# [Deploy Arm instances on AWS and provide access via Jump Server](https://learn.arm.com/learning-paths/servers-and-cloud-computing/aws-terraform/jump_server_aws/)
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/aws-terraform/)
- [Automate AWS instance creation using Terraform](https://learn.arm.com/learning-paths/servers-and-cloud-computing/aws-terraform/terraform/)
- [Deploy Arm instances on AWS and provide access via Jump Server](https://learn.arm.com/learning-paths/servers-and-cloud-computing/aws-terraform/jump_server_aws/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/aws-terraform/_next-steps/)
## Infrastructure automation for other Learning Paths
Some learning paths may require one or more server nodes to complete. The Terraform files shown here can be used as a platform to work on those learning paths. The intent is for you to modify these as needed to support other learning path activities.
## Introduction to Jump Server
A Jump Server (also known as a bastion host) is an intermediary device responsible for funneling traffic through firewalls using a supervised secure channel. By creating a barrier between networks, jump servers create an added layer of security against outsiders wanting to maliciously access sensitive company data. Only those with the right credentials can log into a jump server and obtain authorization to proceed to a different security zone.
**Note**
An alternative to setting up a Jump server like below is to use [Linux Bastion Hosts](https://aws.amazon.com/solutions/implementations/linux-bastion/) or [AWS Systems Manager service](https://aws.amazon.com/systems-manager/).
## Deploying Arm instances on AWS and providing access via Jump Server
For deploying Arm instances on AWS and providing access via Jump Server, the Terraform configuration can be broken down into six files: `variables.tf`, `provider.tf`, `VPC_subnet_IG_RT.tf`, `security_groups.tf`, `ec2.tf` and `outputs.tf`.
Once configured, it creates an instance with OS Login configured to use as a bastion host and a private instance to use alongside the bastion host.
Start by creating these files in your desired directory.
```bash
touch variables.tf provider.tf VPC_subnet_IG_RT.tf security_groups.tf ec2.tf outputs.tf
### Variables
`variables.tf` configures the **region**, **ami**, **instance type**, **disk size**, and **IP range** for both the private server and jump server.
Add the code below to the `variables.tf` file:
```hcl
variable "region" {
  description = "The AWS region to create resources in."
  default     = "us-east-1"
variable "ubuntu-ami" {
  description = "Ubuntu 22.04 AMI image"
  default     = "ami-0f69dd1d0d03ad669" // Ubuntu ARM64 Image
  nullable    = false
// Bastion Server Credentials
variable "bastionhost-instance-type" {
  description = "Instance Type of bastion/Jump server"
  default     = "t4g.small"
variable "bastionhost-disk-size" {
  description = "Root disk size of bastion/Jump server"
  default     = 8
variable "jump-server-IP-Range" {
  default = "0.0.0.0/0"
// Private Server Credentials
variable "instance-type-1" {
  description = "Instance Type of private server"
variable "disk-size-1" {
  description = "Root disk size of private server"
  default     = 40
### Provider
`provider.tf` contains a `region` variable that controls where to deploy the instances.
Add the code below to the `provider.tf` file:
```hcl
provider "aws" {
  region = var.region
### Main Resources
`VPC_subnet_IG_RT.tf` contains the following several resources. For more information about these resources, see the [Amazon VPC Documentation](https://docs.aws.amazon.com/vpc/latest/userguide/how-it-works.html).
1. [Virtual Private Cloud (VPC)](https://docs.aws.amazon.com/vpc/latest/userguide/what-is-amazon-vpc.html)
2. [Subnets](https://docs.aws.amazon.com/vpc/latest/userguide/configure-subnets.html)
3. [Internet Gateway (IG)](https://docs.aws.amazon.com/vpc/latest/userguide/VPC_Internet_Gateway.html)
4. [Route Table (RT)](https://docs.aws.amazon.com/vpc/latest/userguide/VPC_Route_Tables.html)
5. [Network Address Translation (NAT) gateway](https://docs.aws.amazon.com/vpc/latest/userguide/vpc-nat-gateway.html)
Specifically, we will have a Virtual Private Cloud (VPC) with a CIDR block size of /16. In that VPC, we will have the following two subnets with a CIDR block size of /24 each:
1. Public Subnet (for Jump Server access, accessible from Public World)
2. Private Subnet (for Private Server access, restricted from Public World)
Then, we will have a Route Table for the Internet Gateway so that instance can connect to the outside world, update it, and associate it with the private subnet.
Finally, create a Network Address Translation gateway to connect your VPC/Network to the internet and attach this gateway to your VPC in the public network.
