On your AArch64 Linux machine, navigate to your home directory (or another empty working directory) and download the bsort.cpp source file:
wget https://raw.githubusercontent.com/ArmDeveloperEcosystem/arm-learning-paths/main/content/learning-paths/servers-and-cloud-computing/bolt-demo/bsort.cpp
The Why Bubble Sort? section explains why BubbleSort is used as the demonstration workload.
Create the following directories to organize generated files from this example:
mkdir -p out prof heatmap
Next, compile the input program.
Because BOLT and other profile-guided optimization pipelines often involve multiple build stages, you will refer to this initial binary as the stage-0 binary.
For this example, you must preserve the original function order from the source file. Small programs like this one are simple enough that modern compilers may reorder functions automatically to improve instruction locality, even without profile data. That behavior rarely affects large real-world applications, but it can occur in this example. To ensure the program retains its intentionally poor layout, pass specific options to the compiler and linker.
BOLT works with both LLVM and GNU toolchains.
GNU (gcc) provides a flag that preserves the original order: -fno-toplevel-reorder.
LLVM Clang does not provide an equivalent flag, so it relies on a symbol ordering file that explicitly defines the initial function layout. Using a file editor of your choice copy the contents below into a file named orderfile.txt.
_ZL5swap1PiS_
_ZL10cold_func1v
_ZL5swap2PiS_
_ZL10cold_func2v
_ZL5swap3PiS_
_ZL10cold_func3v
_ZL5swap4PiS_
_ZL10cold_func4v
_ZL5swap5PiS_
_ZL10cold_func5v
Both approaches to compile the binary are shown. Compile with your preferred toolchain, and ensure that relocations are enabled. You will look at why relocations matter later in this Learning Path.
gcc bsort.cpp -o out/bsort -O3 -Wl,--emit-relocs -fno-toplevel-reorder
clang bsort.cpp -o out/bsort -O3 -fuse-ld=lld -ffunction-sections -Wl,--emit-relocs -Wl,--symbol-ordering-file=orderfile.txt
Verify that the compiler preserved the intended function order by inspecting the symbols in the .text section of the binary.
Run the following command:
objdump --syms --demangle out/bsort | grep ".text" | grep ")" | sort
__output__ 0000000000014000 l F .text 0000000000000e4c swap1(int*, int*)
__output__ 0000000000018000 l F .text 0000000000000008 cold_func1()
__output__ 0000000000018008 l F .text 0000000000000e4c swap2(int*, int*)
__output__ 000000000001c000 l F .text 0000000000000008 cold_func2()
__output__ 000000000001c008 l F .text 0000000000000e4c swap3(int*, int*)
__output__ 0000000000020000 l F .text 0000000000000008 cold_func3()
__output__ 0000000000020008 l F .text 0000000000000e4c swap4(int*, int*)
__output__ 0000000000024000 l F .text 0000000000000008 cold_func4()
__output__ 0000000000024008 l F .text 0000000000000e4c swap5(int*, int*)
__output__ 0000000000028000 l F .text 0000000000000008 cold_func5()
__output__ 0000000000028158 g F .text 00000000000000c0 bubble_sort(int*, int)
__output__ 0000000000028218 g F .text 00000000000000d8 sort_array(int*)
llvm-objdump --syms --demangle out/bsort | grep ".text" | grep ")" | sort
The output should show the swap and cold functions interleaved.
This layout matches the order in the source file and creates poor instruction locality, which makes the program a good candidate for BOLT optimization.
Verify that the binary contains relocation information.
BOLT relies on relocation records to safely modify the binary layout after linking.
Check the ELF section table and confirm that relocation sections such as .rela.text appear in the output.
