Give feedback
AI-assisted
Close
How do I know that bounce buffers are being used in the Realm?
Use kernel tracing during the exercise to observe activity indicating SWIOTLB usage while the Key Broker demo generates network I/O through VirtIO. Seeing trace output associated with SWIOTLB during traffic confirms that data is bouncing through DMA-capable buffers.
What should I expect after starting the Key Broker container image?
The container runs a pre-built Key Broker demo used in the exercise. After it starts, list network interfaces to confirm connectivity before proceeding to kernel tracing.
When is VirtIO the right choice versus secure physical device attach?
VirtIO is the first level of device attach, mediated by the hypervisor with paravirtualized drivers, and is sufficient for many Realm I/O needs. Secure physical device attach using PCIe‑TDISP and PCIe‑IDE applies when hardware-backed isolation and attestation for the device are required.
Why do Realms rely on SWIOTLB bounce buffers for I/O?
Bounce buffers are used when a device cannot DMA to the original buffer, including when memory is not accessible to the device or does not meet alignment or contiguity constraints. In Realms, SWIOTLB enables data transfer between Realm-protected memory and devices during VirtIO I/O.
Will I learn to perform attestation of a physically attached device?
You’ll learn how PCIe‑TDISP and PCIe‑IDE support secure physical device attach and attestation. The hands-on exercise focuses on VirtIO and observing SWIOTLB behavior, not on performing a physical device attestation workflow.
