’t use, such as secure guests.
Create the shared virtual network
Create a libvirt NAT network named agi-net. The network gives the VMs outbound access and lets them communicate with one another. It also assigns a fixed private address to each VM:
Virtual machineMAC addressIP address
ceph152:54:00:ce:00:01192.168.100.11
ceph252:54:00:ce:00:02192.168.100.12
ceph352:54:00:ce:00:03192.168.100.13
If the AGI host already uses the 192.168.100.0/24 subnet, select an unused private subnet and update the addresses.
Check for an existing route on the AGI host:
ip -4 route show 192.168.100.0/24
If the command returns nothing, there’s no matching route currently configured on the AGI host.
Create the network definition:
cat >/tmp/agi-net.xml <<'EOF'
<network>
  <name>agi-net</name>
  <forward mode="nat"/>
  <ip address="192.168.100.1" prefix="24">
    <dhcp>
      <range start="192.168.100.100" end="192.168.100.200"/>
      <host mac="52:54:00:ce:00:01" name="ceph1" ip="192.168.100.11"/>
      <host mac="52:54:00:ce:00:02" name="ceph2" ip="192.168.100.12"/>
      <host mac="52:54:00:ce:00:03" name="ceph3" ip="192.168.100.13"/>
    </dhcp>
  </ip>
</network>
EOF
Define, start, and enable the network:
sudo virsh net-define /tmp/agi-net.xml
sudo virsh net-start agi-net
sudo virsh net-autostart agi-net
        Network agi-net defined from /tmp/agi-net.xml
Network agi-net started
Network agi-net marked as autostarted
Confirm that agi-net is active:
sudo virsh net-list
        Name      State    Autostart   Persistent
 agi-net   active   yes         yes
 default   active   yes         yes
Create an SSH key for the VMs
Create a dedicated SSH key on the AGI host. The command preserves the key if it already exists:
if [ ! -f "${HOME}/.ssh/agi_ceph" ]; then
  ssh-keygen -t ed25519 -f "${HOME}/.ssh/agi_ceph" -N ""
fi
Cloud-init adds the public key to each VM. You’ll use the matching private key to connect as the ubuntu user.
No password is set for ubuntu, so use SSH key authentication rather than a password to access each VM.
Download the Ubuntu Arm64 cloud image
Create a directory for the VM images and download the Ubuntu 26.04 Arm64 release cloud image:
VM_DIRECTORY=/var/lib/libvirt/images/agi-ceph
BASE_IMAGE="${VM_DIRECTORY}/ubuntu-26.04-arm64-base.img"
sudo mkdir -p "$VM_DIRECTORY"
sudo curl --fail --location \
  https://cloud-images.ubuntu.com/releases/resolute/release/ubuntu-26.04-server-cloudimg-arm64.img \
  --output "$BASE_IMAGE"
The release URL might change as Ubuntu publishes updates. The tested guest image reported Ubuntu 26.04.1 and kernel 7.0.0-34-generic.
The base image remains unchanged. Each VM uses a separate copy-on-write operating system disk backed by this image.
Create and start the VMs
You’ll run a loop to create VMs named ceph1, ceph2, and ceph3.
Each VM receives the following resources:
  • Four virtual CPUs
  • 4 GB of memory
  • A 20 GB operating-system disk
  • A separate empty 10 GB data disk
  • An interface on agi-net
Use --cpu host-passthrough to expose the host CPU to the Arm64 KVM guests.
Each VM also receives a persistent NoCloud seed ISO containing its hostname, SSH public key, and network configuration. The network configuration enables IPv4 DHCP on the interface matching the MAC address of the VM. The DHCP reservation in agi-net supplies the fixed IP address.
