Discover Buildkite on Google Axion C4A instances
Create a Google Axion C4A Arm virtual machine on GCP
Install Buildkite on a Google Axion C4A Arm VM
Set up and connect Buildkite agent on a Google Axion C4A Arm VM
Create a Flask app and set up the Buildkite pipeline
Run the Buildkite pipeline
Now you’ll create a simple application to containerize with Docker. This example uses Flask, a popular Python web framework.
The first step is to create a new public GitHub repository. You’ll add both the Dockerfile and the Python application file to this repository.
In a GitHub repo, add a new file named Dockerfile with this content:
FROM python:3.12-slim
WORKDIR /app
COPY app.py .
RUN pip install flask
EXPOSE 5000
CMD ["python", "app.py"]
In the same repo, add a Python source file named app.py:
from flask import Flask
app = Flask(__name__)
@app.route('/')
def hello():
return "Hello from Arm-based Buildkite runner!"
if __name__ == "__main__":
app.run(host="0.0.0.0", port=5000)
This Python code defines a simple Flask web server that listens on all interfaces (0.0.0.0) at port 5000 and responds with “Hello from Arm-based Buildkite runner!” when the root URL (/) is accessed.
Before you trigger the Buildkite pipeline, make sure your GitHub repository contains both the Dockerfile and the app.py file. The Dockerfile defines your multi-architecture container image, and app.py is your Python microservice.
You’ll need the URL of this repository when you create your Buildkite pipeline in the next steps.
Make sure to add your Docker credentials as secrets in the Buildkite UI.
Navigate to Buildkite and select Agents and then Secrets and add DOCKER_USERNAME and DOCKER_PASSWORD.
Set Secrets
In Buildkite, define your pipeline using YAML through the UI.
Go to the Buildkite Dashboard and select Pipelines and New Pipeline
Fill out the form using the following details:
Create Pipeline
In the Steps (YAML Steps) section, paste your pipeline YAML:
steps:
- label: "Build and Push Multiarch App"
env:
DOCKER_CONFIG: "~/.docker"
commands:
- echo "Testing env hook..."
- env | grep DOCKER
- ~/.buildkite-agent/bin/buildkite-agent secret get "DOCKER_PASSWORD" | docker login -u "$(~/.buildkite-agent/bin/buildkite-agent secret get "DOCKER_USERNAME")" --password-stdin
- docker buildx rm mybuilder || true
- docker buildx create --use --name mybuilder
- docker buildx inspect --bootstrap
- docker buildx build --platform linux/amd64,linux/arm64 -t "$(~/.buildkite-agent/bin/buildkite-agent secret get "DOCKER_USERNAME")/multi-arch-app:latest" --push .
agents:
queue: buildkite-queue1
YAML steps
Select Create pipeline to save your new pipeline.
To start your first build, select New build on your pipeline dashboard. This action triggers the pipeline and begins the multi-architecture build process.
Create Build
You’ve now created a simple Flask application, added a Dockerfile, set up your GitHub repository, and configured a Buildkite pipeline for multi-architecture builds on Arm. You also added Docker credentials as secrets and defined your pipeline steps in YAML. These steps prepare you to build, push, and test containerized applications using Arm-based infrastructure. You’re now ready to validate your setup and run your first build!