Add the code below to the `VPC_subnet_IG_RT.tf` file:
```hcl
// VPC creation
resource "aws_vpc" "Demo_VPC" {
  cidr_block           = "10.1.0.0/16"
  instance_tenancy     = "default"
  enable_dns_support   = "true"
  enable_dns_hostnames = "true"
  tags = {
    Name = "VPC"
// Subnet creation
resource "aws_subnet" "Public_Subnet" {
  vpc_id                  = aws_vpc.Demo_VPC.id
  cidr_block              = "10.1.1.0/24"
  map_public_ip_on_launch = "true"
  availability_zone       = "us-east-1a"
  tags = {
    Name = "Jump Public Subnet"
resource "aws_subnet" "Private_Subnet" {
  cidr_block              = "10.1.2.0/24"
  availability_zone       = "us-east-1b"
  tags = {
    Name = "Private Subnet"
resource "aws_internet_gateway" "IGW" {
  tags = {
    Name = "VPC Internet Gateway"
resource "aws_route_table" "Route_table" {
  tags = {
    Name = "VPC Route Table"
resource "aws_route" "VPC_internet_access" {
  route_table_id         = aws_route_table.Route_table.id
  destination_cidr_block = "0.0.0.0/0"
  gateway_id             = aws_internet_gateway.IGW.id
resource "aws_route_table_association" "VPC_association" {
  subnet_id      = aws_subnet.Public_Subnet.id
resource "aws_eip" "jump-eip" {
  vpc              = true
  public_ipv4_pool = "amazon"
resource "aws_nat_gateway" "eip" {
  depends_on    = [aws_eip.jump-eip]
  allocation_id = aws_eip.jump-eip.id
  tags = {
    Name = "NAT_Gateway"
// Route table for SNAT in private subnet
resource "aws_route_table" "private_subnet_route_table" {
  depends_on = [aws_nat_gateway.eip]
  route {
    gateway_id = aws_nat_gateway.eip.id
  tags = {
    Name = "private_subnet_route_table"
resource "aws_route_table_association" "private_subnet_route_table_association" {
  depends_on     = [aws_route_table.private_subnet_route_table]
  subnet_id      = aws_subnet.Private_Subnet.id
  route_table_id = aws_route_table.private_subnet_route_table.id
### Security Groups
`security_groups.tf` creates two security groups, one for the Bastion Host and one for the Private Instance, in order to allow SSH access from this Bastion Host.
Add the code below to the `security_groups.tf` file:
```hcl
resource "aws_security_group" "only_ssh_bastion" {
  depends_on = [aws_subnet.Public_Subnet]
  name       = "only_ssh_bastion"
  ingress {
    from_port   = 22
    to_port     = 22
    protocol    = "tcp"
    cidr_blocks = ["${var.jump-server-IP-Range}"]
  egress {
    from_port   = 0
    to_port     = 0
    protocol    = "-1"
    cidr_blocks = ["0.0.0.0/0"]
  tags = {
    Name = "only_ssh_bastion"
resource "aws_security_group" "only_ssh_private_instance" {
  name        = "only_ssh_private_instance"
  description = "allow ssh bastion inbound traffic"
  ingress {
    description     = "Only ssh_sql_bastion in public subnet"
    from_port       = 22
    to_port         = 22
    protocol        = "tcp"
    security_groups = [aws_security_group.only_ssh_bastion.id]
  egress {
    from_port        = 0
    to_port          = 0
    protocol         = "-1"
    ipv6_cidr_blocks = ["::/0"]
  tags = {
    Name = "only_ssh_sql_bastion"
### AWS EC2 Instance Resources
`ec2.tf` creates a Bastion/Jump server and a Private Instance.
Add the code below to the `ec2.tf` file:
```hcl
// Bastion/Jump server
resource "aws_instance" "BASTION" {
  ami                    = var.ubuntu-ami
  instance_type          = var.bastionhost-instance-type
  vpc_security_group_ids = [aws_security_group.only_ssh_bastion.id]
  key_name               = aws_key_pair.deployer.key_name
  root_block_device {
    volume_size           = var.bastionhost-disk-size
    volume_type           = "gp2"
    encrypted             = true
    delete_on_termination = true
  tags = {
    Name = "bastion-host"
// Private instance
resource "aws_instance" "ec2" {
  instance_type          = var.instance-type-1
  vpc_security_group_ids = [aws_security_group.only_ssh_private_instance.id]
  root_block_device {
    volume_size           = var.disk-size-1
    volume_type           = "gp2"
    encrypted             = true
  tags = {
    Name = "terraform"
resource "aws_key_pair" "deployer" {
  key_name   = "id_rsa"
  public_key = file("~/.ssh/id_rsa.pub")
### Outputs
`outputs.tf` defines the output values for this configuration.
Add the code below to the `outputs.tf` file:
```hcl
output "EC2-public_ip" {
  value = aws_instance.ec2.public_ip
output "EC2-private_ip" {
  value = aws_instance.ec2.private_ip
output "bastionhost-public-ip" {
  value = aws_instance.BASTION.public_ip
## Terraform commands
### Initialize Terraform
Run `terraform init` to initialize the Terraform deployment. This command is responsible for downloading all the dependencies which are required for the provider AWS.
```bash
terraform init
The output should be similar to what is shown below:
__output__Initializing the backend...
__output__
__output__Initializing provider plugins...
__output__
__output__Terraform has been successfully initialized!
__output__
__output__You may now begin working with Terraform. Try running "terraform plan" to see
__output__any changes that are required for your infrastructure. All Terraform commands
__output__should now work.
__output__
__output__If you ever set or change modules or backend configuration for Terraform,
__output__rerun this command to reinitialize your working directory. If you forget, other
__output__commands will detect it and remind you to do so if necessary.
### Create a Terraform execution plan
Run `terraform plan` to create an execution plan.
