You can view the Azure Linux 3.0 project on GitHub . The project README includes links to ISO downloads.
Using QEMU , you can create a raw disk image, boot a virtual machine with the ISO, and install the operating system. After installation is complete, you’ll convert the image to a fixed-size VHD, upload it to Azure Blob Storage, and use the Azure CLI to create a custom Arm image.
Use wget to download the Azure Linux ISO image file:
wget https://aka.ms/azurelinux-3.0-aarch64.iso
Create a 32 GB empty raw disk image to install the OS:
qemu-img create -f raw azurelinux-arm64.raw 34359738368
You can change the disk size by adjusting the value passed to qemu-img. Ensure it meets the minimum disk size requirements for Azure (typically at least 30 GB).
Use QEMU to boot the operating system in an emulated Arm VM.
qemu-system-aarch64 \
-machine virt \
-cpu cortex-a72 \
-m 4096 \
-nographic \
-bios /usr/share/qemu-efi-aarch64/QEMU_EFI.fd \
-drive if=none,file=azurelinux-arm64.raw,format=raw,id=hd0 \
-device virtio-blk-device,drive=hd0 \
-cdrom azurelinux-3.0-aarch64.iso \
-netdev user,id=net0 \
-device virtio-net-device,netdev=net0
Follow the installer prompts to enter the hostname, username, and password. Use azureuser as the username to ensure compatibility with later steps.
At the end of installation, confirm the reboot prompt. After rebooting into the newly-installed OS, install and enable the Azure Linux Agent:
sudo dnf install WALinuxAgent -y
sudo systemctl enable waagent
sudo systemctl start waagent
sudo poweroff
Now that the raw disk image is ready for you to use, convert it to fixed-size VHD, which makes it compatible with Azure.
qemu-img convert -f raw -o subformat=fixed,force_size -O vpc azurelinux-arm64.raw azurelinux-arm64.vhd
VHD files include a 512-byte footer at the end. The force_size flag ensures the final image size matches the requested virtual size. Without this, QEMU might round the size or adjust for footer overhead (especially when converting from raw to VHD). The force_size flag forces the final image to match the original size. This is required for Azure compatibility, as it avoids rounding errors and ensures the VHD ends at a whole MB or GB boundary.
In the next step, you’ll upload the VHD image to Azure and register it as a custom image for use with Arm-based virtual machines.
