Optimize bitmap scanning in databases with SVE and Neon on Arm servers
Build and manage a bit vector in C
Implement scalar bitmap scanning in C
Vectorized bitmap scanning with Neon and SVE
Benchmarking bitmap scanning across implementations
Applications and optimization best practices
Now that you’ve created four different bitmap scanning implementations, let’s build a benchmarking framework to compare their performance.
Copy the code shown below into bitvector_scan_benchmark.c :
// Timing function for bit vector scanning
double benchmark_scan(size_t (*scan_func)(bitvector_t*, uint32_t*),
bitvector_t* bv, uint32_t* result_positions,
int iterations, size_t* found_count) {
struct timespec start, end;
*found_count = 0;
clock_gettime(CLOCK_MONOTONIC, &start);
for (int iter = 0; iter < iterations; iter++) {
size_t count = scan_func(bv, result_positions);
if (iter == 0) {
*found_count = count;
clock_gettime(CLOCK_MONOTONIC, &end);
double elapsed = (end.tv_sec - start.tv_sec) * 1000.0 +
(end.tv_nsec - start.tv_nsec) / 1000000.0;
return elapsed / iterations;
The main function of your program is responsible for setting up the test environment, running the benchmarking code for the four different implementations across various bit densities, and reporting the results. In the context of bitmap scanning, bit density refers to the percentage or proportion of bits that are set (have a value of 1) in the bitmap.
Copy the main function code below into bitvector_scan_benchmark.c:
int main() {
srand(time(NULL));
printf("Bit Vector Scanning Performance Benchmark\n");
printf("========================================\n\n");
// Parameters
size_t bitvector_size = 10000000; // 10 million bits
int iterations = 10; // 10 iterations for timing
// Test different densities
double densities[] = {0.0, 0.0001, 0.001, 0.01, 0.1};
int num_densities = sizeof(densities) / sizeof(densities[0]);
printf("Bit vector size: %zu bits\n", bitvector_size);
printf("Iterations: %d\n\n", iterations);
// Allocate result array
uint32_t* result_positions = (uint32_t*)malloc(bitvector_size * sizeof(uint32_t));
printf("%-10s %-15s %-15s %-15s %-15s %-15s\n",
"Density", "Set Bits", "Scalar Gen (ms)", "Scalar Opt (ms)", "NEON (ms)", "SVE (ms)");
for (int d = 0; d < num_densities; d++) {
double density = densities[d];
// Generate bit vector with specified density
bitvector_t* bv = generate_bitvector(bitvector_size, density);
// Count actual set bits
size_t actual_set_bits = bitvector_count_scalar(bv);
// Benchmark implementations
size_t found_scalar_gen, found_scalar, found_neon, found_sve2;
double scalar_gen_time = benchmark_scan(scan_bitvector_scalar_generic, bv, result_positions,
iterations, &found_scalar_gen);
double scalar_time = benchmark_scan(scan_bitvector_scalar, bv, result_positions,
iterations, &found_scalar);
double neon_time = benchmark_scan(scan_bitvector_neon, bv, result_positions,
iterations, &found_neon);
double sve2_time = benchmark_scan(scan_bitvector_sve2_pnext, bv, result_positions,
iterations, &found_sve2);
// Print results
printf("%-10.4f %-15zu %-15.3f %-15.3f %-15.3f %-15.3f\n",
density, actual_set_bits, scalar_gen_time, scalar_time, neon_time, sve2_time);
// Print speedups for this density
printf("Speedups at %.4f density:\n", density);
printf(" Scalar Opt vs Scalar Gen: %.2fx\n", scalar_gen_time / scalar_time);
printf(" NEON vs Scalar Gen: %.2fx\n", scalar_gen_time / neon_time);
printf(" SVE vs Scalar Gen: %.2fx\n", scalar_gen_time / sve2_time);
printf(" NEON vs Scalar Opt: %.2fx\n", scalar_time / neon_time);
printf(" SVE vs Scalar Opt: %.2fx\n", scalar_time / sve2_time);
printf(" SVE vs NEON: %.2fx\n\n", neon_time / sve2_time);
// Verify results match
if (found_scalar_gen != found_scalar || found_scalar_gen != found_neon || found_scalar_gen != found_sve2) {
printf("WARNING: Result mismatch at %.4f density!\n", density);
printf(" Scalar Gen found %zu bits\n", found_scalar_gen);
printf(" Scalar Opt found %zu bits\n", found_scalar);
printf(" NEON found %zu bits\n", found_neon);
printf(" SVE found %zu bits\n\n", found_sve2);
// Clean up
bitvector_free(bv);
free(result_positions);
return 0;
You are now ready to compile and run your bitmap scanning implementations.
To compile the bitmap scanning implementations with the appropriate flags, run:
gcc -O3 -march=armv9-a+sve2 -o bitvector_scan_benchmark bitvector_scan_benchmark.c -lm
When running on a Graviton4 c8g.large instance with Ubuntu 24.04, the results should look similar to:
| Density | Set Bits | Scalar Generic | Scalar Optimized | Neon | SVE |
| 0.0000 | 0 | 7.169 | 0.456 | 0.056 | 0.093 |
| 0.0001 | 1,000 | 7.176 | 0.477 | 0.090 | 0.109 |
| 0.0010 | 9,996 | 7.236 | 0.591 | 0.377 | 0.249 |
| 0.0100 | 99,511 | 7.821 | 1.570 | 2.252 | 1.353 |
| 0.1000 | 951,491 | 12.817 | 8.336 | 9.106 | 6.770 |
| Density | Scalar Optimized | Neon | SVE |
| 0.0000 | 15.72x | 127.41x | 77.70x |
| 0.0001 | 15.05x | 80.12x | 65.86x |
| 0.0010 | 12.26x | 19.35x | 29.07x |
| 0.0100 | 5.02x | 3.49x | 5.78x |
| 0.1000 | 1.54x | 1.40x | 1.90x |
The benchmarking results reveal how different bitmap scanning implementations perform across a range of bit densities—from completely empty vectors to those with millions of set bits. Understanding these trends is key to selecting the most effective approach for your specific use case.
The optimized scalar implementation shows significant improvements over the generic scalar implementation due to:
The Neon implementation shows further improvements over the optimized scalar implementation for sparse bit vectors due to:
The performance comparison between Neon and SVE depends on the bit density:
Very Sparse Bit Vectors (0% - 0.01% density):
Higher Density Bit Vectors (0.1% - 10% density):
The SVE implementation includes several key optimizations:
Efficient Non-Zero Byte Detection: using svcmpne_u8 to quickly identify non-zero bytes in the bitvector.
Byte-Level Processing: using svpnext_b8 to efficiently find the next non-zero byte without processing zero bytes.
Value Extraction: using svlastb_u8 to extract both the index and value of non-zero bytes.
Hybrid Vector-Scalar Approach: combining vector operations for finding non-zero bytes with scalar operations for processing individual bits.
Prefetching: Using __builtin_prefetch to reduce memory latency by prefetching the next chunk of data.
Now that you’ve benchmarked all four bitmap scanning implementations—scalar (generic and optimized), Neon, and SVE—you have a data-driven understanding of how vectorization impacts performance across different bitmap densities.
In the next section, you’ll explore how to apply these techniques in real-world database workloads, including:
Bitmap index scans
Bloom filter checks
Column-level filtering in analytical queries
You’ll also learn practical guidelines for choosing the right implementation based on bit density, and discover optimization tips that go beyond the code to help you get the most out of Arm-based systems like Graviton4.
