Use the
llama-bench
tool to measure model performance, including inference speed and memory usage.
Benchmark multiple model versions to compare performance:
# Benchmark the full-precision model
bin/llama-bench -m models/afm-4-5b/afm-4-5B-F16.gguf
# Benchmark the 8-bit quantized model
bin/llama-bench -m models/afm-4-5b/afm-4-5B-Q8_0.gguf
# Benchmark the 4-bit quantized model
bin/llama-bench -m models/afm-4-5b/afm-4-5B-Q4_0.gguf
Typical results on a 16 vCPU instance:
Your actual results might vary depending on your specific instance configuration and system load.
Use this command to benchmark performance across prompt sizes and thread counts:
bin/llama-bench -m models/afm-4-5b/afm-4-5B-Q4_0.gguf \
-p 128,256,512 \
-n 128 \
-t 4,8,16
This command does the following:
-p: evaluates prompt lengths of 128, 256, and 512 tokens-n: generates 128 tokens-t: runs inference using 4, 8, and 16 threadsHere’s an example of how performance scales across threads and prompt sizes (pp = prompt processing, tg = text generation):
| model | size | params | backend | threads | test | t/s |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 4 | pp128 | 106.03 ± 0.21 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 4 | pp256 | 102.82 ± 0.05 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 4 | pp512 | 95.41 ± 0.18 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 4 | tg128 | 24.15 ± 0.02 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 8 | pp128 | 196.02 ± 0.42 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 8 | pp256 | 190.23 ± 0.34 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 8 | pp512 | 177.14 ± 0.31 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 8 | tg128 | 40.86 ± 0.11 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 16 | pp128 | 346.08 ± 0.62 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 16 | pp256 | 336.72 ± 1.43 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 16 | pp512 | 315.83 ± 0.22 |
| arcee 4B Q4_0 | 2.50 GiB | 4.62 B | CPU | 16 | tg128 | 62.39 ± 0.20 |
Even with just four threads, the Q4_0 model achieves comfortable generation speeds. On larger instances, you can run multiple concurrent model processes to support parallel workloads.
To benchmark batch inference, use
llama-batched-bench
Use the llama-perplexity tool to measure how well each model predicts the next token in a sequence. Perplexity is a measure of how well a language model predicts text. It gives you insight into the model’s confidence and predictive ability, representing the average number of possible next tokens the model considers when predicting each word:
The llama-perplexity tool evaluates the model’s quality on text datasets by calculating perplexity scores. Lower perplexity indicates better quality.
Use the following script to download and extract the Wikitext-2 dataset:
sh scripts/get-wikitext-2.sh
This script downloads and extracts the dataset to a local folder named wikitext-2-raw.
Run the llama-perplexity tool to evaluate how well each model predicts the Wikitext-2 test set:
bin/llama-perplexity -m models/afm-4-5b/afm-4-5B-F16.gguf -f wikitext-2-raw/wiki.test.raw
bin/llama-perplexity -m models/afm-4-5b/afm-4-5B-Q8_0.gguf -f wikitext-2-raw/wiki.test.raw
bin/llama-perplexity -m models/afm-4-5b/afm-4-5B-Q4_0.gguf -f wikitext-2-raw/wiki.test.raw
Running a full perplexity evaluation on all three models takes about 3 hours. To avoid SSH timeouts and keep the process running after logout, wrap the commands in a shell script and run it in the background.
Create a script named ppl.sh:
For example:
#!/bin/bash
# ppl.sh
nohup sh ppl.sh >& ppl.sh.log &
tail -f ppl.sh.log
| Model | Generation speed (batch size 1, 16 vCPUs) | Memory Usage | Perplexity (Wikitext-2) | Perplexity Increase |
| F16 | ~25 tokens per second | ~9 GB | 8.4612 +/- 0.06112 | 0 (baseline) |
| Q8_0 | ~40 tokens per second | ~5 GB | 8.4776 +/- 0.06128 | +0.19% |
| Q4_0 | ~60 tokens per second | ~3 GB | 9.1897 +/- 0.06604 | +8.6% |
We can see that 8-bit quantization introduces negligible degradation. The 4-bit model does suffer more, but may still serve its purpose for simpler use cases. As always, you should run your own tests and make up your own mind.
When you have finished your benchmarking and evaluation, make sure to terminate your AWS EC2 instance in the AWS Management Console to avoid incurring unnecessary charges for unused compute resources.
