# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/cca-trustee/)
- [Architecture overview for Arm CCA Attestation with Trustee](https://learn.arm.com/learning-paths/servers-and-cloud-computing/cca-trustee/cca-trustee/)
- [Run an end-to-end Attestation with Arm CCA and Trustee](https://learn.arm.com/learning-paths/servers-and-cloud-computing/cca-trustee/flow/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/cca-trustee/_next-steps/)
## Explore related resources
- [Arm Confidential Compute Architecture](https://www.arm.com/architecture/security-features/arm-confidential-compute-architecture)
- [Arm Confidential Compute Architecture open-source enablement](https://www.youtube.com/watch?v=JXrNkYysuXw)
- [Learn the architecture - Realm Management Extension](https://developer.arm.com/documentation/den0126)
- [Realm Management Monitor specification](https://developer.arm.com/documentation/den0137/latest/)
- [The Role of Attestation in Arm CCA](https://support.arm.com/documentation/111146/latest/)
## Review frequently asked questions
**What result should I expect from the first secret request?**
The initial request is expected to fail. The attestation policy blocks secret release until the realm initial measurement (RIM) is endorsed.
**How do I know the Trustee services are running correctly before launching the realm?**
Check the Docker container status and logs for the Trustee services. They should start without errors and be ready to accept requests.
**When should I endorse the RIM, and how do I confirm it worked?**
Endorse the RIM after the first secret request is denied. After endorsement, re-run attestation and expect the secret request to succeed.
**How can I verify that the realm generated attestation evidence?**
The realm run produces evidence that the Attestation Service (AS) processes. Check the output and logs for evidence generation and a corresponding response from the AS.
**How do I know the FVP realm is ready before requesting a secret?**
The Linux realm should complete boot on the FVP and be able to produce attestation evidence. If evidence generation fails, resolve that before proceeding to secret requests.
