Now that your image is registered, you can launch a new VM using the Azure CLI and the custom image ID. This example creates a Linux VM on Cobalt 100 Arm-based processors using the custom image you created earlier.
Use the following command to create a virtual machine using your custom image:
az vm create \
--resource-group "$RESOURCE_GROUP" \
--name "$VM_NAME" \
--image "$IMAGE_ID" \
--size "$VM_SIZE" \
--admin-username "$ADMIN_USER" \
--generate-ssh-keys \
--public-ip-sku Standard
After the VM is successfully created, retrieve the public IP address.
az vm show \
--name "$VM_NAME" \
--show-details \
--query "publicIps" \
-o tsv
Use the public IP address to SSH to the VM. Replace <public-ip-address> with the IP returned by the previous command.
ssh azureuser@<public-ip-address>
After connecting, print the machine information:
uname -a
The output is similar to:
Linux MyAzureLinuxARMVM 6.6.92.2-2.azl3 #1 SMP Wed Jul 2 02:43:35 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux
You are ready to use your Azure Linux virtual machine.
