In this step, you’ll use BOLT to instrument the MySQL application binary and to collect profile data for specific workloads. The collected profiles will later be merged with others and used to optimize the application’s code layout.
Build the MySQL server (mysqld) binary from source.
Start by installing the required dependencies:
sudo apt update
sudo apt install -y build-essential cmake libncurses5-dev libssl-dev libboost-all-dev \
bison pkg-config libaio-dev libtirpc-dev git ninja-build liblz4-dev
Clone the MySQL source code. You can change to another version in the checkout command below if needed:
git clone https://github.com/mysql/mysql-server.git
cd mysql-server
git checkout mysql-8.0.37
Next, configure the build for debug:
mkdir build && cd build
cmake .. -DCMAKE_C_FLAGS="-O3 -march=native -Wno-enum-constexpr-conversion -fno-reorder-blocks-and-partition" \
-DCMAKE_CXX_FLAGS="-O3 -march=native -Wno-enum-constexpr-conversion -fno-reorder-blocks-and-partition" \
-DCMAKE_CXX_LINK_FLAGS="-Wl,--emit-relocs" -DCMAKE_C_LINK_FLAGS="-Wl,--emit-relocs" -G Ninja \
-DWITH_BOOST=$HOME/boost -DDOWNLOAD_BOOST=On -DWITH_ZLIB=bundled -DWITH_LZ4=system -DWITH_SSL=system
Then build MySQL:
ninja
After the build completes, the mysqld binary is located in $HOME/mysql-server/build/runtime_output_directory/mysqld
Replace runtime_output_directory with your actual path (runtime_output_directory/ is a placeholder — the real directory might differ based on your build system or configuration).
You can run mysqld directly from the build directory or install it system-wide using make install. For testing and instrumentation, running it locally from the build directory is recommended.
After building mysqld, install MySQL server and client utilities system-wide:
sudo ninja install
This makes the mysql client and other utilities available in your PATH.
echo 'export PATH="$PATH:/usr/local/mysql/bin"' >> ~/.bashrc
source ~/.bashrc
Ensure the binary is unstripped and includes debug symbols for BOLT instrumentation.
Make sure your application binary:
Is built from source
Includes symbol information (unstripped)
I - s compiled with frame pointers (-fno-omit-frame-pointer)
You can verify symbol presence with:
readelf -s $HOME/mysql-server/build/runtime_output_directory/mysqld | grep main
The partial output is:
23837: 000000000950dfe8 8 OBJECT GLOBAL DEFAULT 27 mysql_main
34522: 000000000915bfd0 8 OBJECT GLOBAL DEFAULT 26 server_main_callback
42773: 00000000051730e4 80 FUNC GLOBAL DEFAULT 13 _Z18my_main_thre[...]
44882: 000000000357dc98 40 FUNC GLOBAL DEFAULT 13 main
61046: 0000000005ffd5c0 40 FUNC GLOBAL DEFAULT 13 _Z21record_main_[...]
If the symbols are missing, rebuild the binary with debug flags and disable stripping.
Before running the workload, you might need to initialize a new data directory if this is your first run:
# Initialize a new data directory
# Run this from the root of your MySQL source directory (e.g. $HOME/mysql-server). This creates an empty database in the data/ directory.
bin/mysqld --initialize-insecure --datadir=data
Start the instrumented server. On an 8-core system, use core 2 for mysqld and core 7 for Sysbench to avoid contention.
Run the command from build directory:
taskset -c 2 ./bin/mysqld \
--datadir=data \
--max-connections=64 \
--back-log=10000 \
--innodb-buffer-pool-instances=128 \
--innodb-file-per-table \
--innodb-sync-array-size=1024 \
--innodb-flush-log-at-trx-commit=1 \
--innodb-io-capacity=5000 \
--innodb-io-capacity-max=10000 \
--tmp-table-size=16M \
--max-heap-table-size=16M \
--log-bin=1 \
--sync-binlog=1 \
--innodb-stats-persistent \
--innodb-read-io-threads=4 \
--innodb-write-io-threads=4 \
--key-buffer-size=16M \
--max-allowed-packet=16M \
--max-prepared-stmt-count=2000000 \
--innodb-flush-method=fsync \
--innodb-log-buffer-size=64M \
--read-buffer-size=262144 \
--read-rnd-buffer-size=524288 \
--binlog-format=MIXED \
--innodb-purge-threads=1 \
--table-open-cache=8000 \
--table-open-cache-instances=16 \
--open-files-limit=1048576 \
--default-authentication-plugin=mysql_native_password
Adjust --datadir, --socket, and --port as needed for your environment. Make sure the server is running and accessible before proceeding.
