Benchmark Cassandra with cassandra-stress
You can perform Cassandra benchmarking using the built-in cassandra-stress tool, which measures database performance under different workloads such as write, read, and mixed operations.
Verify cassandra-stress installation
Cassandra comes with a built-in tool called cassandra-stress that is used for testing performance. It’s located in the tools/bin/ folder of your Cassandra installation.
ls ~/cassandra/tools/bin | grep cassandra-stress
If you see cassandra-stress in the list, the tool is installed and ready to use.
Check the tool’s help options to verify it works correctly:
~/cassandra/tools/bin/cassandra-stress help
The output is similar to:
        Usage:      cassandra-stress <command> [options]
Help usage: cassandra-stress help <command>
---Commands---
read                 : Multiple concurrent reads - the cluster must first be populated by a write test
write                : Multiple concurrent writes against the cluster
mixed                : Interleaving of any basic commands, with configurable ratio and distribution - the cluster must first be populated by a write test
counter_write        : Multiple concurrent updates of counters.
counter_read         : Multiple concurrent reads of counters. The cluster must first be populated by a counterwrite test.
user                 : Interleaving of user provided queries, with configurable ratio and distribution
help                 : Print help for a command or option
print                : Inspect the output of a distribution definition
version              : Print the version of cassandra stress
The list of commands and options confirms that your setup is correct and you’re ready to start testing Cassandra’s performance.
Run a basic write test
Insert 10,000 rows with 50 concurrent threads using cassandra-stress:
~/cassandra/tools/bin/cassandra-stress write n=10000 -rate threads=50
  • write → Performs only write operations on the Cassandra cluster.
  • n=10000 → Specifies the number of rows to insert during the benchmark test.
  • -rate threads=50 → Sets the number of concurrent worker threads simulating multiple clients writing to the cluster.
        ******************** Stress Settings ********************
Command:
  Type: write
  Count: 10,000
  No Warmup: false
  Consistency Level: LOCAL_ONE
  Target Uncertainty: not applicable
  Key Size (bytes): 10
  Counter Increment Distibution: add=fixed(1)
Rate:
  Auto: false
  Thread Count: 50
  OpsPer Sec: 0
Population:
  Sequence: 1..10000
  Order: ARBITRARY
  Wrap: true
Insert:
  Revisits: Uniform:  min=1,max=1000000
  Visits: Fixed:  key=1
  Row Population Ratio: Ratio: divisor=1.000000;delegate=Fixed:  key=1
  Batch Type: not batching
Columns:
  Max Columns Per Key: 5
  Column Names: [C0, C1, C2, C3, C4]
  Comparator: AsciiType
  Timestamp: null
  Variable Column Count: false
  Slice: false
  Size Distribution: Fixed:  key=34
  Count Distribution: Fixed:  key=5
Errors:
  Ignore: false
  Tries: 10
Log:
  No Summary: false
  No Settings: false
  File: null
  Interval Millis: 1000
  Level: NORMAL
Mode:
  API: JAVA_DRIVER_NATIVE
  Connection Style: CQL_PREPARED
  Protocol Version: V5
  Username: null
  Password: null
  Auth Provide Class: null
  Max Pending Per Connection: 128
  Connections Per Host: 8
  Compression: NONE
Node:
  Nodes: [localhost]
  Is White List: false
  Datacenter: null
Schema:
  Keyspace: keyspace1
  Replication Strategy: org.apache.cassandra.locator.SimpleStrategy
  Replication Strategy Options: {replication_factor=1}
  Table Compression: null
  Table Compaction Strategy: null
  Table Compaction Strategy Options: {}
Transport:
  Truststore: null
  Truststore Password: null
  Keystore: null
  Keystore Password: null
  SSL Protocol: TLS
  SSL Algorithm: null
  SSL Ciphers: TLS_RSA_WITH_AES_128_CBC_SHA,TLS_RSA_WITH_AES_256_CBC_SHA
Port:
  Native Port: 9042
  JMX Port: 7199
JMX:
  Username: null
  Password: *not set*
Graph:
  File: null
  Revision: unknown
  Title: null
  Operation: WRITE
TokenRange:
  Wrap: false
  Split Factor: 1
Credentials file:
  File: *not set*
  CQL username: *not set*
  CQL password: *not set*
  JMX username: *not set*
  JMX password: *not set*
  Transport truststore password: *not set*
  Transport keystore password: *not set*
Reporting:
  Output frequency: 1s
  Header frequency: *not set*
Connected to cluster: Test Cluster, max pending requests per connection 128, max connections per host 8
Datacenter: datacenter1; Host: localhost/127.0.0.1:9042; Rack: rack1
Created keyspaces. Sleeping 1s for propagation.
