What Ceph RBD is
Ceph is a distributed storage system that keeps multiple copies of your data across independent nodes. RADOS Block Device (RBD) exposes Ceph storage as a virtual block device, a volume that behaves like a local disk.
Ceph splits the volume into objects and spreads them across the cluster, but to Linux it looks like an ordinary device at a path such as /dev/rbd0. You can format the device with a filesystem, mount it, and read and write files normally, while Ceph handles replication and distribution across the nodes.
Understand the Ceph deployment
You’ll build a Ceph cluster on an Arm AGI CPU host, use it as a Linux block device, and watch it protect your data when a node’s storage daemon goes down. You’ll begin with one node to learn the core concepts, then expand to a three-node replicated cluster.
The nodes are three Ubuntu 26.04 virtual machines (VMs) on an Arm AGI CPU host running Ubuntu 24.04. The VMs run Ceph Squid 19.2.6. The tested guest image uses Ubuntu 26.04.1 with kernel 7.0.0-34-generic. Cluster commands and RBD mapping use the pinned Ceph container image, and cluster setup uses standalone cephadm 19.2.6.
Start with one node
A production deployment normally spreads services and data across independent physical hosts. You’ll start with one VM so that you can learn the main Ceph concepts before adding cluster membership and data replication.
The first stage configures the following components on a VM named ceph1:
  • A monitor (MON), which maintains the cluster map and membership
  • A manager (MGR), which provides management and monitoring functions
  • An object storage daemon (OSD), which stores data on an unused disk
  • An RBD client, which maps the example image as a Linux block device
The initial configuration sets the example pool to one replica. A single replica provides no redundancy, but it lets the pool become usable with one OSD.
Expand the cluster
You’ll then add VMs named ceph2 and ceph3, including one OSD on each node. The following is the completed topology:
Virtual machineCeph servicesData disk
ceph1MON, MGR, OSD, RBD client/dev/vdb
ceph2MON, OSD/dev/vdb
ceph3MON, OSD/dev/vdb
After all three OSDs are available, you’ll increase the RBD pool size to three, so that Ceph keeps three copies of the pool data. Ceph uses Controlled Replication Under Scalable Hashing (CRUSH) to decide which OSDs store those copies.
A CRUSH rule defines how to spread copies across the cluster. Its failure domain identifies the boundary that copies need to be separated across, such as a host or a rack. The boundary used in this example is host, so each copy goes to an OSD on a different VM: ceph1, ceph2, or ceph3. If one VM becomes unavailable, the other two still hold copies of the data.
Note
All three VMs run on one physical AGI CPU host. This topology demonstrates Ceph node membership, replication, and OSD recovery, but it doesn’t tolerate failure of the physical host. Use independent physical hosts, failure domains, networks, and power sources when designing a production cluster.
You now understand the services that each node runs to build a distributed storage system across multiple nodes.
Next, you’ll create the three VMs on the AGI CPU host.
