Start by downloading the docker container image.
This docker image contains the pre-built binaries for the Arm CCA reference software stack and the Armv-A Base Architecture Envelope Model (AEM) FVP with support for RME extensions.
Install docker engine on your machine.
Pull the docker image from DockerHub:
docker pull armswdev/cca-learning-path:cca-simulation-v3
Confirm that the docker container image was downloaded successfully:
docker image list
The output should be similar to:
IMAGE ID DISK USAGE CONTENT SIZE EXTRA
armswdev/cca-learning-path:cca-simulation-v3 21500198bb93 1.18GB 0B
Run the docker container:
docker run --rm -it armswdev/cca-learning-path:cca-simulation-v3
You are now inside the home directory (/home/cca) of user cca in the running armswdev/cca-learning-path:cca-simulation-v3 container.
cca@a9866f863546:~$
The pre-built binaries for the Arm CCA reference software stack are present in the cca-3world/ directory.
ls cca-3world/
This includes the Realm Management Monitor (rmm.img), the host root filesystem (host-rootfs.ext2) and the host Linux kernel image (Image) and the trusted firmware binaries:
FVP_AARCH64_EFI.fd Image bl1.bin bl2.bin bl31.bin dt_bootargs.dtb fip.bin host-rootfs.ext2 kselftests.tgz modules.tgz rmm.img
These binaries can run on an Armv-A Base Architecture Envelope Model (AEM) FVP with support for RME extensions. AEM FVPs are fixed configuration virtual platforms of Armv8-A and Armv9-A architectures with comprehensive system IP. The FVP is also contained within this docker container.
Launch the run-cca-fvp.sh script to run the Arm CCA pre-built binaries on the FVP:
./run-cca-fvp.sh
A number of Info and Warning messages will be emitted by the FVP. These can safely be ignored.
The run-cca-fvp.sh script uses the screen command to connect to the different UARTs in the FVP.
You should see the host Linux kernel boot on your terminal:
udhcpc: started, v1.36.1
udhcpc: broadcasting discover
udhcpc: broadcasting select for 172.20.51.1, server 172.20.51.254
udhcpc: lease of 172.20.51.1 obtained from 172.20.51.254, lease time 86400
deleting routers
adding dns 172.20.51.254
OK
Starting chrony: OK
Starting crond: OK
Setting up macvtap... [ 16.681271] smc91x 1a000000.ethernet eth0: entered promiscuous mode
OK
Welcome to the CCA host
host login:
You will be prompted to log in to the CCA host. Enter root as the username (no password is required).
You have successfully booted 3 worlds (Root, Non-secure and Realm) on the FVP at this point:
Guest VMs can be launched in a Realm using kvmtool from your host Linux prompt. The realm disk image guest-disk.img is included into the host file system.
Use kvmtool to launch guest Linux in a Realm:
cd /cca
./lkvm run --realm --disable-sve --irqchip=gicv3-its --firmware KVMTOOL_EFI.fd -c 1 -m 512 --no-pvtime --force-pci --disk guest-disk.img --measurement-algo=sha256 --restricted_mem
You should see the guest Linux kernel starting to boot in a Realm. This step can take several minutes.
After boot up, you will be prompted to log in at the guest Linux prompt, use the root username (no password required):
udhcpc: broadcasting select for 192.168.33.15, server 192.168.33.1
udhcpc: lease of 192.168.33.15 obtained from 192.168.33.1, lease time 14400
deleting routers
FAIL
Starting chrony: OK
Starting crond: OK
Setting up macvtap... OK
Welcome to the CCA realm
realm login:
You have successfully created a virtual guest in a Realm using the Arm CCA reference software stack.
Attestation tokens are small reports that are produced by a device upon request. Those tokens are composed of key/value pairs called claims. A CCA attestation token is a collection of claims about the state of a Realm and the CCA platform on which the Realm is running.
Refer to section A7.2 of the Realm Management Monitor Specification to learn about the details of the CCA attestation token.
The retrieval of a CCA attestation token from a running guest is done by reading from /sys/kernel/config/tsm/report/. This is available when Linux’s configfs has been mounted, which has been done automatically as part of the guest boot process — if you are curious, this is the configfs /sys/kernel/config configfs defaults 0 0 line in /etc/fstab.
