Set up other agent workflows
In the previous section, you configured an Arm Cloud Migration Agent in GitHub Copilot. Other AI coding tools provide their own mechanisms for defining persistent instructions, such as steering documents or prompt files. While the configuration details vary by tool, the goal remains the same: provide the AI with clear, structured instructions so it can use the Arm MCP Server effectively and carry out multi-step migration workflows autonomously.
This section shows how to set up the same Arm migration workflow in other popular agentic AI systems. The core migration logic stays consistent across platforms, but each tool has its own format for defining these instructions.
Note The migration instructions below implement the same workflow shown in the previous section. If you skipped that section, you can start here directly. Each AI tool simply wraps the same core instructions in a different format.
Set up Kiro steering documents
Kiro uses “steering documents” - markdown files stored in .kiro/steering/ that provide persistent context to the AI. You can configure steering documents with different inclusion modes to control when and how the instructions are applied.
Create Arm migration steering document
To set up Arm migration in Kiro, create the following file at .kiro/steering/arm-migration.md:
inclusion: manual
Your goal is to migrate a codebase from x86 to Arm. Use the MCP server tools to help you with this. Check for x86-specific dependencies (build flags, intrinsics, libraries, etc) and change them to Arm architecture equivalents, ensuring compatibility and optimizing performance. Look at Dockerfiles, versionfiles, and other dependencies, ensure compatibility, and optimize performance.
Steps to follow:
* Look in all Dockerfiles and use the check_image and/or skopeo tools to verify Arm compatibility, changing the base image if necessary.
* Look at the packages installed by the Dockerfile and send each package to the knowledge_base_search tool to check each package for Arm compatibility. If a package isn't compatible, change it to a compatible version. When invoking the tool, explicitly ask "Is [package] compatible with Arm architecture?" where [package] is the name of the package.
* Look at the contents of any requirements.txt files line-by-line and send each line to the knowledge_base_search tool to check each package for Arm compatibility. If a package isn't compatible, change it to a compatible version.
* Look at the codebase that you have access to, and determine what the language used is.
* Run the migrate_ease_scan tool on the codebase, using the appropriate language scanner based on what language the codebase uses, and apply the suggested changes.
* OPTIONAL: If you have access to build tools, rebuild the project for Arm, if you're running on an Arm-based runner. Fix any compilation errors.
* OPTIONAL: If you have access to any benchmarks or integration tests for the codebase, run these and report the timing improvements to the user.
Pitfalls to avoid:
* Don't confuse a software version with a language wrapper package version. For example, when checking the Python Redis client, check the Python package name "redis" rather than the Redis server version.
* NEON lane indices must be compile-time constants, not variables.
* If you're unsure about Arm equivalents, use knowledge_base_search to find documentation.
* Be sure to find out from the user or system what the target machine is, and use the appropriate intrinsics. For instance, if neoverse (Graviton, Axion, Cobalt) is targeted, use the latest SVE2 (or SVE for older neoverse).
If you have good versions to update for the Dockerfile, requirements.txt, and other files, change them immediately without asking for confirmation.
Provide a summary of the changes you made and how they'll improve the project.
Reference this steering document in chat with #arm-migration.
OpenAI Codex prompt files
OpenAI Codex uses markdown prompt files stored in ~/.codex/prompts/ or $CODEX_HOME/prompts/. The filename determines the command name you’ll use to invoke the prompt.
Create Arm migration prompt
Create the following file at ~/.codex/prompts/arm-migrate.md:
description: Migrate codebase from x86 to Arm architecture
Steps to follow:
Pitfalls to avoid:
Running the Codex prompt
Invoke the prompt with:
codex /prompts:arm-migrate
Additional AI assistants
You now have a general understanding of how agentic systems support persistent migration instructions. For AI coding assistants beyond GitHub Copilot, Kiro, and OpenAI Codex, consult their documentation to learn how to define equivalent prompt files or configuration mechanisms and adapt the same Arm migration workflow.
In this section, you’ve learned how to configure Arm migration workflows in other agentic AI systems beyond GitHub Copilot, including Kiro and OpenAI Codex. You’ve seen how the core migration logic remains consistent across platforms while each tool uses its own format for defining persistent instructions.
You’re now equipped to use the Arm MCP Server with your preferred AI coding assistant to automate the migration of x86 applications to Arm-based cloud instances.
