An Azure Resource Manager template is a JSON file organized into six sections:
$schema: defines the template language versioncontentVersion: your template’s version numberparameters: input values that customize the deploymentvariables: computed values used throughout the templateresources: Azure resources to createoutputs: values returned after deploymentCreate a new file named cobalt-vm-template.json on your local machine. This template deploys a Cobalt 100 VM with all necessary networking components.
"$schema": "https://schema.management.azure.com/schemas/2019-04-01/deploymentTemplate.json#",
"contentVersion": "1.0.0.0",
"parameters": {
"projectName": {
"type": "string",
"metadata": {
"description": "Prefix for resource names"
"location": {
"type": "string",
"defaultValue": "[resourceGroup().location]",
"metadata": {
"description": "Azure region for resources"
"adminUsername": {
"type": "string",
"metadata": {
"description": "Admin username for the VM"
"adminPublicKey": {
"type": "string",
"metadata": {
"description": "SSH public key for authentication"
"vmSize": {
"type": "string",
"defaultValue": "Standard_D4ps_v6",
"metadata": {
"description": "Cobalt 100 VM size (Dpsv6 series)"
"variables": {
"vNetName": "[concat(parameters('projectName'), '-vnet')]",
"vNetAddressPrefixes": "10.0.0.0/16",
"vNetSubnetName": "default",
"vNetSubnetAddressPrefix": "10.0.0.0/24",
"vmName": "[concat(parameters('projectName'), '-vm')]",
"publicIPAddressName": "[concat(parameters('projectName'), '-ip')]",
"networkInterfaceName": "[concat(parameters('projectName'), '-nic')]",
"networkSecurityGroupName": "[concat(parameters('projectName'), '-nsg')]",
"networkSecurityGroupName2": "[concat(variables('vNetSubnetName'), '-nsg')]"
"resources": [
"type": "Microsoft.Network/networkSecurityGroups",
"apiVersion": "2023-04-01",
"name": "[variables('networkSecurityGroupName')]",
"location": "[parameters('location')]",
"properties": {
"securityRules": [
"name": "ssh_rule",
"properties": {
"description": "Allow SSH access",
"protocol": "Tcp",
"sourcePortRange": "*",
"destinationPortRange": "22",
"sourceAddressPrefix": "*",
"destinationAddressPrefix": "*",
"access": "Allow",
"priority": 100,
"direction": "Inbound"
"type": "Microsoft.Network/publicIPAddresses",
"name": "[variables('publicIPAddressName')]",
"properties": {
"publicIPAllocationMethod": "Dynamic"
"sku": {
"name": "Basic"
"name": "[variables('networkSecurityGroupName2')]",
"properties": {
"securityRules": [
"name": "default-allow-ssh",
"properties": {
"priority": 100,
"access": "Allow",
"direction": "Inbound",
"protocol": "Tcp",
"type": "Microsoft.Network/virtualNetworks",
"name": "[variables('vNetName')]",
"dependsOn": [
"[resourceId('Microsoft.Network/networkSecurityGroups', variables('networkSecurityGroupName2'))]"
"properties": {
"addressSpace": {
"addressPrefixes": [
"[variables('vNetAddressPrefixes')]"
"subnets": [
"name": "[variables('vNetSubnetName')]",
"properties": {
"addressPrefix": "[variables('vNetSubnetAddressPrefix')]",
"networkSecurityGroup": {
"id": "[resourceId('Microsoft.Network/networkSecurityGroups', variables('networkSecurityGroupName2'))]"
"type": "Microsoft.Network/networkInterfaces",
"name": "[variables('networkInterfaceName')]",
"dependsOn": [
"[resourceId('Microsoft.Network/publicIPAddresses', variables('publicIPAddressName'))]",
"[resourceId('Microsoft.Network/virtualNetworks', variables('vNetName'))]",
"[resourceId('Microsoft.Network/networkSecurityGroups', variables('networkSecurityGroupName'))]"
"properties": {
"ipConfigurations": [
"name": "ipconfig1",
"properties": {
"privateIPAllocationMethod": "Dynamic",
"publicIPAddress": {
"id": "[resourceId('Microsoft.Network/publicIPAddresses', variables('publicIPAddressName'))]"
"subnet": {
"id": "[resourceId('Microsoft.Network/virtualNetworks/subnets', variables('vNetName'), variables('vNetSubnetName'))]"
"id": "[resourceId('Microsoft.Network/networkSecurityGroups', variables('networkSecurityGroupName'))]"
"type": "Microsoft.Compute/virtualMachines",
"apiVersion": "2023-03-01",
"name": "[variables('vmName')]",
"dependsOn": [
"[resourceId('Microsoft.Network/networkInterfaces', variables('networkInterfaceName'))]"
"properties": {
"hardwareProfile": {
"vmSize": "[parameters('vmSize')]"
"osProfile": {
"computerName": "[variables('vmName')]",
"adminUsername": "[parameters('adminUsername')]",
"linuxConfiguration": {
"disablePasswordAuthentication": true,
"ssh": {
"publicKeys": [
"path": "[concat('/home/', parameters('adminUsername'), '/.ssh/authorized_keys')]",
"keyData": "[parameters('adminPublicKey')]"
"storageProfile": {
"imageReference": {
"publisher": "Canonical",
"offer": "ubuntu-24_04-lts",
"sku": "server-arm64",
"version": "latest"
"osDisk": {
"createOption": "FromImage",
"managedDisk": {
"storageAccountType": "Premium_LRS"
"networkProfile": {
"networkInterfaces": [
"id": "[resourceId('Microsoft.Network/networkInterfaces', variables('networkInterfaceName'))]"
"outputs": {
"vmName": {
"type": "string",
"value": "[variables('vmName')]"
"resourceGroup": {
"type": "string",
"value": "[resourceGroup().name]"
The template includes several Arm-specific configurations.
VM size: The vmSize parameter defaults to Standard_D4ps_v6, part of the Dpsv6 series powered by Cobalt 100 processors. The D4ps_v6 size provides four vCPUs with general-purpose compute capabilities on Arm64 architecture.
Other available Cobalt 100 VM sizes include Standard_D2ps_v6 (two vCPUs), Standard_D8ps_v6 (8 vCPUs), and Standard_D16ps_v6 (16 vCPUs).
Image reference: The storageProfile section specifies the operating system image with Arm64 architecture. The template uses Ubuntu 24.04 LTS:
"imageReference": {
"version": "latest"
You can change the Arm64 image used in the imageReference section. For Ubuntu 22.04 LTS:
"imageReference": {
"offer": "0001-com-ubuntu-server-jammy",
"sku": "22_04-lts-arm64",
"version": "latest"
To find available Arm64 images for other Linux distributions, use:
az vm image list --all --architecture Arm64 --output table
SSH authentication: The template configures SSH key authentication and disables password authentication for enhanced security:
"ssh": {
"publicKeys": [
You’ve created a complete Resource Manager template that defines network infrastructure, a Cobalt 100 VM with Ubuntu 24.04 LTS, and SSH key authentication. The template uses parameters for flexibility, allowing you to customize deployments without modifying the template structure.
Next, you’ll deploy this template to Azure and connect to your new Cobalt 100 VM.
