In this section, you’ll learn how to instrument and optimize shared libraries, and specifically, libssl.so and libcrypto.so using BOLT. These libraries are used by MySQL, and optimizing them can improve overall performance. You’ll rebuild OpenSSL from source to include symbol information, then collect profiles and apply BOLT optimizations.
If system libraries like /usr/lib/libssl.so are stripped, rebuild OpenSSL from source with relocations:
cd $HOME
git clone https://github.com/openssl/openssl.git
cd openssl
./config -O2 -Wl,--emit-relocs --prefix=$HOME/bolt-libs/openssl
make -j$(nproc)
make install
Use llvm-bolt to instrument libssl.so.3:
llvm-bolt $HOME/bolt-libs/openssl/lib/libssl.so.3 \
-instrument \
-o $HOME/bolt-libs/openssl/lib/libssl.so.3.instrumented \
--instrumentation-file=$HOME/bolt-libs/openssl/lib/libssl-readwrite.fdata \
--instrumentation-sleep-time=5 \
--instrumentation-no-counters-clear \
--instrumentation-wait-forks \
2>&1 | tee $HOME/mysql-server/bolt-instrumentation-libssl.log
Launch MySQL with the instrumented libssl.so and run a read+write Sysbench test to populate the profile
After running the read+write test, ensure libssl-readwrite.fdata is populated.
Run BOLT on the uninstrumented libssl.so using the collected read+write profile:
-o $HOME/bolt-libs/openssl/lib/libssl.so.optimized \
-data=$HOME/bolt-libs/openssl/lib/libssl-readwrite.fdata \
-reorder-blocks=ext-tsp \
-reorder-functions=hfsort \
-split-functions \
-split-all-cold \
-split-eh \
-dyno-stats \
--print-profile-stats \
2>&1 | tee $HOME/mysql-server/build/bolt-libssl.log
Copy the optimized version over the original and export the path:
# Set LD_LIBRARY_PATH in the terminal before launching mysqld in order for mysqld to pick the optimized library.
cp $HOME/bolt-libs/openssl/libssl.so.optimized $HOME/bolt-libs/openssl/lib/libssl.so.3
export LD_LIBRARY_PATH=$HOME/bolt-libs/openssl/lib
# You can confirm that mysqld is loading your optimized library with:
ldd build/bin/mysqld | grep libssl
Setting LD_LIBRARY_PATH ensures that MySQL dynamically links to the optimized shared library at runtime. This does not permanently override system libraries.
It should show:
libssl.so.3 => /home/ubuntu/bolt-libs/openssl/libssl.so.3
This ensures MySQL will dynamically load the optimized libssl.so.
Start the BOLT-optimized MySQL binary and link it against the optimized libssl.so. Run the combined workload:
# On an 8-core system, use available cores (e.g., 7 for sysbench)
taskset -c 7 ./src/sysbench \
--db-driver=mysql \
--mysql-host=127.0.0.1 \
--mysql-db=bench \
--mysql-user=bench \
--mysql-password=bench \
--mysql-port=3306 \
--tables=8 \
--table-size=10000 \
--forced-shutdown \
--report-interval=60 \
--rand-type=uniform \
--time=5 \
--threads=1 \
--simple-ranges=1 \
--distinct-ranges=1 \
--sum-ranges=1 \
--order-ranges=1 \
--point-selects=10 \
src/lua/oltp_read_write.lua run
In the next step, you’ll optimize an additional critical external library (libcrypto.so) using BOLT, following a similar process as libssl.so. Afterward, you’ll interpret performance results to validate and compare optimizations across baseline and merged scenarios.
Follow these steps to instrument and optimize libcrypto.so:
llvm-bolt $HOME/bolt-libs/openssl/libcrypto.so.3 \
-instrument \
-o $HOME/bolt-libs/openssl/lib/libcrypto.so.3.instrumented \
--instrumentation-file=$HOME/bolt-libs/openssl/lib/libcrypto-readwrite.fdata \
2>&1 | tee $HOME/mysql-server/bolt-instrumentation-libcrypto.log
Launch MySQL using the instrumented shared library and run a read+write Sysbench test to populate the profile.
After running the read+write test, ensure libcrypto-readwrite.fdata is populated.
Run BOLT on the uninstrumented libcrypto.so using the collected read+write profile to generate an optimized library:
llvm-bolt $HOME/bolt-libs/openssl/lib/libcrypto.so.3 \
-o $HOME/bolt-libs/openssl/lib/libcrypto.so.optimized \
-data=libcrypto-readwrite.fdata \
-split-functions \
-split-all-cold \
-split-eh \
-dyno-stats \
2>&1 | tee $HOME/mysql-server/build/bolt-libcrypto.log
Replace the original at runtime:
cp $HOME/bolt-libs/openssl/libcrypto.so.optimized $HOME/bolt-libs/openssl/lib/libcrypto.so.3
LD_LIBRARY_PATH=$HOME/bolt-libs/openssl/ ldd build/bin/mysqld | grep libcrypto
It should show:
libcrypto.so.3 => /home/ubuntu/bolt-libs/openssl/libcrypto.so.3
Run a final validation workload to ensure functionality and measure performance improvements.
--db-driver=mysql \
--mysql-db=bench \
--mysql-port=3306 \
--tables=8 \
--forced-shutdown \
--time=5 \
--threads=1 \
--simple-ranges=1 \
--sum-ranges=1 \
--order-ranges=1 \
