You’re now ready to use the Azure CLI to create and upload a custom disk image to Azure. In this section, you’ll configure environment variables, provision the necessary Azure resources, and upload a .vhd file. Then, you’ll use the Shared Image Gallery to register the image for use with custom virtual machines.
Before uploading your VHD file, set the environment variables for the Azure CLI:
RESOURCE_GROUP="MyCustomARM64Group"
LOCATION="centralindia"
STORAGE_ACCOUNT="mycustomarm64storage"
CONTAINER_NAME="mycustomarm64container"
VHD_NAME="azurelinux-arm64.vhd"
GALLERY_NAME="MyCustomARM64Gallery"
IMAGE_DEF_NAME="MyAzureLinuxARM64Def"
IMAGE_VERSION="1.0.0"
PUBLISHER="custom"
OFFER="custom-offer"
SKU="custom-sku"
OS_TYPE="Linux"
ARCHITECTURE="Arm64"
HYPERV_GEN="V2"
STORAGE_ACCOUNT_TYPE="Standard_LRS"
VM_NAME="MyAzureLinuxARMVM"
ADMIN_USER="azureuser"
VM_SIZE="Standard_D4ps_v6"
Modify the environment variables such as RESOURCE_GROUP, VM_NAME, and LOCATION to suit your naming preferences, region, and resource requirements.
First, log in to Azure using the CLI:
az login
If prompted, open the browser link and enter the verification code to authenticate.
Then, create a new resource group. If you are using an existing resource group for the RESOURCE_GROUP environment variable, you can skip this step:
az group create --name "$RESOURCE_GROUP" --location "$LOCATION"
Create a new storage account to store your image:
az storage account create \
--name "$STORAGE_ACCOUNT" \
--resource-group "$RESOURCE_GROUP" \
--location "$LOCATION" \
--sku Standard_LRS \
--kind StorageV2
Next, create a blob container in the storage account:
az storage container create \
--name "$CONTAINER_NAME" \
--account-name "$STORAGE_ACCOUNT"
First, retrieve the storage account key:
STORAGE_KEY=$(az storage account keys list \
--account-name "$STORAGE_ACCOUNT" \
--query '[0].value' --output tsv)
Then upload your VHD file to Azure Blob Storage:
az storage blob upload \
--container-name "$CONTAINER_NAME" \
--name "$VHD_NAME" \
--file ./azurelinux-arm64.vhd
You can now use the Azure console to view the image in your Azure account.
Create a custom VM image from the VHD, using the Azure Shared Image Gallery (SIG):
az sig create \
--gallery-name "$GALLERY_NAME" \
Create the image definition:
az sig image-definition create \
--gallery-image-definition "$IMAGE_DEF_NAME" \
--publisher "$PUBLISHER" \
--offer "$OFFER" \
--sku "$SKU" \
--os-type "$OS_TYPE" \
--architecture "$ARCHITECTURE" \
--hyper-v-generation "$HYPERV_GEN"
Create the image version from the uploaded VHD:
az sig image-version create \
--gallery-image-version "$IMAGE_VERSION" \
--os-vhd-uri "https://${STORAGE_ACCOUNT}.blob.core.windows.net/${CONTAINER_NAME}/${VHD_NAME}" \
--os-vhd-storage-account "$STORAGE_ACCOUNT" \
--storage-account-type "$STORAGE_ACCOUNT_TYPE"
Once the image has been versioned, you can retrieve the unique image ID for use in VM creation:
IMAGE_ID=$(az sig image-version show \
--query "id" -o tsv)
You’ll use this ID to deploy a new virtual machine based on your custom image.
You’ve successfully uploaded and registered a custom Arm64 VM image in Azure. In the next section, you’ll learn how to create a virtual machine using this image.