You can now generate an attestation token by running the following commands:
report=/sys/kernel/config/tsm/report/report0
mkdir $report
dd if=/dev/urandom bs=64 count=1 > $report/inblob
hexdump -C $report/outblob
The output should look like:
00000000 d9 01 8f a2 19 ac ca 59 05 ee d2 84 44 a1 01 38 |.......Y....D..8|
00000010 22 a0 59 05 81 a9 19 01 09 78 23 74 61 67 3a 61 |".Y......x#tag:a|
00000020 72 6d 2e 63 6f 6d 2c 32 30 32 33 3a 63 63 61 5f |rm.com,2023:cca_|
00000030 70 6c 61 74 66 6f 72 6d 23 31 2e 30 2e 30 0a 58 |platform#1.0.0.X|
00000040 20 0d 22 e0 8a 98 46 90 58 48 63 18 28 34 89 bd | ."...F.XHc.(4..|
00000050 b3 6f 09 db ef eb 18 64 df 43 3f a6 e5 4e a2 d7 |.o.....d.C?..N..|
00000060 11 19 09 5c 58 20 7f 45 4c 46 02 01 01 00 00 00 |...\X .ELF......|
00000070 00 00 00 00 00 00 03 00 3e 00 01 00 00 00 50 58 |........>.....PX|
00000080 00 00 00 00 00 00 19 01 00 58 21 01 07 06 05 04 |.........X!.....|
00000090 03 02 01 00 0f 0e 0d 0c 0b 0a 09 08 17 16 15 14 |................|
000000a0 13 12 11 10 1f 1e 1d 1c 1b 1a 19 18 19 09 61 44 |..............aD|
000000b0 cf cf cf cf 19 09 5b 19 30 03 19 09 62 67 73 68 |......[.0...bgsh|
000000c0 61 2d 32 35 36 19 09 60 78 3a 68 74 74 70 73 3a |a-256..`x:https:|
000000d0 2f 2f 76 65 72 61 69 73 6f 6e 2e 65 78 61 6d 70 |//veraison.examp|
000000e0 6c 65 2f 2e 77 65 6c 6c 2d 6b 6e 6f 77 6e 2f 76 |le/.well-known/v|
000000f0 65 72 61 69 73 6f 6e 2f 76 65 72 69 66 69 63 61 |eraison/verifica|
00000100 74 69 6f 6e 19 09 5f 8d a4 01 69 52 53 45 5f 42 |tion.._...iRSE_B|
00000110 4c 31 5f 32 05 58 20 53 78 79 63 07 53 5d f3 ec |L1_2.X Sxyc.S]..|
00000120 8d 8b 15 a2 e2 dc 56 41 41 9c 3d 30 60 cf e3 22 |......VAA.=0`.."|
00000130 38 c0 fa 97 3f 7a a3 02 58 20 9a 27 1f 2a 91 6b |8...?z..X .'.*.k|
00000140 0b 6e e6 ce cb 24 26 f0 b3 20 6e f0 74 57 8b e5 |.n...$&.. n.tW..|
00000150 5d 9b c9 4f 6f 3f e3 ab 86 aa 06 67 73 68 61 2d |]..Oo?.....gsha-|
00000160 32 35 36 a4 01 67 52 53 45 5f 42 4c 32 05 58 20 |256..gRSE_BL2.X |
00000170 53 78 79 63 07 53 5d f3 ec 8d 8b 15 a2 e2 dc 56 |Sxyc.S]........V|
00000800 88 cf 5b 66 ce b5 30 59 0a d4 81 79 3d e5 02 dc |..[f..0Y...y=...|
00000810 ac 70 bc dc b7 05 b2 cc 40 f1 b6 05 a5 52 57 04 |.p......@....RW.|
00000820 26 7a 24 c5 2e 88 6e a7 b6 18 59 2e 9f e8 58 8d |&z$...n...Y...X.|
00000830 a6 ea 0b 9b 18 90 62 62 07 f0 17 90 b4 27 04 e3 |......bb.....'..|
00000840 ec 89 dd 67 5f 6b 07 47 55 4d a9 7b c1 be d2 03 |...g_k.GUM.{....|
00000850 4f 5d d1 d0 55 d1 |O]..U.|
00000856
The output is a CCA attestation token from the guest in the Realm. The CCA attestation token is a Concise Binary Object Representation (CBOR) map, in which the map values are the Realm token and the CCA platform token.
You have successfully generated a CCA attestation token from the guest. In later learning paths, you will learn how to use these tokens as part of the Arm CCA attestation flow.
You can now shutdown the guest. Use the poweroff command.
You should see the following output from the guest:
(realm) # Destroying macvtap... OK
Stopping crond: stopped /usr/sbin/crond (pid 120) OK
Stopping chrony: OK
Stopping network: ifdown: interface lo not configured OK
Stopping klogd: OK
Stopping syslogd: stopped /sbin/syslogd (pid 66) OK
umount: devtmpfs busy - remounted read-only
[ 1172.990117] EXT4-fs (vda2): re-mounted b984c902-aed2-4217-bbf0-da44ee66446c ro.
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system poweroff
[ 1175.167522] reboot: Power down
Info: KVM session ended normally.
The guest has shut down and you are back at the host Linux kernel prompt.
To exit the host session and the simulation, use poweroff. You will be placed back into the running docker container.
To exit the docker container, run exit.
In the next section, you will learn how to run a simple application inside the Realm.
The docker session has been started with the --rm option, which means the container will be destroyed when it is exited, allowing you to experiment with the images without fear: at the next session, you will get working pristine images ! If you intend your changes to persist across docker sessions, omit the --rm option to docker.
