AFM-4.5B deployment on Google Cloud Axion with Llama.cpp
Provision a Google Cloud Axion Arm64 environment
Configure your Google Cloud Axion Arm64 environment
Build Llama.cpp on Google Cloud Axion Arm64
Install Python dependencies for Llama.cpp
Download and optimize the AFM-4.5B model for Llama.cpp
Run inference with AFM-4.5B using Llama.cpp
Benchmark and evaluate AFM-4.5B quantized models on Axion
Review your AFM-4.5B deployment on Axion
Use the
llama-bench
tool to measure model performance on Google Cloud Axion Arm64, including inference speed and memory usage.
Run benchmarks on multiple versions of AFM-4.5B:
# Benchmark the full-precision model
bin/llama-bench -m models/afm-4-5b/afm-4-5B-F16.gguf
# Benchmark the 8-bit quantized model
bin/llama-bench -m models/afm-4-5b/afm-4-5B-Q8_0.gguf
# Benchmark the 4-bit quantized model
bin/llama-bench -m models/afm-4-5b/afm-4-5B-Q4_0.gguf
Typical results on a 16 vCPU Axion instance:
Results vary depending on system configuration and load.
Benchmark across prompt sizes and thread counts:
bin/llama-bench -m models/afm-4-5b/afm-4-5B-Q4_0.gguf \
-p 128,256,512 \
-n 128 \
-t 4,8,16
This command does the following:
-p: evaluates prompt lengths of 128, 256, and 512 tokens-n: generates 128 tokens-t: runs inference using 4, 8, and 16 threadsHere’s an example of how performance scales across threads and prompt sizes (pp = prompt processing, tg = text generation):
| model | size | params | backend | threads | test | t/s |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 4 | pp128 | 106.03 ± 0.21 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 4 | pp256 | 102.82 ± 0.05 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 4 | pp512 | 95.41 ± 0.18 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 4 | tg128 | 24.15 ± 0.02 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 8 | pp128 | 196.02 ± 0.42 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 8 | pp256 | 190.23 ± 0.34 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 8 | pp512 | 177.14 ± 0.31 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 8 | tg128 | 40.86 ± 0.11 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 16 | pp128 | 346.08 ± 0.62 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 16 | pp256 | 336.72 ± 1.43 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 16 | pp512 | 315.83 ± 0.22 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 16 | tg128 | 62.39 ± 0.20 |
Even with just four threads, the Q4_0 model achieves comfortable generation speeds. On larger instances, you can run multiple concurrent model processes to support parallel workloads.
For batch inference, use
llama-batched-bench
Perplexity measures how well a model predicts text:
Use the llama-perplexity tool to measure how well each model predicts the next token in a sequence. Perplexity is a measure of how well a language model predicts text. It gives you insight into the model’s confidence and predictive ability, representing the average number of possible next tokens the model considers when predicting each word:
The llama-perplexity tool evaluates the model’s quality on text datasets by calculating perplexity scores. Lower perplexity indicates better quality.
Use the following script to download and extract the Wikitext-2 dataset:
sh scripts/get-wikitext-2.sh
This script downloads and extracts the dataset to a local folder named wikitext-2-raw.
Run the llama-perplexity tool to evaluate how well each model predicts the Wikitext-2 test set:
bin/llama-perplexity -m models/afm-4-5b/afm-4-5B-F16.gguf -f wikitext-2-raw/wiki.test.raw
bin/llama-perplexity -m models/afm-4-5b/afm-4-5B-Q8_0.gguf -f wikitext-2-raw/wiki.test.raw
bin/llama-perplexity -m models/afm-4-5b/afm-4-5B-Q4_0.gguf -f wikitext-2-raw/wiki.test.raw
Running a full perplexity evaluation on all three models takes about 3 hours. To avoid SSH timeouts and keep the process running after logout, wrap the commands in a shell script and run it in the background.
Create a script named ppl.sh:
#!/bin/bash
# ppl.sh
Run it:
nohup sh ppl.sh >& ppl.sh.log &
tail -f ppl.sh.log
| Model | Generation speed (batch size 1, 16 vCPUs) | Memory Usage | Perplexity (Wikitext-2) | Perplexity Increase |
| F16 | ~25 tokens per second | ~9 GB | 8.4612 +/- 0.06112 | 0 (baseline) |
| Q8_0 | ~40 tokens per second | ~5 GB | 8.4776 +/- 0.06128 | +0.19% |
| Q4_0 | ~60 tokens per second | ~3 GB | 9.1897 +/- 0.06604 | +8.6% |
We can see that 8-bit quantization introduces negligible degradation. The 4-bit model does suffer more, but may still serve its purpose for simpler use cases. As always, you should run your own tests and make up your own mind.
When you have finished your benchmarking and evaluation, make sure to terminate your Google instance in the console to avoid incurring unnecessary charges for unused compute resources.