Run the loop on the AGI host for the initial VM creation. It checks that the VM disk and seed files don’t already exist before creating them:
set -e
SSH_PUBLIC_KEY="$(cat "${HOME}/.ssh/agi_ceph.pub")"
SEED_DIRECTORY=$(mktemp -d)
for VM_NUMBER in 1 2 3; do
  VM_NAME="ceph${VM_NUMBER}"
  VM_MAC="52:54:00:ce:00:0${VM_NUMBER}"
  OS_DISK="${VM_DIRECTORY}/${VM_NAME}-os.qcow2"
  DATA_DISK="${VM_DIRECTORY}/${VM_NAME}-data.qcow2"
  USER_DATA="${SEED_DIRECTORY}/${VM_NAME}-user-data.yaml"
  META_DATA="${SEED_DIRECTORY}/${VM_NAME}-meta-data.yaml"
  NETWORK_CONFIG="${SEED_DIRECTORY}/${VM_NAME}-network-config.yaml"
  SEED_IMAGE="${VM_DIRECTORY}/${VM_NAME}-seed.iso"
  test ! -e "$OS_DISK"
  test ! -e "$DATA_DISK"
  test ! -e "$SEED_IMAGE"
  sudo qemu-img create \
    -f qcow2 \
    -F qcow2 \
    -b "$BASE_IMAGE" \
    "$OS_DISK" \
    20G
    -f qcow2 \
    "$DATA_DISK" \
    10G
  cat >"$USER_DATA" <<EOF
#cloud-config
hostname: ${VM_NAME}
manage_etc_hosts: true
ssh_pwauth: false
users:
  - name: ubuntu
    groups:
      - adm
      - sudo
    shell: /bin/bash
    sudo: ALL=(ALL) NOPASSWD:ALL
    lock_passwd: true
    ssh_authorized_keys:
      - ${SSH_PUBLIC_KEY}
EOF
  cat >"$META_DATA" <<EOF
instance-id: ${VM_NAME}
local-hostname: ${VM_NAME}
EOF
  cat >"$NETWORK_CONFIG" <<EOF
version: 2
ethernets:
  cephnic:
    match:
      macaddress: "${VM_MAC}"
    dhcp4: true
EOF
  sudo cloud-localds \
    --network-config="$NETWORK_CONFIG" \
    "$SEED_IMAGE" \
    "$USER_DATA" \
    "$META_DATA"
  sudo virt-install \
    --connect qemu:///system \
    --name "$VM_NAME" \
    --virt-type kvm \
    --arch aarch64 \
    --machine virt \
    --cpu host-passthrough \
    --vcpus 4 \
    --memory 4096 \
    --import \
    --osinfo generic \
    --boot uefi \
    --disk "path=${OS_DISK},format=qcow2,bus=virtio" \
    --disk "path=${DATA_DISK},format=qcow2,bus=virtio" \
    --disk "path=${SEED_IMAGE},device=cdrom,format=raw" \
    --network "network=agi-net,model=virtio,mac=${VM_MAC}" \
    --graphics none \
    --noautoconsole
  rm -f "$USER_DATA" "$META_DATA" "$NETWORK_CONFIG"
done
rmdir "$SEED_DIRECTORY"
The first boot can take a few minutes while cloud-init configures each VM. Keep the seed ISOs attached so that they remain available on subsequent boots.
Verify access to the VMs
Confirm that all three VMs are running:
sudo virsh list --all
The output is similar to:
         Id   Name    State
 1    ceph1   running
 2    ceph2   running
 3    ceph3   running
If a VM is listed as shut off, start that existing VM with sudo virsh start ceph1, replacing ceph1 with its name.
Check that libvirt assigned 192.168.100.11, 192.168.100.12, and 192.168.100.13 to the three VMs:
sudo virsh net-dhcp-leases agi-net
        Expiry Time           MAC address         Protocol   IP address          Hostname   Client ID or DUID
 2026-10-07 15:03:31   52:54:00:ce:00:01   ipv4       192.168.100.11/24   ceph1      ff:cb:39:0a:c7:00:02:00:00:ab:11:11:3d:ef:1d:a1:60:28:a1
 2026-10-07 15:05:06   52:54:00:ce:00:02   ipv4       192.168.100.12/24   ceph2      ff:cb:39:0a:c7:00:02:00:00:ab:11:fe:6b:dd:98:1d:91:16:4b
 2026-10-07 14:58:52   52:54:00:ce:00:03   ipv4       192.168.100.13/24   ceph3      ff:cb:39:0a:c7:00:02:00:00:ab:11:bb:14:a0:3e:17:e0:f4:e8
If the lease list is empty immediately after boot, wait for a few minutes and check again. If a lease remains missing, run sudo virsh domblklist ceph1 --details for the affected VM and confirm that its seed ISO is attached to the CD-ROM. Use sudo virsh console ceph1 to inspect boot and cloud-init messages. To leave the console, press Ctrl+].
After the leases appear, connect to each VM and display its hostname, architecture, and cloud-init status:
  VM_IP="192.168.100.$((10 + VM_NUMBER))"
  echo "Checking ceph${VM_NUMBER} (${VM_IP})"
  ssh -o ConnectTimeout=10 \
    -o ConnectionAttempts=1 \
    -o ServerAliveInterval=10 \
    -o ServerAliveCountMax=2 \
    -i "${HOME}/.ssh/agi_ceph" "ubuntu@${VM_IP}" \
    'hostname; uname -m; cloud-init status --long'
done
Accept each SSH host key when prompted. Each connection should report the corresponding hostname, ceph1, ceph2, or ceph3, followed by aarch64. Before continuing, confirm that cloud-init reports status: done with no errors. Its datasource should be DataSourceNoCloud using the attached seed media. If SSH reports Connection refused, wait for cloud-init to finish and try again.
You’ve created three Ubuntu 26.04 VMs with fixed private addresses and separate empty data disks.
Next, you’ll validate their resources, networking, time synchronization, and storage before installing Ceph.
