AFM-4.5B is a 4.5-billion-parameter foundation model designed to balance accuracy, efficiency, and broad language coverage. Trained on nearly 8 trillion tokens of carefully filtered data, it performs well across a wide range of languages, including Arabic, English, French, German, Hindi, Italian, Korean, Mandarin, Portuguese, Russian, and Spanish.
In this Learning Path, you’ll deploy AFM-4.5B using Llama.cpp on an Arm-based AWS Graviton4 instance. You’ll walk through the full workflow, from setting up your environment and compiling the runtime, to downloading, quantizing, and running inference on the model. You’ll also evaluate model quality using perplexity, a common metric for measuring how well a language model predicts text.
This hands-on guide helps developers build cost-efficient, high-performance LLM applications on modern Arm server infrastructure using open-source tools and real-world deployment practices.
Provision compute: launch an EC2 instance using a Graviton4-based instance type (for example, c8g.4xlarge)
Set up your environment: install the required build tools and dependencies (such as CMake, Python, and Git)
Build the inference engine: clone the Llama.cpp repository and compile the project for your Arm-based environment
Prepare the model: download the AFM-4.5B model files from Hugging Face and use Llama.cpp’s quantization tools to reduce model size and optimize performance
Run inference: load the quantized model and run sample prompts using Llama.cpp.
Evaluate model quality: calculate perplexity or use other metrics to assess model performance
