Prepare your AWS account
You’ll need an active AWS account for this Learning Path. If you don’t have one yet, refer to the AWS documentation .
Note
This Learning Path assumes that you have administrator-level privileges for your AWS account.
Install AWS command-line tools
You’ll need the AWS Command-Line Interface (CLI) installed for this section. Follow the AWS documentation to install the latest version.
Set up authentication
You’ll need to set up your local environment to authenticate with AWS before deploying Veraison.
The recommended method is Single Sign-On (SSO). Follow the steps in Veraison’s AWS account documentation .
To confirm authentication is configured correctly, run a simple command, such as:
aws ec2 describe-availability-zones
You should see output similar to the following (depending on which AWS region you are using):
    "AvailabilityZones": [
            "OptInStatus": "opt-in-not-required",
            "Messages": [],
            "RegionName": "eu-west-1",
            "ZoneName": "eu-west-1a",
            "ZoneId": "euw1-az1",
            "GroupName": "eu-west-1-zg-1",
            "NetworkBorderGroup": "eu-west-1",
            "ZoneType": "availability-zone",
            "State": "available"
            "Messages": [],
            "ZoneName": "eu-west-1b",
            "ZoneId": "euw1-az2",
            "Messages": [],
            "ZoneName": "eu-west-1c",
            "ZoneId": "euw1-az3",
If this operation fails, pause here and troubleshoot using the AWS documentation before continuing.
