In this step, you’ll set up the Graviton4 instance with the tools and dependencies required to build and run the AFM-4.5B model. This includes installing system packages and a Python environment.
Run the following command to update your local APT package index:
sudo apt-get update
This step ensures you have the most recent metadata about available packages, including versions and dependencies. It helps prevent conflicts when installing new packages.
Install the build tools and Python environment:
sudo apt-get install cmake gcc g++ git python3 python3-pip python3-virtualenv libcurl4-openssl-dev unzip -y
This command installs the following tools and dependencies:
CMake: cross-platform build system generator used to compile and build Llama.cpp
GCC and G++: GNU C and C++ compilers for compiling native code
Git: version control system for cloning repositories
Python 3: Python interpreter for running Python-based tools and scripts
Pip: Python package manager
Virtualenv: tool for creating isolated Python environments
libcurl4-openssl-dev: development files for the curl HTTP library
Unzip: tool to extract .zip files (used in some model downloads)
The -y flag automatically approves the installation of all packages without prompting.
After completing the setup, your instance includes the following tools and environments:
You’re now ready to build Llama.cpp and download the Arcee Foundation Model.
