Explore related resources
Give feedback
AI-assisted
Close
How do I confirm the Azure region I selected supports Cobalt 100 VM sizes?
Run az vm list-skus for the target region and filter for the Dpsv6 series. For example: az vm list-skus --location eastus --size Standard_D --all --output table | grep "ps_v6".
Which VM size should I set in the template for a Cobalt 100 instance?
Choose a Dpsv6 series size returned by the SKU query for your region. The output example shows sizes such as Standard_D16ps_v6.
Where do I find the VM’s public IP address after deployment?
Use the value surfaced in the previous deployment step, often provided as a deployment output. You can also view the Public IP resource created in the resource group defined by the template.
What username should I use when connecting with SSH?
Use the admin username defined in your template’s parameters. The example uses azureuser; if your template specifies a different name, use that instead.
What output confirms the VM is running on `arm64`?
Run uname -m and expect aarch64. You can also run lscpu to see Arm 64-bit CPU details.