Sleeping 2s...
Warming up WRITE with 2500 iterations...
Running WRITE with 50 threads for 10000 iteration
type                                               total ops,    op/s,    pk/s,   row/s,    mean,     med,     .95,     .99,    .999,     max,   time,   stderr, errors,  gc: #,  max ms,  sum ms,  sdv ms,      mb
total,                                                 10000,   10690,   10690,   10690,     3.7,     2.8,     9.5,    16.7,    28.9,    38.4,    0.9,  0.00000,      0,      0,       0,       0,       0,       0
Results:
Op rate                   :   10,690 op/s  [WRITE: 10,690 op/s]
Partition rate            :   10,690 pk/s  [WRITE: 10,690 pk/s]
Row rate                  :   10,690 row/s [WRITE: 10,690 row/s]
Latency mean              :    3.7 ms [WRITE: 3.7 ms]
Latency median            :    2.8 ms [WRITE: 2.8 ms]
Latency 95th percentile   :    9.5 ms [WRITE: 9.5 ms]
Latency 99th percentile   :   16.7 ms [WRITE: 16.7 ms]
Latency 99.9th percentile :   28.9 ms [WRITE: 28.9 ms]
Latency max               :   38.4 ms [WRITE: 38.4 ms]
Total partitions          :     10,000 [WRITE: 10,000]
Total errors              :          0 [WRITE: 0]
Total GC count            : 0
Total GC memory           : 0 B
Total GC time             :    0.0 seconds
Avg GC time               :    NaN ms
StdDev GC time            :    0.0 ms
Total operation time      : 00:00:00
END
Run a read test
Run a read benchmark on your Cassandra database using cassandra-stress. This simulates multiple clients reading from the cluster at the same time and records performance metrics such as throughput and latency.
~/cassandra/tools/bin/cassandra-stress read n=10000 -rate threads=50
Command:
  Type: read
  Count: 10,000
  No Warmup: false
Rate:
  Auto: false
  Thread Count: 50
  OpsPer Sec: 0
Population:
  Distribution: Gaussian:  min=1,max=10000,mean=5000.500000,stdev=1666.500000
  Order: ARBITRARY
  Wrap: false
Insert:
Columns:
  Timestamp: null
  Slice: false
Errors:
  Ignore: false
  Tries: 10
Log:
  No Summary: false
  No Settings: false
  File: null
  Level: NORMAL
Mode:
  Username: null
  Password: null
  Compression: NONE
Node:
  Nodes: [localhost]
  Datacenter: null
Schema:
  Keyspace: keyspace1
Transport:
  Truststore: null
  Keystore: null
  SSL Protocol: TLS
  SSL Algorithm: null
Port:
  Native Port: 9042
  JMX Port: 7199
JMX:
  Username: null
  Password: *not set*
Graph:
  File: null
  Revision: unknown
  Title: null
  Operation: READ
TokenRange:
  Wrap: false
  Split Factor: 1
Credentials file:
  File: *not set*
Reporting:
Sleeping 2s...
Warming up READ with 2500 iterations...
