Now that Cassandra is installed on your GCP C4A Arm virtual machine, verify that it’s running and functioning properly.
Run Cassandra in the background:
cassandra -R
The -R flag allows Cassandra to run in the background as a daemon. The first startup may take 30–60 seconds as it initializes.
Check logs to ensure Cassandra started successfully:
tail -f ~/cassandra/logs/system.log
Look for the message “Startup complete”, which indicates Cassandra is fully initialized.
nodetool status
The output is similar to:
Datacenter: datacenter1
Status=Up/Down
|/ State=Normal/Leaving/Joining/Moving
-- Address Load Tokens Owns (effective) Host ID Rack
UN 127.0.0.1 162.51 KiB 16 100.0% 78774686-39f3-47e7-87c3-3abc4f02a835 rack1
For a single-node setup, the output should indicate that the node is Up (U) and Normal (N), confirming that your Cassandra instance is running and ready to accept queries.
cqlsh is the interactive command-line shell for Cassandra that allows you to run Cassandra Query Language (CQL) commands.
cqlsh
You’ll enter the CQL (Cassandra Query Language) shell.
A keyspace in Cassandra is similar to a database in SQL systems. Create a simple keyspace testks with a replication factor of 1 (suitable for a single-node setup):
CREATE KEYSPACE testks WITH replication = {'class':'SimpleStrategy','replication_factor' : 1};
Verify the keyspace was created:
DESCRIBE KEYSPACES;
cqlsh> DESCRIBE KEYSPACES;
system system_distributed system_traces system_virtual_schema
system_auth system_schema system_views testks
Create a users table with three columns:
USE testks;
CREATE TABLE users (
id UUID PRIMARY KEY,
name text,
age int
Insert two sample rows into the users table. The uuid() function generates a unique identifier for each row:
INSERT INTO users (id, name, age) VALUES (uuid(), 'Alice', 30);
INSERT INTO users (id, name, age) VALUES (uuid(), 'Bob', 25);
Retrieve all rows from the users table:
SELECT * FROM users;
id | age | name
c08dafde-17f0-4a4a-82b8-54455bb07836 | 25 | Bob
d47eb93c-3988-4aa1-bc85-9561500a6893 | 30 | Alice
(2 rows)
This baseline test verifies that Cassandra 5.0.5 is installed and running correctly on the VM, confirming node status, CQLSH connectivity, and basic database operations.
Press Ctrl-D to exit the Cassandra Query Shell.
