Optimize bitmap scanning in databases with SVE and Neon on Arm servers
Build and manage a bit vector in C
Implement scalar bitmap scanning in C
Vectorized bitmap scanning with Neon and SVE
Benchmarking bitmap scanning across implementations
Applications and optimization best practices
Modern Arm CPUs like Neoverse V2 support SIMD (Single Instruction, Multiple Data) extensions that allow processing multiple bytes in parallel. In this section, you’ll explore how Neon and SVE vector instructions can dramatically accelerate bitmap scanning by skipping over large regions of unset data and reducing per-bit processing overhead.
This implementation uses Neon SIMD (Single Instruction, Multiple Data) instructions to process 16 bytes (128 bits) at a time, significantly accelerating the scanning process.
Copy the Neon implementation shown below into the same file:
// NEON implementation of bit vector scanning
size_t scan_bitvector_neon(bitvector_t* bv, uint32_t* result_positions) {
size_t result_count = 0;
// Process 16 bytes at a time using NEON
size_t i = 0;
for (; i + 16 <= bv->size_bytes; i += 16) {
uint8x16_t data = vld1q_u8(&bv->data[i]);
// Quick check if all bytes are zero
uint8x16_t zero = vdupq_n_u8(0);
uint8x16_t cmp = vceqq_u8(data, zero);
uint64x2_t cmp64 = vreinterpretq_u64_u8(cmp);
// If all bytes are zero (all comparisons are true/0xFF), skip this chunk
if (vgetq_lane_u64(cmp64, 0) == UINT64_MAX &&
vgetq_lane_u64(cmp64, 1) == UINT64_MAX) {
continue;
// Process each byte
uint8_t bytes[16];
vst1q_u8(bytes, data);
for (int j = 0; j < 16; j++) {
uint8_t byte = bytes[j];
// Skip empty bytes
if (byte == 0) {
continue;
// Process each bit in the byte
for (int bit_pos = 0; bit_pos < 8; bit_pos++) {
if (byte & (1 << bit_pos)) {
size_t global_pos = (i + j) * 8 + bit_pos;
if (global_pos < bv->size_bits) {
result_positions[result_count++] = global_pos;
// Handle remaining bytes with scalar code
for (; i < bv->size_bytes; i++) {
uint8_t byte = bv->data[i];
// Skip empty bytes
if (byte == 0) {
continue;
size_t global_pos = i * 8 + bit_pos;
return result_count;
This Neon implementation processes 16 bytes at a time with vector instructions. For sparse bitmaps, entire 16-byte chunks can be skipped at once, providing a significant speedup over byte-level skipping. After vector processing, it falls back to scalar code for any remaining bytes that don’t fill a complete 16-byte chunk.
This implementation uses SVE instructions which are available in the Arm Neoverse V2 based AWS Graviton 4 processor.
Copy this SVE implementation into the same file:
// SVE implementation using svcmp_u8, PNEXT, and LASTB
size_t scan_bitvector_sve2_pnext(bitvector_t* bv, uint32_t* result_positions) {
size_t sve_len = svcntb();
svuint8_t zero = svdup_n_u8(0);
// Process the bitvector to find all set bits
for (size_t offset = 0; offset < bv->size_bytes; offset += sve_len) {
svbool_t pg = svwhilelt_b8((uint64_t)offset, (uint64_t)bv->size_bytes);
svuint8_t data = svld1_u8(pg, bv->data + offset);
// Prefetch next chunk
if (offset + sve_len < bv->size_bytes) {
__builtin_prefetch(bv->data + offset + sve_len, 0, 0);
// Find non-zero bytes
svbool_t non_zero = svcmpne_u8(pg, data, zero);
// Skip if all bytes are zero
if (!svptest_any(pg, non_zero)) {
continue;
// Create an index vector for byte positions
svuint8_t indexes = svindex_u8(0, 1); // 0, 1, 2, 3, ...
// Initialize next with false predicate
svbool_t next = svpfalse_b();
// Find the first non-zero byte
next = svpnext_b8(non_zero, next);
// Process each non-zero byte using PNEXT
while (svptest_any(pg, next)) {
// Get the index of this byte
uint8_t byte_idx = svlastb_u8(next, indexes);
// Get the actual byte value
uint8_t byte_value = svlastb_u8(next, data);
// Calculate the global byte position
size_t global_byte_pos = offset + byte_idx;
// Process each bit in the byte using scalar code
if (byte_value & (1 << bit_pos)) {
size_t global_bit_pos = global_byte_pos * 8 + bit_pos;
if (global_bit_pos < bv->size_bits) {
result_positions[result_count++] = global_bit_pos;
// Find the next non-zero byte
The SVE implementation efficiently scans bitmaps by using svcmpne_u8 to identify non-zero bytes and svpnext_b8 to iterate through them sequentially. It extracts byte indices and values with svlastb_u8, then processes individual bits using scalar code. This hybrid vector-scalar approach maintains great performance across various bitmap densities. On Graviton4, SVE vectors are 128 bits (16 bytes), allowing processing of 16 bytes at once.
With both Neon and SVE implementations in place, you’ve now unlocked the full power of Arm’s vector processing capabilities for bitmap scanning. These SIMD techniques allow you to process large bitvectors more efficiently—especially when filtering sparse datasets or skipping over large blocks of empty rows.
In the next section, you’ll learn how to apply these optimizations in the context of real database operations like bitmap index scans, Bloom filter probes, and column filtering. You’ll also explore best practices for selecting the right implementation based on bit density, and tuning for maximum performance on AWS Graviton4.
