In this section, you will build and validate the application on the source Arm platform before performing any migration steps.
This example uses AWS Graviton3 as the source platform. The same principles apply to any Arm-to-Arm migration scenario, such as Raspberry Pi 4 to Raspberry Pi 5 or i.MX8 to Jetson.
Download the sensor-monitor application to your local machine (where Kiro IDE is installed). You inspect the project locally, then build and validate it on the Graviton3 instance.
wget https://github.com/ArmDeveloperEcosystem/arm-learning-paths/raw/main/content/learning-paths/servers-and-cloud-computing/arm-soc-migration-learning-path/projects/sensor-monitor.tar.gz
tar -xzf sensor-monitor.tar.gz
cd sensor-monitor
The archive includes the complete source code, a Makefile, and platform-specific implementations. You will analyze and migrate this code using the Perform Migration between Arm SoC Power.
Before migrating, verify that the application builds and runs correctly on the source Arm platform.
Upload the archive to the Graviton instance:
scp -i graviton-migration-key.pem sensor-monitor.tar.gz ec2-user@$(aws ec2 describe-instances --filters "Name=tag:Name,Values=graviton-migration-source" "Name=instance-state-name,Values=running" --query 'Reservations[0].Instances[0].PublicIpAddress' --output text):~
Connect to the instance:
ssh -i graviton-migration-key.pem ec2-user@$(aws ec2 describe-instances --filters "Name=tag:Name,Values=graviton-migration-source" "Name=instance-state-name,Values=running" --query 'Reservations[0].Instances[0].PublicIpAddress' --output text)
Build the application on the Graviton instance:
cd sensor-monitor
make
./sensor_monitor
If successful, the application compiles for AArch64 using GCC and displays simulated sensor readings.
This confirms:
This validated build becomes your migration baseline. Any functional differences after migration can be compared against this known-good state.
The sensor-monitor application demonstrates a common embedded/edge design pattern: business logic separated from platform-specific hardware interaction.
Project Structure:
sensor-monitor/
├── src/main.c # Main application logic
├── include/sensor.h # Sensor interface
├── platform/graviton/sensor_graviton.c # Graviton implementation
├── platform/rpi5/ # Target platform (created during migration)
├── Makefile # Build configuration
└── README.md # Documentation
Key components:
src/main.c - Main application that reads sensor data in a loop
include/sensor.h - Hardware abstraction interface
platform/graviton/sensor_graviton.c - Simulated sensor for cloud development
In this section:
In the next section, you’ll use the Perform Migration between Arm SoC Power to analyze the codebase and migrate it to the target platform.
