In this section, you deploy a production-ready NGINX application on an Arm64-based GKE cluster using GitOps with Argo CD.
All Kubernetes resources are declared in Git and continuously reconciled by Argo CD, ensuring the cluster always matches the desired state stored in the repository.
Ensure the following prerequisites are met before proceeding:
kubectl is configured for the clusterCreate a local Git repository that acts as the single source of truth for application configuration:
mkdir -p argocd-arm-gitops/apps/nginx
cd argocd-arm-gitops
git init
This creates a GitOps-compliant directory structure for managing Kubernetes applications and initializes a local Git repository that you push to GitHub. This establishes Git as the only place where application state is defined (no manual kubectl apply).
Repository structure:
argocd-arm-gitops/
└── apps/
└── nginx/
├── namespace.yaml
├── deployment.yaml
└── service.yaml
Create declarative Kubernetes manifests that define the desired state of the application.
Create a namespace manifest (apps/nginx/namespace.yaml):
apiVersion: v1
kind: Namespace
metadata:
Create a deployment manifest (apps/nginx/deployment.yaml) that deploys an NGINX application with two replicas for high availability:
apiVersion: apps/v1
kind: Deployment
metadata:
namespace: prod
spec:
replicas: 2
selector:
matchLabels:
app: nginx
template:
metadata:
labels:
app: nginx
spec:
containers:
- name: nginx
image: nginx:1.25
ports:
- containerPort: 80
Create a service manifest (apps/nginx/service.yaml) that exposes NGINX publicly using a LoadBalancer service:
apiVersion: v1
kind: Service
metadata:
namespace: prod
spec:
type: LoadBalancer
selector:
app: nginx
ports:
- port: 80
targetPort: 80
Go to https://github.com/<YOUR_GITHUB_USERNAME> and create a repository called argocd-arm-gitops.
Push the application manifests to GitHub so Argo CD can continuously track and apply changes:
git add .
git config --global user.email "you@example.com"
git config --global user.name "Your Name"
git commit -m "Initial Arm GitOps app"
git branch -M main
git remote add origin https://github.com/<YOUR_GITHUB_USERNAME>/argocd-arm-gitops.git
git push -u origin main
Replace <YOUR_GITHUB_USERNAME> with your GitHub username or organization name. These commits define the desired cluster state, and any future Git change automatically triggers reconciliation.
Create an Argo CD Application resource to link GitHub manifests with the GKE cluster.
Create argo-app.yaml and replace <YOUR_GITHUB_USERNAME> with your GitHub username or organization:
apiVersion: argoproj.io/v1alpha1
kind: Application
metadata:
namespace: argocd
spec:
project: default
source:
repoURL: https://github.com/<YOUR_GITHUB_USERNAME>/argocd-arm-gitops.git
targetRevision: main
path: apps/nginx
destination:
server: https://kubernetes.default.svc
namespace: prod
syncPolicy:
automated:
prune: true
selfHeal: true
Key settings:
automated sync keeps the cluster aligned with Gitprune removes deleted resourcesselfHeal restores manual driftEnsure the repoURL points to your GitHub repository.
Apply the application:
kubectl apply -f argo-app.yaml
Confirm that Argo CD has successfully synchronized and deployed the application:
kubectl get pods -n prod
kubectl get svc -n prod
The output is similar to:
NAME READY STATUS RESTARTS AGE
nginx-55d67f7b54-glhj5 1/1 Running 0 5s
nginx-55d67f7b54-sdh9h 1/1 Running 0 5s
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
nginx LoadBalancer 34.118.225.71 34.30.xx.xx 80:32019/TCP 2m11s
Validate the deployment by accessing the application through the external load balancer:
http://<NGINX_EXTERNAL_IP>
You should see the NGINX welcome page:
NGINX Application Output
This confirms the application is successfully deployed via GitOps.
Return to the Argo CD UI:
https://<ARGOCD_EXTERNAL_IP>
The Argo CD UI provides real-time visibility into application health, sync status, repository source, and deployment history.
Argo CD Application Status
Key indicators:
apps/nginxprodValidate Argo CD’s self-healing capability by manually changing the cluster state:
kubectl scale deployment nginx -n prod --replicas=1
Argo CD automatically restores the deployment back to two replicas, matching the Git-defined desired state.
You’ve successfully implemented a production-grade GitOps workflow on Arm infrastructure:
You can now explore additional Argo CD features or apply these GitOps patterns to your own applications.
