In this step, you’ll build Llama.cpp from source. Llama.cpp is a high-performance C++ implementation of the LLaMA model, optimized for inference on a range of hardware platforms, including Arm-based processors like AWS Graviton4.
Even though AFM-4.5B uses a custom model architecture, you can still use the standard Llama.cpp repository - Arcee AI has contributed the necessary modeling code upstream.
git clone https://github.com/ggerganov/llama.cpp
This command clones the Llama.cpp repository from GitHub to your local machine. The repository contains the source code, build scripts, and documentation needed to compile the inference engine.
cd llama.cpp
Change into the llama.cpp directory to run the build process. This directory contains the CMakeLists.txt file and all source code.
cmake -B .
This command configures the build system using CMake:
-B . tells CMake to generate build files in the current directoryIf you’re running on Graviton4, the CMake output should include hardware-specific optimizations targeting the Neoverse V2 architecture. These optimizations are crucial for achieving high performance on Graviton4:
-- ARM feature DOTPROD enabled
-- ARM feature SVE enabled
-- ARM feature MATMUL_INT8 enabled
-- ARM feature FMA enabled
-- ARM feature FP16_VECTOR_ARITHMETIC enabled
-- Adding CPU backend variant ggml-cpu: -mcpu=neoverse-v2+crc+sve2-aes+sve2-sha3+dotprod+i8mm+sve
These features enable advanced CPU instructions that accelerate inference performance on Arm64:
DOTPROD: Dot Product: hardware-accelerated dot product operations for neural network workloads
SVE (Scalable Vector Extension): advanced vector processing capabilities that can handle variable-length vectors up to 2048 bits, providing significant performance improvements for matrix operations
MATMUL_INT8: integer matrix multiplication units optimized for transformers
FMA: fused multiply-add operations to speed up floating-point math
FP16 vector arithmetic: 16-bit floating-point vector operations to reduce memory use without compromising precision
cmake --build . --config Release -j16
This command compiles the Llama.cpp source code:
--build . tells CMake to build the project in the current directory--config Release enables optimizations and strips debug symbols-j16 runs the build with 16 parallel jobs, which speeds up compilation on multi-core systems like Graviton4The build process compiles the C++ source code into executable binaries optimized for the Arm64 architecture. Compilation typically takes under a minute.
After compilation, you’ll find several key command-line tools in the bin directory:
llama-cli: the main inference executable for running LLaMA modelsllama-server: a web server for serving model inference over HTTPllama-quantize: a tool for model quantization to reduce memory usageYou can find more tools and usage details in the llama.cpp GitHub repository .
These binaries are specifically optimized for the Arm architecture and will provide excellent performance on your Graviton4 instance.
