Some learning paths may require one or more server nodes to complete. The Terraform files shown here can be used as a platform to work on those learning paths. The intent is for you to modify these as needed to support other learning path activities.
A Jump Server (also known as a bastion host) is an intermediary device responsible for funneling traffic through firewalls using a supervised secure channel. By creating a barrier between networks, jump servers create an added layer of security against outsiders wanting to maliciously access sensitive company data. Only those with the right credentials can log into a jump server and obtain authorization to proceed to a different security zone.
An alternative to setting up a Jump server like below is to use Azure Bastion .
For deploying Arm VMs on Azure and providing access via Jump Server, the Terraform configuration can be broken down into four files: providers.tf, main.tf, variables.tf and outputs.tf.
Once configured, it creates an instance with OS Login configured to use as a bastion host and a private instance to use alongside the bastion host.
Start by creating these files in your desired directory.
touch providers.tf main.tf variables.tf outputs.tf
Tell Terraform which cloud provider to connect to, Azure for this example.
Using a file editor of your choice, add the code below to a file named providers.tf:
terraform {
required_version = ">=0.12"
required_providers {
azurerm = {
source = "hashicorp/azurerm"
version = "~>2.0"
random = {
source = "hashicorp/random"
version = "~>3.0"
tls = {
source = "hashicorp/tls"
version = "~>4.0"
provider "azurerm" {
features {}
Add the code shown below in a file named main.tf to create the required resources and VM:
# Create a resource group if it doesn’t exist.
resource "azurerm_resource_group" "resource_group" {
name = "${var.resource_prefix}-rg"
location = var.location
# Create virtual network with public and private subnets.
resource "azurerm_virtual_network" "vnet" {
name = "${var.resource_prefix}-vnet"
address_space = ["10.0.0.0/16"]
resource_group_name = azurerm_resource_group.resource_group.name
# Create public subnet for hosting bastion/public VMs.
resource "azurerm_subnet" "public_subnet" {
name = "${var.resource_prefix}-pblc-sn001"
virtual_network_name = azurerm_virtual_network.vnet.name
address_prefixes = ["10.0.1.0/24"]
# Create network security group and SSH rule for public subnet.
resource "azurerm_network_security_group" "public_nsg" {
name = "${var.resource_prefix}-pblc-nsg"
# Allow SSH traffic in from Internet to public subnet.
security_rule {
name = "allow-ssh-all"
priority = 100
direction = "Inbound"
access = "Allow"
protocol = "Tcp"
source_port_range = "*"
destination_port_range = "22"
source_address_prefix = "*"
destination_address_prefix = "*"
# Associate network security group with public subnet.
resource "azurerm_subnet_network_security_group_association" "public_subnet_assoc" {
subnet_id = azurerm_subnet.public_subnet.id
network_security_group_id = azurerm_network_security_group.public_nsg.id
# Create a public IP address for bastion host VM in public subnet.
resource "azurerm_public_ip" "public_ip" {
name = "${var.resource_prefix}-ip"
allocation_method = "Dynamic"
# Create network interface for bastion host VM in public subnet.
resource "azurerm_network_interface" "bastion_nic" {
name = "${var.resource_prefix}-bstn-nic"
ip_configuration {
name = "${var.resource_prefix}-bstn-nic-cfg"
private_ip_address_allocation = "Dynamic"
public_ip_address_id = azurerm_public_ip.public_ip.id
# Create private subnet for hosting target VMs.
resource "azurerm_subnet" "private_subnet" {
name = "${var.resource_prefix}-prvt-sn001"
address_prefixes = ["10.0.2.0/24"]
# Create network security group and SSH rule for private subnet.
resource "azurerm_network_security_group" "private_nsg" {
name = "${var.resource_prefix}-prvt-nsg"
# Allow SSH traffic in from public subnet to private subnet.
security_rule {
name = "allow-ssh-public-subnet"
priority = 100
access = "Allow"
protocol = "Tcp"
source_address_prefix = "10.0.1.0/24"