readelf -S out/bsort | grep .rel
__output__ [ 9] .rela.dyn RELA 0000000000000520 00000520
__output__ [10] .rela.plt RELA 0000000000000658 00000658
__output__ [20] .data.rel.ro PROGBITS 0000000000038560 00018560
__output__ [23] .relro_padding NOBITS 0000000000038750 00018750
__output__ [28] .rela.text RELA 0000000000000000 000187b8
__output__ [29] .rela.eh_frame RELA 0000000000000000 00018ea8
__output__ [30] .rela.init RELA 0000000000000000 00019058
__output__ [31] .rela.data RELA 0000000000000000 00019070
__output__ [32] .rela.fini_array RELA 0000000000000000 00019088
__output__ [33] .rela.init_array RELA 0000000000000000 000190a0
__output__ [35] .rela.data.rel.ro RELA 0000000000000000 00019158
__output__
llvm-readelf -S out/bsort | grep .rel
__output__ [ 9] .rela.dyn RELA 0000000000000520 000520 000138 18 A 4 0 8
__output__ [10] .rela.plt RELA 0000000000000658 000658 0000c0 18 AI 4 26 8
__output__ [20] .data.rel.ro PROGBITS 0000000000038560 018560 000028 00 WA 0 0 8
__output__ [23] .relro_padding NOBITS 0000000000038750 018750 0008b0 00 WA 0 0 1
__output__ [28] .rela.text RELA 0000000000000000 0187b8 0006f0 18 I 36 14 8
__output__ [29] .rela.eh_frame RELA 0000000000000000 018ea8 0001b0 18 I 36 12 8
__output__ [30] .rela.init RELA 0000000000000000 019058 000018 18 I 36 15 8
__output__ [31] .rela.data RELA 0000000000000000 019070 000018 18 I 36 24 8
__output__ [32] .rela.fini_array RELA 0000000000000000 019088 000018 18 I 36 18 8
__output__ [33] .rela.init_array RELA 0000000000000000 0190a0 000018 18 I 36 19 8
__output__ [35] .rela.data.rel.ro RELA 0000000000000000 019158 000078 18 I 36 20 8
Look for relocation sections such as .rela.text in the output. Their presence confirms that the linker preserved relocation information required by BOLT.
BOLT uses relocation records to update references after it changes the code layout. When BOLT reorders functions or basic blocks, it must update addresses used by instructions such as calls, branches, and references to code or data. Relocation records identify these locations in the binary so that BOLT can safely rewrite them. Without relocations, BOLT cannot reliably adjust these references. As a result, many optimizations become unavailable. For example, BOLT disables function reordering when relocation information is missing, which prevents most code layout optimizations.
Because BOLT operates on fully linked binaries, it must modify addresses that the linker already resolved. Relocations preserve the information needed to update those addresses correctly.
Bubble Sort is a simple program with all the code in one file. The program has no external dependencies, and runs in a few seconds under instrumentation with a small, fixed workload. In its original form, the program does not benefit much from code layout optimization. To create a more interesting example, instruction locality is intentionally reduced. We introduce cold code paths between frequently executed code. These cold blocks separate hot instructions in memory and degrade spatial locality. BOLT later improves performance by reorganizing the binary so that hot code paths appear closer together.
The code below shows how the program was modified to reduce code locality.
The main sort function rotates through five copies of the swap function. Each time the algorithm performs a swap, it selects the next swap implementation in a round-robin fashion.
void bubble_sort(int *a, int n) {
if (n <= 1)
return;
int end = n - 1;
int swapped = 1;
unsigned idx = 0;
while (swapped && end > 0) {
swapped = 0;
// pick a different copy of the swap function, in a round-robin fashion
// and call it.
for (int i = 1; i <= end; ++i) {
if (a[i] < a[i - 1]) {
auto swap_func = swap_funcs[idx++];
idx %= FUNC_COPIES;
swap_func(&a[i - 1], &a[i]);
swapped = 1;
--end;
Each swap function is defined using a macro and contains a small cold path that includes several nop instructions.
#define SWAP_FUNC(ID) \
static __attribute__((noinline)) \
void swap##ID(int *left, int *right) { \
if (COND()) NOPS(300); \
int tmp = *left; \
if (COND()) NOPS(300); else *left = *right; \
if (COND()) NOPS(300); else *right = tmp; \
To further reduce code locality, we place larger cold functions between frequently executed functions. These cold functions occupy space in the instruction layout and push hot code farther apart in memory. We define these cold functions using a macro. Each function contains only a nop instruction and does not participate in the program’s hot execution path.
#define COLD_FUNC(ID) \
static __attribute__((noinline, aligned(16384), used)) \
void cold_func##ID(void) { \
asm volatile("nop"); \
We use the above two macros to interleave the hot and cold functions in the binary. Locality is reduced because each call uses a different swap function with large cold code regions placed between them.
SWAP_FUNC(1) COLD_FUNC(1)
SWAP_FUNC(2) COLD_FUNC(2)
SWAP_FUNC(3) COLD_FUNC(3)
SWAP_FUNC(4) COLD_FUNC(4)
SWAP_FUNC(5) COLD_FUNC(5)
You’ve compiled the BubbleSort example program with intentionally poor code locality and verified that the binary contains the necessary relocation information. The program is now ready for profiling and optimization.
Next, you’ll learn how to identify whether this program is a good candidate for BOLT optimization by analyzing its performance metrics.
