Install and configure Kiro Arm SoC Migration Power
In this section, you will install Kiro IDE, enable Kiro Arm SoC Migration Power, and prepare the development environment.
Kiro runs locally on your development machine. The Migration Power uses the Arm MCP server deployed as a containerized backend (using Docker) to provide Arm-specific guidance. You will also provision an AWS Graviton3 instance to act as the source platform for the migration example.
Install Kiro IDE
Kiro IDE provides AI-powered development assistance and hosts the Arm SoC Migration Power that will guide you through the migration process.
Download and install Kiro IDE for your platform:
macOS:
brew install --cask kiro
Windows and Linux: Visit https://kiro.dev to download the installer for your platform.
After installation completes, launch Kiro IDE to proceed.
Install the Power in Kiro
The Arm SoC Migration Power extends Kiro with specialized knowledge and tools for migrating applications between Arm platforms.
  • Open Kiro IDE
  • Navigate to the Powers panel. Press Cmd + Shift + P (Mac) or Ctrl + Shift + P (Windows)
  • Select the Perform Migration between Arm SoC in the Recommended section
  • Select Install
Verify install
After installation, you can either click on the “Try power” button or enter the following prompt in Kiro:
I just installed the arm-soc-migration power and want to use it.
The Power should respond and guide you through any additional setup steps.
It supports migrations across a wide range of Arm-based platforms, including:
  • AWS Graviton (Neoverse-based servers)
  • Raspberry Pi (Cortex-A)
  • NVIDIA Jetson
  • NXP i.MX
  • Other Linux-based Arm SoCs
Install prerequisites
The Perform Migration between Arm SoC uses the Arm MCP (Model Context Protocol) server to provide specialized Arm migration capabilities. The Arm MCP server runs via Docker.
Install Docker on your local development machine (required for ARM MCP server):
macOS:
brew install --cask docker
Linux:
# Ubuntu/Debian
sudo apt-get update
sudo apt-get install -y docker.io
# Or use Docker's official installation script
curl -fsSL https://get.docker.com -o get-docker.sh
sudo sh get-docker.sh
Windows: Download Docker Desktop from https://www.docker.com/products/docker-desktop
Verify installation:
docker --version
Note
Ensure Docker is running before using the Perform Migration between Arm SoC. The Power will automatically pull and run the Arm MCP server container when needed.
Launch AWS Graviton3 instance (source platform)
You will use an AWS Graviton3 instance as the source platform in this migration scenario.
Note
Before proceeding, ensure you are authenticated with the AWS CLI. Follow the AWS CLI install guide if you haven’t configured credentials yet.
Verify your AWS CLI authentication:
aws sts get-caller-identity
If you see an error or need to configure AWS CLI, follow the AWS CLI Configuration Guide to set up your credentials.
Create an SSH key and security group, then launch a c7g.medium Graviton3 instance. Run each command separately to make it easier to identify any errors.
Create the SSH key:
aws ec2 create-key-pair --key-name graviton-migration-key \
  --query 'KeyMaterial' --output text > graviton-migration-key.pem
chmod 400 graviton-migration-key.pem
Create the security group and allow SSH access. Restrict SSH access to your current public IP address.
SG_ID=$(aws ec2 create-security-group \
  --group-name graviton-migration-sg \
  --description "Security group for Arm SoC migration" \
  --query 'GroupId' --output text)
MY_IP=$(curl -s https://checkip.amazonaws.com)
aws ec2 authorize-security-group-ingress \
  --group-id $SG_ID \
  --protocol tcp \
  --port 22 \
  --cidr ${MY_IP}/32
Find the latest Amazon Linux 2023 arm64 AMI and launch the instance:
AMI_ID=$(aws ec2 describe-images \
  --owners amazon \
  --filters "Name=name,Values=al2023-ami-2023*-arm64" "Name=state,Values=available" \
  --query 'reverse(sort_by(Images, &CreationDate))[0].ImageId' \
  --output text)
aws ec2 run-instances \
  --image-id $AMI_ID \
  --instance-type c7g.medium \
  --security-group-ids $SG_ID \
  --tag-specifications 'ResourceType=instance,Tags=[{Key=Name,Value=graviton-migration-source}]' \
  --query 'Instances[0].InstanceId' --output text
Wait until the instance state is running. Retrieve the SSH command:
echo "ssh -i graviton-migration-key.pem ec2-user@$(aws ec2 describe-instances --filters "Name=tag:Name,Values=graviton-migration-source" "Name=instance-state-name,Values=running" --query 'Reservations[0].Instances[0].PublicIpAddress' --output text)"
Copy and execute the output command to connect to your instance.
Install development tools on the Graviton3 instance
The Graviton3 instance needs development tools to compile the sensor-monitor example application.
Once connected to your Graviton3 instance, install the required tools:
sudo dnf install -y gcc make wget tar
In this section:
  • You installed Kiro IDE and the Perform Migration between Arm SoC Power
  • You provisioned an AWS Graviton3 instance as your source platform
  • You installed the build tools needed for the migration example
In the next section, you’ll build and test the sensor-monitor application on the Graviton3 instance to establish a validated baseline before migration.
