Checking base images for Arm compatibility
This section demonstrates just one example of using direct AI chat with the Arm MCP Server. You can use similar natural language prompts to check library compatibility, search for Arm documentation, or analyze code for migration issues.
A common first step when migrating a containerized application to Arm is verifying that the base container images support the arm64 architecture. The Arm MCP Server simplifies this process by allowing you to ask this question directly using a natural language prompt, without manually inspecting image manifests or registry metadata.
Direct AI chat works best as a fast decision gate as it helps you rule out incompatible base images and configurations before investing time in deeper migration or automation work.
Example: Legacy CentOS 6 application
Consider an application built on CentOS 6, a legacy Linux distribution that has reached end of life (EOL). This example represents a typical x86-optimized, compute-heavy benchmark application that you might encounter when migrating older workloads.
Before examining the Dockerfile, note that it contains several x86-specific elements that need attention during migration: the centos:6 base image (which might lack arm64 support), the -mavx2 compiler flag for x86 AVX2 SIMD instructions, and C++ source files with x86 intrinsics.
Copy this Dockerfile into VS Code using GitHub Copilot or another agentic IDE connected to the Arm MCP Server:
FROM centos:6
# CentOS 6 reached EOL, need to use vault mirrors
RUN sed -i 's|^mirrorlist=|#mirrorlist=|g' /etc/yum.repos.d/CentOS-Base.repo && \
    sed -i 's|^#baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g' /etc/yum.repos.d/CentOS-Base.repo
# Install EPEL repository (required for some development tools)
RUN yum install -y epel-release && \
    sed -i 's|^mirrorlist=|#mirrorlist=|g' /etc/yum.repos.d/epel.repo && \
    sed -i 's|^#baseurl=http://download.fedoraproject.org/pub/epel|baseurl=http://archives.fedoraproject.org/pub/archive/epel|g' /etc/yum.repos.d/epel.repo
# Install Developer Toolset 2 for better C++11 support (GCC 4.8)
RUN yum install -y centos-release-scl && \
    sed -i 's|^mirrorlist=|#mirrorlist=|g' /etc/yum.repos.d/CentOS-SCLo-scl.repo && \
    sed -i 's|^mirrorlist=|#mirrorlist=|g' /etc/yum.repos.d/CentOS-SCLo-scl-rh.repo && \
    sed -i 's|^# baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g' /etc/yum.repos.d/CentOS-SCLo-scl.repo && \
    sed -i 's|^# baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g' /etc/yum.repos.d/CentOS-SCLo-scl-rh.repo
# Install build tools
RUN yum install -y \
    devtoolset-2-gcc \
    devtoolset-2-gcc-c++ \
    devtoolset-2-binutils \
    make \
    && yum clean all
# Set working directory
WORKDIR /app
# Copy all header files
COPY *.h ./
# Copy all C++ source files
COPY *.cpp ./
# Build the application with optimizations using devtoolset-2 (GCC 4.8)
# AVX2 intrinsics are used in the code for x86-64 platforms
RUN scl enable devtoolset-2 "g++ -O2 -mavx2 -o benchmark \
    main.cpp \
    matrix_operations.cpp \
    hash_operations.cpp \
    string_search.cpp \
    memory_operations.cpp \
    polynomial_eval.cpp \
    -std=c++11"
# Create a startup script
COPY start.sh .
RUN chmod +x start.sh
# Run the application
CMD ["./start.sh"]
Using the Arm MCP Server to check compatibility
With the Arm MCP Server connected to your AI assistant, you can quickly verify base image compatibility using a simple natural language prompt:
Check if this Dockerfile supports Arm
The AI assistant uses the check_image or skopeo tool to inspect the base image and return a compatibility report. For centos:6, you’d discover that this legacy image doesn’t support arm64 architecture.
In this section, you’ve used direct AI chat with the Arm MCP Server to check Docker base images for Arm compatibility. You’ve seen how a simple natural language prompt can quickly identify compatibility issues without manually inspecting image manifests.
In the next section, you’ll set up the Arm Cloud Migration Agent in GitHub Copilot and use it to migrate x86 SIMD code to Arm.
