In this step, you’ll generate a profile for a write-heavy workload and merge it with the read-heavy profile you created earlier. The merged profile captures a broader set of execution behaviors for optimizing the final binary.
You can reuse the previously built MySQL binary or generate a new instrumented variant if needed.
Use the BOLT-instrumented MySQL binary to run a write-only workload and generate profile-writeonly.fdata. You can reuse the binary from the previous step or create a new one with the command below.
llvm-bolt $HOME/mysql-server/build/bin/mysqld \
-instrument \
-o $HOME/mysql-server/build/bin/mysqldwriteonly.instrumented \
--instrumentation-file=$HOME/mysql-server/build/profile-writeonly.fdata \
--instrumentation-sleep-time=5 \
--instrumentation-no-counters-clear \
--instrumentation-wait-forks \
2>&1 | tee $HOME/mysql-server/bolt-instrumentation-writeonly.log
Run Sysbench using the write-only Lua script to generate a workload profile:
# On an 8-core system, use available cores (e.g., 7 for Sysbench)
taskset -c 7 ./src/sysbench \
--db-driver=mysql \
--mysql-host=127.0.0.1 \
--mysql-db=bench \
--mysql-user=bench \
--mysql-password=bench \
--mysql-port=3306 \
--tables=8 \
--table-size=10000 \
--forced-shutdown \
--report-interval=60 \
--rand-type=uniform \
--time=5 \
--threads=1 \
--simple-ranges=1 \
--distinct-ranges=1 \
--sum-ranges=1 \
--order-ranges=1 \
--point-selects=10 \
src/lua/oltp_write_only.lua run
Confirm that --instrumentation-file is set to profile-writeonly.fdata.
After running each benchmark, cleanly shut down the MySQL server and reset the in-memory dataset to ensure the next run starts in a consistent state:
./bin/mysqladmin -u root shutdown ; rm -rf /dev/shm/dataset ; cp -R data/ /dev/shm/dataset
Verify that the following .fdata files have been generated:
ls -lh $HOME/mysql-server/build/profile-readonly.fdata
ls -lh $HOME/mysql-server/build/profile-writeonly.fdata
Both .fdata files should now exist and contain valid data:
profile-readonly.fdataprofile-writeonly.fdataUse merge-fdata to combine the feature-specific profiles into one comprehensive .fdata file:
merge-fdata $HOME/mysql-server/build/profile-readonly.fdata $HOME/mysql-server/build/profile-writeonly.fdata \
-o $HOME/mysql-server/build/profile-merged.fdata
Output:
Using legacy profile format.
Profile from 2 files merged.
This creates a single merged profile (profile-merged.fdata) covering both read-only and write-only workload behaviors.
Confirm the merged profile file exists and is non-empty:
ls -lh $HOME/mysql-server/build/profile-merged.fdata
Use LLVM-BOLT to generate the final optimized binary using the merged .fdata file:
-o $HOME/mysql-server/build/bin/mysqldreadwrite_merged.bolt_instrumentation \
-data=$HOME/mysql-server/build/profile-merged.fdata \
-reorder-blocks=ext-tsp \
-reorder-functions=hfsort \
-split-functions \
-split-all-cold \
-split-eh \
-dyno-stats \
--print-profile-stats \
2>&1 | tee $HOME/mysql-server/build/bolt-readwritemerged-opt.log
Key flags explained:
-reorder-blocks=ext-tsp: Reorders code blocks to improve cache locality-split-functions: Separates hot and cold regions for better performance-dyno-stats: Prints dynamic profile-based statistics during optimizationThis command optimizes the binary layout based on the merged workload profile, creating a single binary (mysqldreadwrite_merged.bolt_instrumentation) that is optimized across both features.
