Now that your Veraison services are deployed into AWS and initialized with endorsements for the CCA reference platform, you are ready to make use of the verification service to verify a CCA attestation token.
To do this, you should follow the steps set out in the Learning Path Get Started with CCA Attestation and Veraison . Follow the steps in this Learning Path exactly, except you’ll use your AWS-hosted Veraison deployment instead of Linaro’s service.
The URL for the Veraison server provided by Linaro is https://veraison.test.linaro.org:8443.
Instead of this URL, use the one for your own Veraison service, which will be of the form https://services.example-veraison.com:8443, although you need to replace example-veraison.com with your AWS domain.
Apart from this URL change, all other steps in the Learning Path remain the same.
