Optimize bitmap scanning in databases with SVE and Neon on Arm servers
Build and manage a bit vector in C
Implement scalar bitmap scanning in C
Vectorized bitmap scanning with Neon and SVE
Benchmarking bitmap scanning across implementations
Applications and optimization best practices
Now let’s define a simple bitmap data structure that serves as the foundation for the different implementations. The bitmap implementation uses a simple structure with three key components:
For testing the different implementations in this Learning Path, you also need functions to generate and analyze the bitmaps.
Use a file editor of your choice and then copy the code below into bitvector_scan_benchmark.c:
// Define a simple bit vector structure
typedef struct {
uint8_t* data;
size_t size_bytes;
size_t size_bits;
} bitvector_t;
// Create a new bit vector
bitvector_t* bitvector_create(size_t size_bits) {
bitvector_t* bv = (bitvector_t*)malloc(sizeof(bitvector_t));
bv->size_bits = size_bits;
bv->size_bytes = (size_bits + 7) / 8;
bv->data = (uint8_t*)calloc(bv->size_bytes, 1);
return bv;
// Free bit vector resources
void bitvector_free(bitvector_t* bv) {
free(bv->data);
free(bv);
// Set a bit in the bit vector
void bitvector_set_bit(bitvector_t* bv, size_t pos) {
if (pos < bv->size_bits) {
bv->data[pos / 8] |= (1 << (pos % 8));
// Get a bit from the bit vector
bool bitvector_get_bit(bitvector_t* bv, size_t pos) {
return (bv->data[pos / 8] & (1 << (pos % 8))) != 0;
return false;
// Generate a bit vector with specified density
bitvector_t* generate_bitvector(size_t size_bits, double density) {
bitvector_t* bv = bitvector_create(size_bits);
// Set bits according to density
size_t num_bits_to_set = (size_t)(size_bits * density);
for (size_t i = 0; i < num_bits_to_set; i++) {
size_t pos = rand() % size_bits;
bitvector_set_bit(bv, pos);
return bv;
// Count set bits in the bit vector
size_t bitvector_count_scalar(bitvector_t* bv) {
size_t count = 0;
for (size_t i = 0; i < bv->size_bits; i++) {
if (bitvector_get_bit(bv, i)) {
count++;
return count;
With your bit vector infrastructure in place, you’re now ready to scan it for set bits—the core operation that underpins all bitmap-based filters in database systems.
