In this step, you’ll download the
AFM-4.5B
model from Hugging Face, convert it to the GGUF format for compatibility with llama.cpp, and generate quantized versions to optimize memory usage and improve inference speed.
If you want to skip the model optimization process, GGUF versions are available.
Make sure to activate your virtual environment before running any commands. The instructions below walk you through downloading and preparing the model for efficient use on AWS Graviton4.
In order to download AFM-4.5B, you will need:
pip install huggingface_hub hf_xet
This command installs:
huggingface_hub: Python client for downloading models and datasetshf_xet: Git extension for fetching large model files hosted on Hugging FaceThese tools include the hf command-line interface you’ll use next.
hf auth login
_| _| _| _| _|_|_| _|_|_| _|_|_| _| _| _|_|_| _|_|_|_| _|_| _|_|_| _|_|_|_|
_| _| _| _| _| _| _| _|_| _| _| _| _| _| _| _|
_|_|_|_| _| _| _| _|_| _| _|_| _| _| _| _| _| _|_| _|_|_| _|_|_|_| _| _|_|_|
_| _| _| _| _| _| _| _| _| _| _|_| _| _| _| _| _| _| _|
_| _| _|_| _|_|_| _|_|_| _|_|_| _| _| _|_|_| _| _| _| _|_|_| _|_|_|_|
To login, `huggingface_hub` requires a token generated from https://huggingface.co/settings/tokens .
Enter your token (input will not be visible):
Please enter the token you created above, and answer ’n’ to “Add token as git credential? (Y/n)”.
hf download arcee-ai/afm-4.5B --local-dir models/afm-4-5b
This command downloads the model to the models/afm-4-5b directory:
arcee-ai/afm-4.5B is the Hugging Face model identifier.
python3 convert_hf_to_gguf.py models/afm-4-5b
deactivate
This command converts the downloaded Hugging Face model to GGUF (GGML Universal Format):
convert_hf_to_gguf.py is a conversion script that comes with Llama.cpp.models/afm-4-5b is the input directory containing the Hugging Face model files.afm-4-5B-F16.gguf ~15GB file in the same models/afm-4-5b/ directory.Next, deactivate the Python virtual environment as future commands won’t require it.
bin/llama-quantize models/afm-4-5b/afm-4-5B-F16.gguf models/afm-4-5b/afm-4-5B-Q4_0.gguf Q4_0
This command creates a 4-bit quantized version of the model:
llama-quantize is the quantization tool from Llama.cpp.afm-4-5B-F16.gguf is the input GGUF model file in 16-bit precision.Q4_0 applies zero-point 4-bit quantization.afm-4-5B-Q4_0.gguf.Arm has contributed optimized kernels for Q4_0 that use Neoverse V2 instruction sets. These low-level routines accelerate math operations, delivering strong performance on Graviton4.
These instruction sets allow Llama.cpp to run quantized operations significantly faster than generic implementations, making Arm processors a competitive choice for inference workloads.
bin/llama-quantize models/afm-4-5b/afm-4-5B-F16.gguf models/afm-4-5b/afm-4-5B-Q8_0.gguf Q8_0
This command creates an 8-bit quantized version of the model:
Q8_0 specifies 8-bit quantization with zero-point compression.afm-4-5B-Q8_0.gguf.Similar to Q4_0, Arm has contributed optimized kernels for Q8_0 quantization that take advantage of Neoverse V2 instruction sets. These optimizations provide excellent performance for 8-bit operations while maintaining higher accuracy compared to 4-bit quantization.
After completing these steps, you’ll have three versions of the AFM-4.5B model in models/afm-4-5b:
afm-4-5B-F16.gguf - The original full-precision model (~15GB)afm-4-5B-Q4_0.gguf - 4-bit quantized version (~4.4GB) for memory-constrained environmentsafm-4-5B-Q8_0.gguf - 8-bit quantized version (~8GB) for balanced performance and memory usageThese models are now ready to be used with the llama.cpp inference engine for text generation and other language model tasks.
