This section compares the performance of baseline binaries with BOLT-optimized versions. It highlights the impact of merged profile optimizations and shared library enhancements on overall system throughput and latency.
All tests used Sysbench with the flags --time=0 --events=10000. This configuration ensures that each test completes exactly 10,000 requests per thread, delivering consistent workload runtimes across runs.
| Metric | Read-only | Write-only | Read + write |
| Transactions/sec (TPS) | 1006.33 | 2113.03 | 649.15 |
| Queries/sec (QPS) | 16,101.24 | 12,678.18 | 12,983.09 |
| Latency avg (ms) | 0.99 | 0.47 | 1.54 |
| Latency 95th % (ms) | 1.04 | 0.83 | 1.79 |
| Total time (s) | 9.93 | 4.73 | 15.40 |
| Metric | Regular BOLT (read + write, system libssl) | Merged BOLT (read + write + libssl) |
| Transactions/sec (TPS) | 850.32 | 879.18 |
| Queries/sec (QPS) | 17,006.35 | 17,583.60 |
| Latency avg (ms) | 1.18 | 1.14 |
| Latency 95th % (ms) | 1.52 | 1.39 |
| Total time (s) | 11.76 | 11.37 |
Second test run:
| Transactions/sec (TPS) | 853.16 | 887.14 |
| Queries/sec (QPS) | 17,063.22 | 17,742.89 |
| Latency avg (ms) | 1.17 | 1.13 |
| Latency 95th % (ms) | 1.39 | 1.37 |
| Total time (s) | 239.9 | 239.9 |
| Metric | BOLT read-only | BOLT write-only | Merged BOLT (read + write + libssl) | Merged BOLT (read + write + libcrypto) | Merged BOLT (read + write + libcrypto + libssl) |
| Transactions/sec (TPS) | 1348.47 | 3170.92 | 887.14 | 896.58 | 902.98 |
| Queries/sec (QPS) | 21575.45 | 19025.52 | 17742.89 | 17931.57 | 18059.52 |
| Latency avg (ms) | 0.74 | 0.32 | 1.13 | 1.11 | 1.11 |
| Latency 95th % (ms) | 0.77 | 0.55 | 1.37 | 1.34 | 1.34 |
| Total time (s) | 239.8 | 239.72 | 239.9 | 239.9 | 239.9 |
All Sysbench and .fdata file paths, as well as taskset usage, should match the conventions in previous steps: use Sysbench from PATH (no src/), use /usr/share/sysbench/ for Lua scripts, and use $HOME-based paths for all .fdata and library files. On an 8-core system, use taskset -c 7 for Sysbench and avoid contention with mysqld.
libssl and libcrypto) provide smaller incremental gains, delivering a fully-optimized execution environment.
