Explore related resources
Give feedback
AI-assisted
Close
How do I confirm the AWS CDK CLI is installed before starting?
Run cdk --version. A version string should print to the terminal.
From which directory should I run the synthesis step?
Run the synthesis command from the project directory created for the sample CDK app. The generated template appears under cdk.out.
What file should be produced after synthesis, and where is it located?
You should see a CloudFormation template named cdk.out/ArmCdkAppStack.template.json. This is the synthesized output the CDK uses for deployment.
Do I need to bootstrap before deploying the stack?
Yes. After synthesis, bootstrap the environment so the CDK can create required deployment resources. When bootstrapping completes without errors, proceed to deploy.
How do I know the ECS service is configured for Arm-based AWS Fargate?
The sample CDK application defines an ECS service running on Arm-based AWS Fargate compute. Use the provided definitions and deploy the stack to apply those settings.
