# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/arm-soc-migration-learning-path/)
- [Install Arm SoC Migration Power](https://learn.arm.com/learning-paths/servers-and-cloud-computing/arm-soc-migration-learning-path/setup/)
- [Develop on source platform](https://learn.arm.com/learning-paths/servers-and-cloud-computing/arm-soc-migration-learning-path/graviton-development/)
- [Migrate using Arm SoC Migration Power](https://learn.arm.com/learning-paths/servers-and-cloud-computing/arm-soc-migration-learning-path/migration/)
- [Validate migration with testing](https://learn.arm.com/learning-paths/servers-and-cloud-computing/arm-soc-migration-learning-path/validation/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/arm-soc-migration-learning-path/_next-steps/)
## Explore related resources
- [Kiro Arm SoC Migration Power Documentation](https://kiro.dev/powers/arm-soc-migration)
- [AWS Graviton Technical Guide](https://aws.amazon.com/ec2/graviton/)
- [Raspberry Pi 5 Documentation](https://www.raspberrypi.com/documentation/)
- [Arm Architecture Reference](https://developer.arm.com/documentation)
- [BCM2712 Peripherals Datasheet](https://datasheets.raspberrypi.com/bcm2712/bcm2712-peripherals.pdf)
## Review frequently asked questions
### Where should Kiro and the Arm MCP server run during setup?
Kiro runs locally on your development machine. The Migration Power uses the Arm MCP server deployed as a containerized backend using Docker, started as described in the setup step so Kiro can connect to it.
### Where do I open and build the `sensor-monitor` application before migrating?
Open and inspect the project locally in Kiro, then build and validate it on the AWS Graviton3 source instance. A successful baseline build and run on Graviton3 provides the reference behavior for migration.
### How do I know the discovery phase has identified hardware-dependent code?
Use the Migration Power’s AI-guided analysis to review findings for platform-specific or hardware-dependent code paths. The analysis highlights areas to isolate behind an abstraction before porting.
### What should the hardware abstraction layer include for this migration?
Define clear interfaces for hardware interactions and move platform-specific logic behind those interfaces. Provide target-specific implementations and use the existing build system to select the appropriate implementation per platform.
### What results indicate the migration is validated on both platforms?
Both source and target builds should complete without platform-specific errors, and the application should pass functional checks and hardware interaction tests. Use the Power’s testing recommendations to confirm platform compatibility and compare performance characteristics against the source baseline.