# Block all outbound traffic from private subnet to Internet.
security_rule {
name = "deny-internet-all"
priority = 200
direction = "Outbound"
access = "Deny"
protocol = "Tcp"
destination_port_range = "*"
# Associate network security group with private subnet.
resource "azurerm_subnet_network_security_group_association" "private_subnet_assoc" {
subnet_id = azurerm_subnet.private_subnet.id
network_security_group_id = azurerm_network_security_group.private_nsg.id
# Create network interface for target host VM in private subnet.
resource "azurerm_network_interface" "target_nic" {
name = "${var.resource_prefix}-trgt-nic"
ip_configuration {
name = "${var.resource_prefix}-trgt-nic-cfg"
# Generate random text for a unique storage account name.
resource "random_id" "random_id" {
keepers = {
# Generate a new ID only when a new resource group is defined.
resource_group = "${azurerm_resource_group.resource_group.name}"
byte_length = 8
# Create storage account for boot diagnostics.
resource "azurerm_storage_account" "storage_account" {
name = "diag${random_id.random_id.hex}"
account_tier = "Standard"
account_replication_type = "LRS"
# Create bastion host VM.
resource "azurerm_linux_virtual_machine" "bastion_vm" {
name = "${var.resource_prefix}-bstn-vm001"
network_interface_ids = ["${azurerm_network_interface.bastion_nic.id}"]
size = "Standard_D2ps_v5"
os_disk {
name = "${var.resource_prefix}-bstn-dsk001"
caching = "ReadWrite"
storage_account_type = "Premium_LRS"
source_image_reference {
publisher = "Canonical"
offer = "0001-com-ubuntu-server-focal"
sku = "20_04-lts-arm64"
version = "20.04.202209200"
computer_name = "${var.resource_prefix}-bstn-vm001"
admin_username = var.username
disable_password_authentication = true
admin_ssh_key {
public_key = file("~/.ssh/id_rsa.pub")
boot_diagnostics {
storage_account_uri = azurerm_storage_account.storage_account.primary_blob_endpoint
# Create target host VM.
resource "azurerm_linux_virtual_machine" "target_vm" {
name = "${var.resource_prefix}-trgt-vm001"
network_interface_ids = ["${azurerm_network_interface.target_nic.id}"]
os_disk {
name = "${var.resource_prefix}-trgt-dsk001"
computer_name = "${var.resource_prefix}-trgt-vm001"
admin_ssh_key {
boot_diagnostics {
To define the variables required to create a virtual machine, add the code below in a file named variables.tf:
# Define prefix for consistent resource naming.
variable "resource_prefix" {
default = "bastion-test"
description = "Service prefix to use for naming of resources."
# Define Azure region for resource placement.
variable "location" {
default = "eastus2"
description = "Azure region for deployment of resources."
# Define username for use on the hosts.
variable "username" {
default = "ubuntu"
description = "Username to build and use on the VM hosts."
Add the code below in outputs.tf to get the Private IP addresses name and Public IP address of the Bastion VM:
# IP address of public IP addresses provisioned for bastion VM.
output "public_ip_address" {
description = "IP address of public IP addresses provisioned for bastion VM."
value = azurerm_linux_virtual_machine.bastion_vm.public_ip_address
# IP addresses of private IP addresses provisioned.
output "private_ip_addresses" {
description = "IP addresses of private IP addresses provisioned."
value = concat(azurerm_network_interface.bastion_nic.*.private_ip_address, azurerm_network_interface.target_nic.*.private_ip_address)
Run terraform init to initialize the Terraform deployment. This command downloads the Azure modules required to manage your Azure resources.
terraform init
The output should be similar to:
Initializing the backend...
Initializing provider plugins...
Terraform has been successfully initialized!
You may now begin working with Terraform. Try running "terraform plan" to see
any changes that are required for your infrastructure. All Terraform commands
should now work.
If you ever set or change modules or backend configuration for Terraform,
rerun this command to reinitialize your working directory. If you forget, other
commands will detect it and remind you to do so if necessary.