Running READ with 50 threads for 10000 iteration
total,                                                  1540,    1540,    1540,    1540,     8.1,     6.2,    19.2,    38.4,    73.3,    80.9,    1.0,  0.00000,      0,      0,       0,       0,       0,       0
total,                                                  9935,    8395,    8395,    8395,     5.9,     4.2,    16.7,    33.1,    57.3,    86.0,    2.0,  0.48892,      0,      0,       0,       0,       0,       0
total,                                                 10000,    4217,    4217,    4217,     8.5,     4.2,    27.1,    27.4,    27.4,    27.4,    2.0,  1.89747,      0,      0,       0,       0,       0,       0
Results:
Op rate                   :    4,962 op/s  [READ: 4,962 op/s]
Partition rate            :    4,962 pk/s  [READ: 4,962 pk/s]
Row rate                  :    4,962 row/s [READ: 4,962 row/s]
Latency mean              :    6.3 ms [READ: 6.3 ms]
Latency median            :    4.5 ms [READ: 4.5 ms]
Latency 95th percentile   :   17.4 ms [READ: 17.4 ms]
Latency 99th percentile   :   33.4 ms [READ: 33.4 ms]
Latency 99.9th percentile :   59.6 ms [READ: 59.6 ms]
Latency max               :   86.0 ms [READ: 86.0 ms]
Total partitions          :     10,000 [READ: 10,000]
Total errors              :          0 [READ: 0]
Total GC count            : 0
Total operation time      : 00:00:02
END
Understand benchmark results
The metrics below explain what each value in the cassandra-stress output represents:
  • Op rate (operations per second): the number of read operations Cassandra successfully executed per second.
  • Partition rate: the number of partitions read per second. Since this is a read test, the partition rate equals the op rate.
  • Row rate: the number of rows read per second. Again, for this test it equals the op rate.
  • Latency mean: the average time taken for each read request to complete.
  • Latency median: the 50th percentile latency - half of the operations completed faster than this time.
  • Latency max: the slowest single read request during the test.
  • Total partitions: the total number of partitions read during the test.
  • Total errors: the number of failed read operations.
  • GC metrics (Garbage Collection): shows whether JVM garbage collection paused Cassandra during the test.
  • Total operation time: the total wall-clock time taken to run the benchmark.
Benchmark summary for Arm64
Results from the run on the c4a-standard-4 (4 vCPU, 16 GB memory) Arm64 VM in GCP (SUSE shown; Ubuntu results were very similar):
MetricWrite TestRead Test
Operation Rate (op/s)10,6904,962
Partition Rate (pk/s)10,6904,962
Row Rate (row/s)10,6904,962
Latency Mean3.7 ms6.3 ms
Latency Median2.8 ms4.5 ms
Latency 95th Percentile9.5 ms17.4 ms
Latency 99th Percentile16.7 ms33.4 ms
Latency 99.9th Percentile28.9 ms59.6 ms
Latency Max38.4 ms86.0 ms
Total Partitions10,00010,000
Total Errors00
Total GC Count00
Total GC Memory0 B0 B
Total GC Time0.0 s0.0 s
Total Operation Time0:00:000:00:02
You’ve successfully deployed Apache Cassandra 5.0.5 on a Google Axion C4A Arm-based virtual machine, validated its functionality, and measured its performance using cassandra-stress. The benchmark results on Google Axion C4A Arm-based instances demonstrate strong performance characteristics.
Write operations achieved high throughput of 10,690 op/s, while read operations reached 4,962 op/s on the c4a-standard-4 Arm64 VM. Write latency was notably low with a mean of 3.7 ms compared to reads at 6.3 ms, indicating fast write processing on this Arm64 VM. The 95th and 99th percentile latencies show consistent performance, with writes significantly faster than reads. Zero errors or GC overhead confirm stable and reliable benchmarking results.
The Arm64 VM provides efficient and predictable performance, making it suitable for high-throughput Cassandra workloads. The low write latencies and high operation rates demonstrate that Arm-based infrastructure can effectively handle database operations that require both speed and consistency. These results provide a solid baseline for evaluating Cassandra performance on Arm64 architecture and can guide decisions about instance sizing and configuration for production deployments.
To continue building on this foundation, you can explore advanced Cassandra configurations such as multi-node cluster deployments, replication strategies for high availability, or performance tuning for specific workload patterns. You might also investigate integrating Cassandra with application frameworks or comparing performance across different Arm-based instance types to optimize for your use case.
