Get started with Apache Arrow and Arrow Flight on Google Axion C4A
Create firewall rules on GCP for Apache Arrow, MinIO, and Arrow Flight
Create a Google Axion C4A arm64 virtual machine on GCP
Set up Apache Arrow and MinIO on arm64
Analyze columnar data with Apache Arrow on arm64
Run high-speed analytics with Apache Arrow Flight on arm64
In this section you’ll create a Google Axion C4A arm64 virtual machine on Google Cloud Platform. You’ll use the c4a-standard-4 machine type, which provides 4 vCPUs and 16 GB of memory. This virtual machine hosts your Apache Arrow and Arrow Flight applications.
For help with GCP setup, see the Learning Path Getting started with Google Cloud Platform .
To create a virtual machine based on the C4A instance type:
C4A.c4a-standard-4 for machine type.
Configuring machine type to C4A in Google Cloud Console
allow-arrow-minio-flight so this virtual machine matches the firewall rule you created in the previous section.After the instance starts, select SSH next to the VM in the instance list to open a browser-based terminal session.
Connecting to a running C4A VM using SSH
A new browser window opens with a terminal connected to your VM.
Terminal session connected to the VM
In this section:
Your virtual machine is now ready to host Apache Arrow and Arrow Flight.