Run terraform plan to create and preview an execution plan before applying it to your cloud infrastructure.
terraform plan -out main.tfplan
A long output of resources to be created will be printed. The bottom of the output should be similar to:
Plan: 15 to add, 0 to change, 0 to destroy.
Changes to Outputs:
+ private_ip_addresses = [
+ (known after apply),
+ public_ip_address = (known after apply)
Saved the plan to: main.tfplan
The terraform plan command is optional. You can directly run the terraform apply command, but it is always better to confirm the resources that will be created.
Run terraform apply to apply the execution plan to your cloud infrastructure. The command below creates all required infrastructure.
terraform apply main.tfplan
If prompted to confirm if you want to create Azure resources, answer yes.
Apply complete! Resources: 15 added, 0 changed, 0 destroyed.
Outputs:
"10.0.1.4",
"10.0.2.4",
public_ip_address = "20.242.22.182"
Make note of the outputs to identify your instances. This is particularly useful when having multiple instances.
In the Azure Portal, go to the Virtual Machines page to verify your instances setup. You should see the following two instances running:
public_ip_address output and an address from the private_ip_addresses output.private_ip_addresses output.Click on the Instance Names to display more details about your instances, including the Private IP Address.
Connect to a target server via a Jump Host using the -J flag from the command line. This tells SSH to make a connection to the jump host and then establish a TCP forwarding to the target server from there:
ssh -J ubuntu@<bastion-vm-public-IP> ubuntu@<target-vm-private-IP>
Replace <bastion-vm-public-IP> with the public IP of the bastion VM and <target-vm-private-IP> with the private IP of the target VM.
Terminal applications such as PuTTY , MobaXterm and similar can be used.
The output is shown below. Once connected, you are now ready to use your instance.
ubuntu@ip-172-31-38-39:~/azure_jumpserver$ ssh -J ubuntu@20.242.22.182 ubuntu@l0.0.2.4
The authenticity of host '20.242.22.182 (20.242.22.182)" can't be established.
ED25519 key fingerprint is SHA256:013xvbJhZRyRrvT} +p4g/YpLya6Q7/xSOhwusOUGKQ -
This key is not known by any other names
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added 20.242.22.163 (ED3519) to the List of known hosts.
The authenticity of host '10.0.2.4 (<no hostip for proxy command>)' can't be established.
ED25519 key fingerprint is SHA256:hSQPO0LVa/UB4AHOZe2IpCCOHXOrCCYyYJKnmVxlzk .
Warning: Permanently added '10.0.2.4' (ED25519) to the List of known hosts.
Welcome to Ubuntu 20.04.5 LTS (GNU/Linux 5.15.6-1020-azure aarch64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https: //ubuntu.con/advantage
System information as of Wed Apr 5 12:54:51 UTC 2023
System load: 0.0 Processes: 127
Usage of /: 4.6% of 28.0068 Users logged in: 0
Memory usage: 3% IPv4 address for eth0: 10.0.2.4
Swap usage: 0%
0 updates can be applied immediately.
The list of available updates is more than a week old.
To check for new updates run: sudo apt update
Last login: Wed Apr 5 12:54:23 2023 from 10.0.1.4
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
ubuntu@bastion-test-trgt-vnoo1:~s
Run terraform destroy to delete all resources created through Terraform, including resource groups, virtual networks, and all other resources.
terraform destroy
A long output of resources to destroy will be printed. If prompted to confirm if you want to destroy all resources, answer yes.
Destroy complete! Resources: 15 destroyed.
Use the uname utility to verify that you are using an Arm-based server. For example:
uname -m
will identify the host machine as aarch64.
Install the gcc compiler. If you are using Ubuntu, use the following commands. If not, refer to the
GNU compiler install guide
sudo apt-get update
sudo apt install -y gcc
Using a text editor of your choice, create a file named hello.c with the contents below:
#include <stdio.h>
int main(){
printf("hello world\n");
return 0;
Build and run the application:
gcc hello.c -o hello
./hello
The output is shown below:
hello world
