Explore related resources
Give feedback
AI-assisted
Close
What output should I expect after running an instrumented workload with BOLT?
BOLT produces a profile file in .fdata format, such as profile-writeonly.fdata. These files are later used to optimize the binary and can be merged to improve coverage.
Should I reuse the BOLT-instrumented mysqld binary for additional workloads or create a new one?
Either approach works. The steps allow reusing the previously instrumented binary or generating a new instrumented variant as long as you produce a new .fdata profile for each workload.
Which shared libraries are targeted for optimization, and what if the system copies are stripped?
The path optimizes libssl.so and libcrypto.so. If system libraries are stripped, rebuild OpenSSL from source with relocations enabled so BOLT can instrument and optimize them.
Do I need to rebuild the application to benefit from optimized shared libraries?
The shared libraries are optimized independently of the application binary. The path focuses on rebuilding OpenSSL for symbol information and then integrating the optimized libraries with the application.
What test configuration is used to compare baseline and BOLT-optimized results?
Sysbench is run with --time=0 --events=10000 to complete exactly 10,000 requests per thread. Use this consistent configuration to compare baseline, application-only, and merged-with-library optimization scenarios.
