Explore related resources
Give feedback
AI-assisted
Close
Which Google Cloud machine type should I choose for this setup?
Select the c4a-standard-4 machine type (4 vCPUs, 16 GB memory) when creating the VM. This aligns with the example in the provisioning step.
How do I start Cassandra and confirm it is ready?
Start Cassandra with cassandra -R to run it in the background. Tail ~/cassandra/logs/system.log and wait for the “Startup complete” message, then use nodetool status to check the node state.
What should I check in nodetool status before continuing?
Verify that nodetool status returns the node’s status and cluster information. Use this as a quick check that the service is responding before running any benchmarks.
Where is `cassandra-stress` located and how can I verify it’s installed?
cassandra-stress is in the tools/bin directory of your Cassandra installation. List the directory and confirm it appears, for example with ls ~/cassandra/tools/bin | grep cassandra-stress.
Which Java version does the installation use in this guide?
Cassandra requires a Java runtime. The example uses Java 17.
