Before you begin
Download the armswdev/cca-learning-path:cca-simulation-v3 docker container.
Running an application in a Realm
In the previous section, you were able to boot a guest virtual machine as the Realm. In this section, you will learn how to run your own application within that Realm. The application inherits the confidential protection of the guest virtual machine it is running in.
A convenient way to run an application inside a Realm, within the context of this example, is to inject the application into the guest filesystem. In this section, you will inject a simple hello world program into the guest filesystem.
Inject a simple application in the guest filesystem
Compile the application
Create a directory in which you will build the simple hello world application:
mkdir ~/CCA-docker-share
cd ~/CCA-docker-share
Using a file editor of your choice, create a file named hello.c in this directory. Copy the contents below into the file:
#include <stdio.h>
#include <stdlib.h>
int main(int argc, char *argv[])
  printf("\n******* Hello from the Realm ! *******\n\n");
  return EXIT_SUCCESS;
Now start the container:
docker run -v ~/CCA-docker-share:/home/cca/CCA-docker-share --rm --privileged -it armswdev/cca-learning-path:cca-simulation-v3
Note
The docker session is started with the --rm option, which means the container will be destroyed when it is exited, allowing you to experiment with the images without fear: at the next session, you will get working pristine images ! If you intend your changes to persist across docker sessions, omit the --rm option to docker.
The --privileged option is needed to be able to mount the host and guest filesystems inside the container.
The ~/CCA-docker-share directory on your development machine is available within the container at /home/cca/CCA-docker-share thanks to the -v ~/CCA-docker-share:/home/cca/CCA-docker-share command line option to docker run.
Inside the running container, compile the hello world application, the source code file hello.c should be present in the shared directory /home/cca/CCA-docker-share :
        ls CCA-docker-share/
__output__hello.c
aarch64-linux-gnu-gcc -O1 -static -o hello CCA-docker-share/hello.c
You now have a hello statically linked binary for the hello world application inside /home/cca/:
        ls
__output__CCA-docker-share  FastRAM.cfg  cca-3world  hello  run-cca-fvp.sh
Inject the application into the guest filesystem.
While still in the docker container, mount the host filesystem, then the guest filesystem (which lives inside the host filesystem), then copy the hello binary file to the guest filesystem and then unmount the guest and host filesystems:
sudo mkdir -p /mnt/host-fs /mnt/guest-fs
sudo mount -t auto -w -o loop cca-3world/host-rootfs.ext2 /mnt/host-fs
fs_start=$(fdisk -l /mnt/host-fs/cca/guest-disk.img |grep "Linux filesystem"| tr -s ' ' | cut -f2 -d" ")
sudo mount -t auto -w -o loop,offset=$(($fs_start*512)) /mnt/host-fs/cca/guest-disk.img /mnt/guest-fs
sudo cp hello /mnt/guest-fs/cca/
sudo umount /mnt/guest-fs
sudo umount /mnt/host-fs
Execute hello world in the realm
Now, as previously, start the CCA host in the FVP:
./run-cca-fvp.sh
udhcpc: started, v1.36.1
udhcpc: broadcasting discover
udhcpc: broadcasting select for 172.20.51.1, server 172.20.51.254
udhcpc: lease of 172.20.51.1 obtained from 172.20.51.254, lease time 86400
deleting routers
adding dns 172.20.51.254
OK
Starting chrony: OK
Starting crond: OK
Setting up macvtap... [   16.681271] smc91x 1a000000.ethernet eth0: entered promiscuous mode
OK
Welcome to the CCA host
host login:
Log into the CCA host, using root as the username (no password required), then start a realm with:
cd /cca
./lkvm run --realm --disable-sve --irqchip=gicv3-its --firmware KVMTOOL_EFI.fd -c 1 -m 512 --no-pvtime --force-pci --disk guest-disk.img --measurement-algo=sha256 --restricted_mem
udhcpc: broadcasting select for 192.168.33.15, server 192.168.33.1
udhcpc: lease of 192.168.33.15 obtained from 192.168.33.1, lease time 14400
deleting routers
FAIL
Starting chrony: OK
Starting crond: OK
Setting up macvtap... OK
Welcome to the CCA realm
realm login:
Log into the CCA realm, using root as the username (no password required).
Now change directory to /cca: the hello world application should be there as the binary file hello, just run it:
        cd /cca
ls
__output__arc         hello       kbs-client
./hello
You have successfully run your own application inside the Realm !
As before, with poweroff you can now exit the realm, then the host.
