What you've learned
You should now know how to:
  • Describe how you can use attestation with Arm's Confidential Computing Architecture (CCA).
  • Deploy a simple workload in a CCA realm on an Armv9-A AEM Base Fixed Virtual Platform (FVP) that has support for RME extensions.
  • Connect the workload with additional software services to create an end-to-end example that uses attestation to unlock the confidential processing of data.
Knowledge Check
The Arm Confidential Compute Architecture (CCA) is available on all Arm devices.
kvmtool supports the creation of Realm guests.
An application running in the Realm inherits its confidential protection.