With the database running, open a second terminal to create a benchmark user and third terminal to run the client commands.
In the new terminal, navigate to the build directory:
cd $HOME/mysql-server/build
Run once after initializing MySQL for the first time:
bin/mysql -u root <<< "
CREATE USER 'bench'@'localhost' IDENTIFIED BY 'bench';
CREATE DATABASE bench;
GRANT ALL PRIVILEGES ON *.* TO 'bench'@'localhost' WITH GRANT OPTION;
FLUSH PRIVILEGES;"
This sets up the bench user and the bench database with full privileges.
You only need to do this once. Don’t repeat it before each test.
This clears all existing tables and data from the bench database, giving you a clean slate for Sysbench prepare without needing to recreate the user or reinitialize the datadir.
bin/mysql -u root <<< "DROP DATABASE bench; CREATE DATABASE bench;"
In a third terminal, run the commands below if you have not run Sysbench yet:
git clone https://github.com/akopytov/sysbench.git
cd sysbench
./autogen.sh
./configure
make -j$(nproc)
export LD_LIBRARY_PATH=/usr/local/mysql/lib/
Use ./src/sysbench for running benchmarks unless installed globally.
Run sysbench with the prepare option:
./src/sysbench \
--db-driver=mysql \
--mysql-host=127.0.0.1 \
--mysql-db=bench \
--mysql-user=bench \
--mysql-password=bench \
--mysql-port=3306 \
--tables=8 \
--table-size=10000 \
--threads=1 \
src/lua/oltp_read_write.lua prepare
Do these steps once at the start from MySQL source directory
bin/mysqladmin -u root shutdown
mv data data-orig
This saves the populated dataset before benchmarking.
rm -rf /dev/shm/dataset
cp -R data-orig/ /dev/shm/dataset
From MySQL source directory,
ln -s /dev/shm/dataset/ data
This links the MySQL –datadir to a fast in-memory copy, ensuring every test starts from a clean, identical state.
Use llvm-bolt to create an instrumented version of the binary:
llvm-bolt $HOME/mysql-server/build/bin/mysqld \
-instrument \
-o $HOME/mysql-server/build/bin/mysqldreadonly.instrumented \
--instrumentation-file=$HOME/mysql-server/build/profile-readonly.fdata \
--instrumentation-sleep-time=5 \
--instrumentation-no-counters-clear \
--instrumentation-wait-forks \
2>&1 | tee $HOME/mysql-server/bolt-instrumentation-readonly.log
These flags control how BOLT collects runtime data from the instrumented binary. Understanding them helps ensure accurate and comprehensive profile generation:
-instrument: enables instrumentation mode. BOLT inserts profiling instructions into the binary to record execution behavior at runtime.--instrumentation-file=<PATH.: specifies the output file for the collected profiling data (.fdata). This file is later used during optimization.--instrumentation-wait-forks: instructs BOLT to wait for forked child processes to complete, which is important for applications like daemons or servers that spawn subprocesses.Start the MySQL instrumented binary in first terminal.
Use a workload generator to stress the binary in a feature-specific way.
For example, to simulate read-only traffic with Sysbench:
taskset -c 7 ./src/sysbench \
--db-driver=mysql \
--mysql-db=bench \
--mysql-port=3306 \
--tables=8 \
--forced-shutdown \
--report-interval=60 \
--rand-type=uniform \
--time=5 \
--threads=1 \
--simple-ranges=1 \
--distinct-ranges=1 \
--sum-ranges=1 \
--order-ranges=1 \
--point-selects=10 \
src/lua/oltp_read_only.lua run
On an 8-core system, cores are numbered 0-7. Adjust the taskset -c values as needed for your system. Avoid using the same core for both mysqld and sysbench to reduce contention. You can increase this time (for example, –time=5 or –time=300) for more statistically meaningful profiling and better .fdata data.
The .fdata file defined in --instrumentation-file will be populated with runtime execution data.
After completing each benchmark run (for example, after Sysbench run), you must cleanly shut down the MySQL server and reset the dataset to ensure the next test starts from a consistent state.
bin/mysqladmin -u root shutdown ; rm -rf /dev/shm/dataset ; cp -R data/ /dev/shm/dataset
After running the workload:
ls -lh $HOME/mysql-server/build/profile-readonly.fdata
You should see a non-empty file. This file will later be merged with other profiles (for example, for write-only traffic) to generate a complete merged profile.