```bash
terraform plan -out main.tfplan
A long output of resources to be created will be printed. The bottom of the output should be similar to:
__output__Plan: 19 to add, 0 to change, 0 to destroy.
__output__
__output__Changes to Outputs:
__output__  + EC2-private_ip        = (known after apply)
__output__  + EC2-public_ip         = (known after apply)
__output__  + bastionhost-public-ip = (known after apply)
__output__
__output__────────────────────────────────────────────────────────────────────────────────────────────────
__output__
__output__Saved the plan to: main.tfplan
### Apply a Terraform execution plan
Run `terraform apply` to apply the execution plan to your cloud infrastructure. The command below creates all required infrastructure.
```bash
terraform apply main.tfplan
If prompted to confirm if you want to create AWS resources, answer `yes`.
The bottom of the output should be similar to what is shown below:
__output__Apply complete! Resources: 19 added, 0 changed, 0 destroyed
__output__
__output__outputs:
__output__
__output__EC2-private_ip = "10.1.2.76"
__output__EC2-public_ip = "54.221.51.159"
__output__bastionhost-public_ip = "54.152.41.75"
Make note of the outputs to identify your instances. This is particularly useful when having multiple instances.
### Verify the Instance and Bastion Host setup
Verify the instances setup on the AWS Console.
Go to **EC2 -> instances** you should see the following two instances running:
1. An instance named **terraform** with the **Public** and **Private IPv4 addresses** matching your `EC2-public_ip` and `EC2-private_ip` outputs above.
2. An instance named **bastion** with the **Public IPv4 address** matching your `bastionhost-public_ip` output above.
Click on the **Instance IDs** to display the **Instance Summary** view which includes more details about your instances.
![Locate your instances on the AWS Console](https://github.com/ArmDeveloperEcosystem/arm-learning-paths/assets/71631645/eb7569b7-ddfb-4c5a-b450-ab903cf4e8df)
### Use Jump Host to access the Private Instance
Connect to a target server via a Jump Host using the `-J` flag from the command line. This tells SSH to make a connection to the jump host and then establish a TCP forwarding to the target server from there. For example, if using a `ubuntu` AMI:
```bash
ssh -J ubuntu@<jump-host-IP> ubuntu@<target-server-IP>
**Note**
Replace `<jump-host-IP>` with the public IP of the bastion VM and `<target-server-IP>` with the private IP of the target VM.
Terminal applications such as [PuTTY](https://www.putty.org/), [MobaXterm](https://mobaxterm.mobatek.net/) and similar can be used.
Different Linux distributions have different default usernames you can use to connect.
[Default usernames](https://docs.aws.amazon.com/AWSEC2/latest/UserGuide/connection-prereqs.html) for AMIs are listed in a table. Find your operating system and see the default username you should use to connect.
The output is shown below. Once connected, you are now ready to use your instance.
__output__ubuntu@ip-172-31-46-24:~/ $ ssh -J ubuntu@54.205.132.186 ubuntu@10.1.2.76
__output__The authenticity of host '54.205.132.186 (54.205.132.186)' can't be established.
__output__ED25519 key fingerprint is SHA256:LEP11QPanpvagrBEfz71C5111gUQjAUTtzIF8ovAdzT.
__output__This key is not known by any other names
__output__Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
__output__Warning: Permanently added '54.205.132.186' (ED25519) to the list of known hosts.
__output__The authenticity of host '10.1.2.76 (<no hostip for proxy command>)' can't be established.
__output__ED25519 key fingerprint is SHA256:4FsZ5txilwvvrbaIkvdxJuznb6dKQiN2FSyd7/I/EtQ.
__output__Warning: Permanently added '10.1.2.76' (ED25519) to the list of known hosts.
__output__Welcome to Ubuntu 22.04.1 LTS (GNU/Linux 5.15.0-1019-aws aarch64)
### Clean up resources
Run `terraform destroy` to delete all resources created through Terraform, including resource groups, virtual networks, and all other resources.
```bash
terraform destroy
A long output of resources to destroy will be printed. If prompted to confirm if you want to destroy all resources, answer `yes`.
__output__Destroy complete! Resources: 19 destroyed.
## Explore your instance
### Run uname
Use the [uname](https://en.wikipedia.org/wiki/Uname) utility to verify that you are using an Arm-based server. For example:
```bash
uname -m
will identify the host machine as `aarch64`.
### Run hello world
Install the `gcc` compiler. If you are using `Ubuntu`, use the following commands. If not, refer to the [GNU compiler install guide](/install-guides/gcc/):
```bash
sudo apt-get update
sudo apt install -y gcc
Using a text editor of your choice, create a file named `hello.c` with the contents below:
```c
#include <stdio.h>
int main(){
    printf("hello world\n");
    return 0;
Build and run the application:
```bash
gcc hello.c -o hello
./hello
The output is shown below:
__output__hello world
